Not much to report as per usual, operations have been remarkably flawless.
I have been amassing the necessary components to complete a preventative refresh or the rear end.
A bunch of bearings and bushings etc.
As such I have just dropped the rear end this Arvo, parts have a solid 10mm of schmutz that will require a serious going over with the water blaster prior to disassembly.
Some pics,
1) the radius arm attaches the lower control arm to the chassis, its the only rubber bush (apart from the subframe mounts) The retarded thing is you can't get the mounting bolt out while the shock is in place, there simply isn't room. The bolt is even special in that it's not a typical 6 sided hex bolt, one of the points is cut off so it's a 4 sided "hex" . Top tier English engineering IMG20260811203914.thumb.jpg.f1bb7898edec83299edf5b17c3322f22.jpg
  • Haha 6
  • Confused 2
Close up view of the inboard brakes setup.
I had thought about extending the bleeders to a more accessible location but upon having a proper look they really aren't that bad to accessIMG20260811203925.thumb.jpg.d7c438698a28003e34207551210c950d.jpg
And lastly for today, the diff cradle is dropped from the car.
Really not too big of a job, about 90 mins all up, not bad for a first time. There really isn't that much holding it in the car. 8 mount bolts, 2 radius arm bolts, d shaft, hand brake and brake line.
Next up is a thorough cleaning and disassembly IMG20260812155642.thumb.jpg.a39147e42278fe1873c30089ef5e77f6.jpg
  • Like 9
Howzit,
Had some issues with the rear hub inner grease seal. It was like the supplied seals were a bees dick too large and simply wouldn't fit in. I completely mangled one trying so ordered what I thought was the same thing, turns out it was a more factory style metal/ rubber seals rather than the newer all rubber style. These older style could go in 1 of 2 ways, curve down or curve up. They were also a very tight fit, I decided to go curve down due to ease of installation. It's only sealing wheel bearing grease under no pressure so should be fine
Then decided to put the lower arm needle bearing stuff together. Significantly easier than i expected. I'm at like 2 months since disassembly at this point to my memory is beginning to fade on the specific order of seals etc, luckily there could only go together one way.
There are 2 needle bearings in each side of the fork that are pressed in, then the "axel" they allow to rotate, on the inside / outside there is a small inner washer, a grease seal, a lager outer ring and a big boy washer.
Currently held in place via cable ties
I just need to extract the large radius arm Bushes and press in the new ones and all the refreshing is done. They are like 95mm OD so much bigger than anything I have to press them in / out so I think I'll have to cut them out.
I have ordered a cheap ultrasonic cleaner to hopefully tart up all of the hardware but it's effectiveness has yet to be seen, it should arrive today.
  • Like 9
