Am thoroughly enjoying your build, thanks for sharing it. Here, have some, similar themed surrealism for your shed listening pleasure:
  • Replies 303
1 hour ago, Tiger Tamer said:
Could you use a random or belt sander on it now and then use the fairing filler to correct the imperfections. Much easier to block sand.
It's too curved for the belt sander sadly but I did use it on the bottom panel especially where the skeg goes as that needs to get roughed up. The final coat I put on was with a fairing filler but not the softest one. I mustn't have used enough to dilute the epoxy as it is hard as wood. These are my weapons of choice:
The best one to use is the long board sander but it clogs fairly easily. Really what happens is whichever tool I'm using I look at the other ones longingly thinking that they are better. Spoiler alert: They aren't.
I might just recoat the thing and do it properly with smoothing it out whilst wet to as to build it up rather than sand it down. I'm trying not to get too stressed though as I have ordered some Altex high build surfacer and 4 liters of the stuff (5l including part B). Sanding that will be like heaven compared to the epoxy. Speaking of I need to start considering the colour choice for the hull. These are the choices I have to choo choo choose from below.
Pretty excited that I have got this far to even look at colours as I never thought I'd get this far looking at the plans when I got them. When they came in I sent an email back asking where the rest of the instructions were. :huh:
The faring filler is quite easy to sand if you mix quite a lot into it but not to be used at that ratio for strength. But we find out these things usually the hard way,lol.
You are doing really well getting it this far along in really quite a short time especially with all your other projects and life to deal with.
Paint colour, I really like the pic of the boat with the white hull and the maroon side plank. Whie or off white hull would show less imperfections as well I suppose.
5 hours ago, dmulally said:
Altex
Used Altex Regatta on the last boat and found it to be ludicrously thin and a challenge to make it stick to anything.
I don't know if International Toplac is any better.... Just uhh....good luck.
Burgundy hull with brass bits bolted to it.
Is that with the Altex primer and undercoat too? It was either that or Toplac. I used both to see how it would go on my lockers and I couldn't spot the difference. Pretty shit we have such little choice in NZ as other countries have all sorts of custom suppliers. John Welsford says for a trailer sailer just to use exterior house epoxy and crack on.
I went to the local Resene and the angry Karen behind the counter argued that they don't sell paint suitable for wood that gets wet so I left. I didn't have the energy.
I should have the body scuffed by close of play tonight. Tomorrow I want to slap some epoxy on it. Might use some 410 fairing filler in the second coat or a light skim with the bog spreader. That stuff is very easy to sand smooth. I'll tip it this time.
I know it's a different product line, but I used Altex epoxy everseal and the timbercote varnish on the woodie. If I was to ever refinish it I'd try something else as a couple of areas haven't really sealed very well (including doing it twice in some places).
It is carried in some of the resene shops, but they don't know much about it.
Epic work on the boat build though.
I used the Altex primer but I suck at surface prep because I have the patience of a child. So you'll have better results no doubt.
There's a slightly bigger range when you look at commercial suppliers like link-up paints.
This is what I used when I painted the inside of my wooden fizz boat recently. An epoxy that they matched to the outside colour it was already painted.
From complete paints in Napier.
Cool cheers. I'll look into it to see if it will stick to another brands primer.
Just called them and the lady didn't know what marine paint was but asked if I emailed her she would look into it for me.
So I decided to stop being lazy and re-coated the entire hull with light fairing compound. The softer stuff though this time and easier to sand than the other fairing compound. When this is all sanded smooth it'll need another coat or two of straight epoxy and then the primer. Adds another week to the project but I'd rather have more epoxy on it than paint to fill in the troughs.
Goes on like mayonnaise. I did one row of planking at a time then waited for it to run before scooping it off the next plank and then doing the next plank down. Took some time but at least I wasn't doing the whole thing at once which would have been quite boring. I did tip it but found it was so thick it didn't really make much of a difference.
As that'll need a couple days to set, that means tomorrow I can start working on the skeg. Really looking forward to working with wood again.
It was a fairly mixed bag of different surfaces I went over with the primer. From bare wood to probably single pack enamel paint. I never had any bad reaction from the primer and so far all is good but only been on there nearly a year.
They sell a fair bit of other stuff from paint and have quite a few staff, so you need to talk to the correct people. Always been good to deal with I have found.
The double bias cloth sure does like to drink up resin. The edges were already double taped so rather than drape over and create a fairing drama I just did up the skeg side and close to the edge.
Put tape over the sides to stop it all running off and build it up. Besides the initial base coat to wet the underside of the cloth, it took three more coats before it was fully wet. If I used the 200g cloth it would have taken one coat. Three coats on the 200g would have seen it begin to float.
Messenger_creation_539D8B76-27F9-46BE-8A78-5604630AE976.thumb.jpeg.7962087ca36c24774e65f0d4d98816df.jpeg
Anyway mission accomplished for the weekend and tomorrow restarts the fairing of the hull.
