If its going to be slow it may as well be cool (inside)
Chucked the gauges on and it had sfa pressure. Had a small top up can so shoved it in
Compressor and TX valve are doing what they should so I'll get another couple of cans and see how it goes. Sticker says system charge is 750g. Cans are about 250g from what I can find so I'll get two more and see if it starts cooling
  • Replies 193
Stumbled across some old Korean videos on YouTube
Might need to re index the torsion bars in the front and find some shorter springs for the rear
Had a thought that maybe the injection pump wasn't seeing boost due to shit vacuum lines or a blockage somewhere
Yeah that was blocked
Now it's not
Thought I'd have a quick look at the intake crossover arm
Yeah that's pretty caked up too
Probably egr schmutz and pcv stuff so may as well reduce the things that could cause the schmutz
Only the finest of gasket materials
Needed to block off the egr port on the manifold so used the old valve so the flange wouldn't warp when I welded it.
Turns out the valve was sealed and the shit inside the pipe tried to escape as I was welding and was venting through the weld. It's ugly af and still has some pinhole leaks but I'll let the exhaust gas mark them out for me. It doesn't noticeably leak so it's good enough for now.
After all that work it's still Fucking slow.
Got annoyed with it and re installed vicegrips on the wastgate line and pulled off the intake arm. That's full throttle and a mild incline. I'm guessing the rest of the intake is going to be full of schmutz so it'll have to come off for a proper clean. While I have it apart will most likely pull the injectors and get them serviced as I bet they never have been done
  • Haha 2
Grabbed another couple of cans off marketplace and topped off the aircon, it's super cold now so I've managed to fix something which is nice.
Found a loose clamp on the intercooler. Tightened it but made no difference annoyingly.
Done a pressure test? What's the bet a hose has let go?
It had some pressure when I initially put the gauges on so I think it's just never been re gassed. It did hold the pressure from the first can over a week so it's good enough for now
Whipped the intake off in the slight hopes it'd be full of schmutz
Wasn't bad enough to cause this amount of performance loss.
Since I had most of it apart pulled the injectors out too. Chances are they have never been serviced so it won't hurt to have them checked over
That might be the problem there
Gave the intake a quick jizz of oven cleaner, degreaser and a waterblast
Will give it another go over with more elbow grease at some stage to get the last of the crap out
I was meaning for the intercooler piping but yeah, curious on why the a/c was down as its a closed system
any exhaust restriction?
Oooh my bad!
Yeah I have tightened all the clamps and it made no difference. No signs of boost leaks (I left a clamp loose and saw some oil schmutz escaping and no change after re tightening it)
No exhaust restriction I'm aware of as I had unbolted the downpipe to the muffler and it was equally slow, that was before sorting the boost feed to the pump though so could potentially be a issue
It was surprisingly quiet with no muffler so the massive middle muffler will probably end up in the scrap bin with a bit of pipe to replace it
Injector guy said injectors are a bit worn and the pressure has dropped off but he can sort them. Parts ex aus so will be a few days.
Had a cunt of a time on wagons ball joints/control arms today so down to zero drivable vehicles now.
Decided to do some basic maintenance to make myself feel better
Cleaned out the musso Intake. Pretty sure the schmutz re blocked the boost feed to the pump after did a half ass clean the other day
Did the glow plugs as well since manifold was off
Gave the ports a quick wipe and clean too. Reinstalled the boost rags into the ports to keep out the environment.
I had thought that ssangyong had for the castings or something to get the licensed by Mercedes but they must be licensed to assemble the engines.
Intake manifold is also Mercedes but has ssangyong part number on it
It's also got daewoo parts too
So it's a Korean made gm daewoo Daimler benz powered thing
Collected some camber & castor adjustment bolts today. Never felt more out of place or judged for walking into a business ha
Everything ready to go in
After a bit of a battle new lower control arm, new castor /front lower arm and new balljoint. Unsure which one wof man failed but the one in the castor arm was fucked and the other one wasn't much better.
  • Like 8
On 12/04/2025 at 16:28, Raizer said:
Some idiot owner butchered the tube so now that nice plug won't fit. Will keep a eye out for another tube.
Injectors for the musso are ready, will hopefully receive them this week and can get it all back together before Easter
  • Haha 2
Injectors arrived
New heatshields are wrong but others are on the courier and should be here tomorrow
Put the intake on, realised I forgot the throttle linkage. Took it off and reinstalled it
My egr butchery blank removed and better one in its place
Cleaned the last of the schmutz out of the boost tube
And sat it in place
I gave the alda (boost aneroid) 1/3 of a turn so hopefully it gets a bit more fuel quicker as boost comes on. Cbf pulling the back off the pump to tweak the rest, it'll also need to run so I can make sure that it returns to idle after tweaking it.
Gave it a oil change too but we all know what that looks like.
Hopefully after all this work and a bit of money it'll end up being regularly slow not Fucking slow
Wof sorted on wagon which is nice.
Went on a barry Mercedes diesel journey.
Genuine Mercedes crossover/boost tube gasket
Part number if anyone cares (not many musso left and even fewer weirdos who want to fix them)
And a new oil pressure switch to replace the one that's leaking oil internally
Now to install it all in the rain
Rain stopped luckily but was windy as
battled with the new injector clips but got them in and everything reassembled. I also had the correct size fuel hose to replace the vacuum hose on the injector return
Cranked it for ages until to got the air out
It's got a 4/5 race cam
Early merc injector torque spec is double the later models, I was cautious and went for the lower spec but looks like the injectors are leaking a bit of compression so will pull everything apart and re torque them and try again
