20 minutes ago, kpr said:
The 6262 is a ripoff G series
G series as in Garrett? I thought the 6262 was a Precision ripoff? Google tells me Precision used to 'borrow' Garrett designs but not for a long time. oh the tangled, incestuous web that is turbocharger design and marketing...
  • Replies 236
Assuming that's a pulsar turbo?   They are a G series ripoff.  they used to even call them G series, I assume Garrett was unhappy about and they just started naming them by wheel size
6262 is a " g35-900 "
On 04/11/2025 at 16:01, xsspeed said:
you should probably raise it and fit less dished rims with your small turbo
At least you don't need to do this now
rx7 forums tell me that only the HKS specific turbo will bolt to the kit (sneaky buggers) a couple of hundred to chop and change the downpipe vs 4k on the genuine turbo is a no brainer
I cant help but feel that all this hassle would have been avoided if you'd just fitted a Nikki carb with mechanical secondaries, topped off with a Ramflo filter.
  • Haha 2
seconded
@cletusdoes converting from EFI to carb require a cert?
  • Haha 1
I found with the later model evo pull clutch disconnection. Look for a really short youtube video and pay careful attention to the size of the flat blade screwdriver they use. Up until then it seem impossible/daunting.
Once you get a feel for it, it's so simple.
14 minutes ago, gibbon said:
yip all FDs are pull type. I believe the reasoning behind it was malice
Pivot ratio on a pull clutch means you get more clamp load for the same pedal effort. A lot of mid to late 90's stuff migrated to pull type including 4wd's so not just in performance cars.
  • 7 months later...
as someone who doesn't do things properly it's really refreshing to work on an FD, where the advice for 75% of the engine shit you pull off is "don't bother putting that back on"
  • Haha 6
This is true.
All you need is a ramflo filter on a nikki carb with mechanical secondaries plus a big exhaust with a dumpy.
The rest is all unnecessary weight.
You can then revel in the many hundreds of ponies at ungodly revs
  • Haha 3
