  • Replies 237
....yeah I reckon we might've cracked the case here
replacing the engine is neither here nor there as it's just made that aspect of the car as good as it can ever be, rather than an unknown. but I am mourning the loss of the stock twins
1 hour ago, ~Slideways~ said:
I've never heard of these having weak rods, this is very good info, I will now share it on every corner of the internet.
Not normally a problem on stock cams, it's when you go more than 3/4 race cams.
  • Haha 6
On 28/10/2025 at 21:42, cletus said:
Sounds like it needs rewiring with a new ecu so it doesn't throw a rod out of your new engine
Upgrade to green top/taxi rods. Much stronger incase of LPG kick back.
Seems logical while its out of the car.
  • Haha 2
18 hours ago, shrike said:
Have you decided on a single turbo config to use?
not really, seems like its such a buyer's market I'll just see whatever comes up super cheap. A complete TD06-20G setup with everything except the downpipe just went for $200.....
some not very interesting pictures but thought I'd better put something up so that this doesn't just turn into a big chat thread
I have run out of money so did non-spendy work on the car over the weekend. Cleaned the engine bay out, fitted the OMP and oil drain blanks
engine is all ready to go in, just waiting on the clutch and throwout bearing but apparently it takes 4 days for the DHL truck to drive between Auckland and Whangarei
stripped the loom back and removed quite a bit of the plumbing for the twin turbos. the only solenoids I have left are the ISC and double throttle
Firefly_GeminiFlash_anentireroomfulloftinyoldrubberhosesandbitsofblackplastic809727.png.753f547d444eb849a78b19a018db4894.png
the bodykit always looked a bit unfinished here at the rear of the front fender where there's just a gaping hole into nothing
so I sketched up some rice to fill the holes
the slicer decided that this was the most efficient way to print them?
meanwhile I think I've made a mistake with the PAC setup, I didn't realise that the kit you buy has multiple different turbo options (some of them HUGE) and the manifold and downpipe are scaled accordingly. So it would seem that this setup is from one of the aforementioned HUGE turbos and I am going to struggle to get something reasonably sized which will still mate up to everything. can't really call Garrett and say "give me your biggest turbo but make it real small please"
so probably going to shelve that, or at least look at getting it modified
  • Like 8
9 minutes ago, Alfashark said:
Unsure how things work in the Dorito world, but can you give them a holler and see if they'll exchange the manifold and downpipe for a smaller option?
I bought it second hand so they'll probably tell me to bugger off
I think it's going to be a bit of a sunken cost where I end up paying more for something cobbled together and less effective than it could be, just for the sake of retaining the wrong kit that I bought at the outset
i'm sure i can upcycle the downpipe into something useful though
  • Haha 1
3 hours ago, Nominal said:
Surely the answer is to fit a big-ass turbo?
Or just resell the second hand kit
i'll probably sell it eventually but when I do it'll be actualizing the loss as it inevitably resells for a fraction of what I paid for it (even though it was a bargain)
Ain't that the truth!
