  • Replies 112
  • sheepers
    113
just to clarify, that brown shit on the dash ^^^ was where a shift light was glued down. i couldn't get it off but sticking the GPS unit over covers it up well.
so it looks like the center bottom bit on my car has been cut and the top piece has been removed.
my one does not look like this, it has no top bar.
i might just make it work with what ive got and keep my eye out for another one.
this is the noise, its a bit hard to hear but im sure you'll pick out the surging type noise. it does this at idle but not as pronounced or as loud.
  • Confused 1
haven't worked on this in the last couple of days, ive been insulating my shed and im currently building a bathroom in the shed.
Dyno is booked for the 20th of October.
i have two issues to fix between now and dyno day.
1 - turbo shuffle
2 - boiling the water in the turbos after shutoff.
lets talk about turbo shuffle. it didn't do it when this motor was in the other car, it does it at idle and now that I've balanced the wastegates it does it at small throttle input but as soon as you  get some serious airflow it stops.
differences between then and now,
  • different tune
  • no return piping from the blowoff valves
  • no MAF sensors
everything else is the same.
im wondering if a balance on the intake might help?
like the ones on these drag cars,
its the only real difference between how it was and how it is now.
ill rig something up and see what happens.
then the last thing to address is  the water flow weirdness but that's for another day.
  • Like 9
