Popular Post Hunterkiwi01 Posted December 17, 2024 Popular Post Posted December 17, 2024 I bought this honda c100 a couple of days ago for $500. It's my first real project bike that I have owned. (My younger sister named it Ronda because it's a honda obviously) 9 2 Quote
GregT Posted December 17, 2024 Posted December 17, 2024 Spare bottom end in a beer crate, Traditional. Going to rebuild the Honda or go Lifan ? If you split the engine(s) i'm happy to come and assess/advise. 5 Quote
Doug Hill Posted December 17, 2024 Posted December 17, 2024 That looks perfect, very swish! If you don't use the original pushtod motors I'd be happy to buy them off you Quote
Hunterkiwi01 Posted December 18, 2024 Author Posted December 18, 2024 I am for now but might swap later. Quote
Hunterkiwi01 Posted December 18, 2024 Author Posted December 18, 2024 15 hours ago, GregT said: Spare bottom end in a beer crate, Traditional. Going to rebuild the Honda or go Lifan ? If you split the engine(s) i'm happy to come and assess/advise. I think it would be cool to rebuild the 50. The thought process is at least build a good bottom end. 1 Quote
GregT Posted December 18, 2024 Posted December 18, 2024 45 minutes ago, Hunterkiwi01 said: I think it would be cool to rebuild the 50. The thought process is at least build a good bottom end. First step is split what you have and assess. Pretty sure rod kits can be found. 1 Quote
Doug Hill Posted December 18, 2024 Posted December 18, 2024 You can basically get everything from Malcolm at Anaconda. Be aware when buying stuff on line that the pushrod motors are entirely different to the OHC units, even the rotating assembly 2 Quote
Hunterkiwi01 Posted December 19, 2024 Author Posted December 19, 2024 Oh ok. This is the first motor rebuild so I appreciate all the help I can get. I have been doing some research on pushrod motors and I've become more and more confused 3 Quote
Doug Hill Posted December 19, 2024 Posted December 19, 2024 They're about as simple as a 4 stroke gets, perfect place to start. 2 Quote
GregT Posted December 19, 2024 Posted December 19, 2024 Got a workshop manual ? They can frequently be found free online to download. 2 Quote
Mop Head Posted December 19, 2024 Posted December 19, 2024 Schematics here: https://www.cmsnl.com/honda-c100-japan_model50708/partslist/ Service manual download (if you login): https://4-stroke.net/131-honda/honda-c100/downloads/438-honda-c100-service-manual.html Workshop manual: https://4-stroke.net/download/workshop-manual/1011-workshop-manual-for-honda-c100-1961.html I just created an account on that site and the downloads legitimately work. Can download 5 documents a day on 4-stroke.net Good luck! 3 4 Quote
Hunterkiwi01 Posted December 19, 2024 Author Posted December 19, 2024 1 hour ago, Mop Head said: Schematics here: https://www.cmsnl.com/honda-c100-japan_model50708/partslist/ Service manual download (if you login): https://4-stroke.net/131-honda/honda-c100/downloads/438-honda-c100-service-manual.html Workshop manual: https://4-stroke.net/download/workshop-manual/1011-workshop-manual-for-honda-c100-1961.html I just created an account on that site and the downloads legitimately work. Can download 5 documents a day on 4-stroke.net Good luck! Thanks this will come in handy. Quote
felixx Posted December 28, 2024 Posted December 28, 2024 One of the studs holding thr barrel on is rusted. We will hit it with a blowtorch tomorrow. How much heat is too much??? Quote
Raizer Posted December 28, 2024 Posted December 28, 2024 14 minutes ago, felixx said: One of the studs holding thr barrel on is rusted. We will hit it with a blowtorch tomorrow. How much heat is too much??? You'll want to get a good bit of heat into it but if it turns into a liquid, that was too much. 1 3 Quote
GregT Posted December 28, 2024 Posted December 28, 2024 Give it a soak in atf/acetone mix first. 1 2 Quote
Hunterkiwi01 Posted December 30, 2024 Author Posted December 30, 2024 Will give it a go. I got some penetrating oil and it did shit all so I'll give that a go and put up a photo Quote
Hunterkiwi01 Posted January 2, 2025 Author Posted January 2, 2025 Me and @felixx used a heat old kerosine powered heat gun to wiggle the piston and head off. Worked a treat had it taken apart in about 30 mins. 3 Quote
Hunterkiwi01 Posted January 2, 2025 Author Posted January 2, 2025 This is the piston. I am wanting to re use but not sure about condition. I there are wear marks but nothing that can catch a fingernail. I am going to replace the rings. 1 Quote
