mjrstar Posted September 26, 2025 Posted September 26, 2025 2 hours ago, gibbon said: I've give it a run without the inlet pipes (which are pretty oily to be fair) and it still smokes just as bad, so that rules out the turbos as the (only) source of the oil it's still kinda in bits and i wouldn't trust it around the block at the moment but i'll back it out of the garage and conduct a scheduled rev limiter function test in the driveway shortly edit: didnt feel like starting got a couple of coughs but that's all. doesn't stink of fuel though which is interesting If you have a dodgy turbo seal you can still be adding oil to the exhaust which will cause a chunk of smoke, but from cold this will take a minute or two at idle to start showing. Quote
RUNAMUCK Posted September 26, 2025 Posted September 26, 2025 Didn't @ProZac have trouble with his injector loom/plugs being old/baked/cooked? Quote
gibbon Posted September 27, 2025 Author Posted September 27, 2025 21 hours ago, mjrstar said: If you have a dodgy turbo seal you can still be adding oil to the exhaust which will cause a chunk of smoke, but from cold this will take a minute or two at idle to start showing. fair point but in this case it's smoke almost immediately 1 Quote
gibbon Posted September 27, 2025 Author Posted September 27, 2025 if i plan to really ring the shit out of this engine with the inlet disconnected, is there a risk of overspeeding the turbos? should I take the arm off the primary wastegate Quote
gibbon Posted September 27, 2025 Author Posted September 27, 2025 having the intake off also is probably half the reason it doesn't want to start, must have a bunch of vacuum leaks. but I was able to start it previously. Plugs look dry as which is weird Quote
gibbon Posted September 28, 2025 Author Posted September 28, 2025 god i dont want to pull this engine. just looking at it makes me sigh. it's festooned with extraneous shit. the triumph has ruined me 1 Quote
gibbon Posted September 28, 2025 Author Posted September 28, 2025 29 minutes ago, Positive Ape said: you can do it! I could do it. and yet here I am drinking a supercharger and feeling sorry for myself instead 2 1 Quote
bigfoot Posted September 28, 2025 Posted September 28, 2025 If you want a hand/supervisor giz a yell 1 Quote
gibbon Posted September 28, 2025 Author Posted September 28, 2025 should've made a start yesterday but I'm going to try and yoink the engine out today 3 Quote
cletus Posted September 28, 2025 Posted September 28, 2025 Kind of funny that a guy who fixes aeroplanes thinks an rx7 is complicated (Not being an ass, I mean a factory rx7 has a lot of giblets to deal with, possibly more than an aeroplane engine does?) Quote
shrike Posted September 28, 2025 Posted September 28, 2025 2 hours ago, cletus said: Kind of funny that a guy who fixes aeroplanes thinks an rx7 is complicated (Not being an ass, I mean a factory rx7 has a lot of giblets to deal with, possibly more than an aeroplane engine does?) Has anyone tried to certify an aircraft engine in an RX7? :p 1 Quote
igor Posted September 28, 2025 Posted September 28, 2025 How about a wankel powered flying machine? Quote
gibbon Posted September 29, 2025 Author Posted September 29, 2025 1 hour ago, igor said: How about a wankel powered flying machine? there's definitely a few of them around. rotaries make for theoretically a pretty decent aircraft engine, theyve got a low cross sectional area so not much drag, make good power for the size, and are extremely unlikely to seize in flight even if they fail downsides are fuel burn and high rpm so you need a reduction gearbox. and aviation is all about the devil you know, so even back in the 70s when rotaries would have no doubt been bought up in the board room at cessna etc, lycoming already had a thirty year track record of being too dumb to die at that point, so why risk it by switching? 5 Quote
gibbon Posted September 29, 2025 Author Posted September 29, 2025 3 hours ago, cletus said: Kind of funny that a guy who fixes aeroplanes thinks an rx7 is complicated (Not being an ass, I mean a factory rx7 has a lot of giblets to deal with, possibly more than an aeroplane engine does?) honestly compared to the nightmare of a 90s GT car, the aircraft we look after are pretty simple. no power steering, no aircon, pretty much no wiring loom, DEFINITELY no pneumatically controlled sequential turbocharger setup/emissions rat nest from hell as i mentioned though i think its more to do with the smooth sailing of working on the triumph recently 3 Quote
gibbon Posted September 29, 2025 Author Posted September 29, 2025 my body is a wreck and the keg is ready to come out wish it was a real keg 6 Quote
Nominal Posted September 29, 2025 Posted September 29, 2025 10 hours ago, shrike said: Has anyone tried to certify an aircraft engine in an RX7? :p Perhaps in an MR2? 2 2 Quote
Corbie Posted September 29, 2025 Posted September 29, 2025 Only need 9 more.. Pft edit: oops not random pic thread 1 Quote
Popular Post gibbon Posted October 5, 2025 Author Popular Post Posted October 5, 2025 tell me your secrets you shit cunt I'm not really taking photos at this point because I'm covered in shit and don't want to touch my phone. I must say that my resolution to retain the stock twin turbos is wavering, because refitting ALL THAT BULLSHIT is not really my scene. But future turbo budget is likely to depend on what I find next So something broken off and wedged in the water gallery is not a good start Front rotor is off and aside from being pretty fouled with carbon it looks pretty good. All the seals were there on removal, everything seems free enough to move, a tiny bit of edge peel on the housing and the chrome is exactly as expected for a 77km engine. Side plates are great, probably a thou or two if you're feeling unkind. That was the good rotor Having a beer, then onto the problem child rear rotor assembly... Ok I'm back Here's yer problem: stuck side seal. (Ignore the departed corner seal) And for good measure, another stuck side seal, but on a different chamber. Giving two flat results and all the hallmarks of a failed apex seal. So the good news is that I don't have a housing scored to death by busted seals and IMHO all the main components will go again Now, here's a strange thing to find in a virgin unopened engine: 16 1 Quote
gibbon Posted October 5, 2025 Author Posted October 5, 2025 So I feel like this was possibly self-inflicted with my somewhat liberal premixing and not sorting out the oil pump of unknown output. and MAYBE a hoon of biblical proportion MIGHT have freed up the side seals. But it still doesn't quite solve the smoking riddle. All the oil seals are there, the primary turbo has oil leaking from the turbine down to the wastegate but it's kinda impossible to determine if it's from the seals or if it's all the ATF that I poured down it's throat the last time I tried to start it. All I know at this point is that not everything that came out is going back in... 7 Quote
