dmulally Posted October 13, 2025 Posted October 13, 2025 Ive used it on stuff like chassis and trailers as a bare metal winner takes all. Never bothered with a top coat. 1 Quote
tortron Posted October 13, 2025 Posted October 13, 2025 its not porus like a primer, its not UV rated, it will go milky in the sun, but is otherwise fairly resistant. i have used it by itself, under cars, or as a base/sealer to be top coated currently my ute tray is sitting in it from bare metal 4 years ago without any signs of degredation (so its not porus as primer would be showing rust) i have had it peel a table frame, it was heavily pitted, i flapdisked it and hit thr pits with wire brush on grinder (no chemical rust removal), brushed durepox on and then left it outside in the rain. the rust spread under it after about 3 years where it was touching the ground it sets really hard, so if you get a run or whatever in it and you are going to topcoat then best to sand the lot within a few days rather than weeks. brushes well, fairly self leveling They will also tint it a bunch of colours 1 Quote
anglia4 Posted October 13, 2025 Author Posted October 13, 2025 Thanks guys. I’ll get it to use as an all in one. I’m thinking I might brush/roller it on just so I don’t have to deal with overspray etc. Remembering this is a patina car, not a show pony. 1 Quote
ThePog Posted December 11, 2025 Posted December 11, 2025 Fuck I could probably drive straight to your place on the basis of this pic 1 1 Quote
HumberSS Posted December 11, 2025 Posted December 11, 2025 2 hours ago, ThePog said: Fuck I could probably drive straight to your place on the basis of this pic Haha I thought the same Quote
HumberSS Posted July 4 Posted July 4 What carb does it run? Just had a couple rebuilt by the dude in normanby, he does such a great job and is familiar with most anything. He did my super snipe ones years ago and that thing ran like a clock. Quote
Thphantum Posted July 4 Posted July 4 Yea I'm interested to know what carb too. I'd say that vacuum advance was cooched for a while so someone had just tuned it to run without it, hence the timing being way off. Quote
anglia4 Posted July 4 Author Posted July 4 Yeah that was my theory as well, the timing was way off and the carb was full of sealant, so I think they had been chasing that issue for a while. It is a Holley 600(650? Can never remember) 4150(4160?) vacuum secondary Quote
Valiant Posted July 5 Posted July 5 Sounds like it might have a blocked idle jet. Did you fit the carb new out of the box? Does it react when you just the idle screws? Or can you turn them right in till they stop and it still runs? Quote
anglia4 Posted July 5 Author Posted July 5 It is the carb that was on the car but I have ultrasonic cleaned and re-kitted it. It responds to the idle screws. Quote
anglia4 Posted July 5 Author Posted July 5 There was a lot of blue silicone to deal with though, so it might be worth me pulling it apart again to check over Quote
Thphantum Posted July 5 Posted July 5 You can get different plastic cams for the accelerator pump lever that will make it squirt earlier/later/more/less but this is really super fine tuning. Also check the adjustment screw on the accelerator pump lever 1 Quote
anglia4 Posted July 5 Author Posted July 5 Accelerator pump is set correctly. Yes vac advance on the dizzy. The accelerator pump feels like it is working well, it comes off idle really nicely now, it’s just the high vac situations that are terrible. Idle and low throttle cruise. Quote
Lord Gruntfuttock Posted July 5 Posted July 5 Are you sure the vac secondaries are opening? I think you can put a rubber band or something on the linkage to see if it's opened properly. Maybe the diaphragm is leaking? I have the same carb. Pretty sure the standard ones have fixed secondary orifices. I bought a kit that added a plate with replaceable jets. I also bought variable rate secondary springs to tune where they come in. You shouldn't feel a sudden surge when they open, it should be fairly smooth. They're a good carb and reasonably simple. Loads of online help available in American forums etc... Quote
Thphantum Posted July 5 Posted July 5 Have you checked the vacuum advance on the Dizzy? Pull the hose off the carb and suck on it, see if the advance plate moves in the dizzy. Also this hose should be connected to the base of the carb for best function. Another thing to check is the power valve on the back of the metering block of the carb. One back fire through the carb can blow these. Quote
anglia4 Posted July 5 Author Posted July 5 I’ve just gone over the air idle again since I did the last float adjustment and now it’s running really nicely 🙌 5 Quote
LoLlife Posted July 5 Posted July 5 I had some dried fuel in the secondary needle and seat in my 600 Holley a while back from not getting used much. Made it leak fuel and idle like poos. @Shaz's Dad told me to clean it out and use my car more......... Bit of W.O.T to open up secondarys flushing fresh fuel through can't hurt now and then aye. Totally sick car too mate you've done really well getting it sorted, well done. 1 1 Quote
anglia4 Posted July 5 Author Posted July 5 Thank you! I get a bit disappointed now and again comparing how rough it is against my mustang, I’m starting to feel the need to paint it… Quote
