felixx Posted August 19, 2024 Posted August 19, 2024 Todays issue.. she goes about 750m at 85kmh (WOT) then dies (as if it is starved for fuel) After 20seconds I can kick her and she starts first go and does the same 750m later At 50kmh this is not an issue The carb is on an angle (air filter pointed about 15 deg down) when bike is upright. Could this be an issue? Quote
440bbm Posted August 19, 2024 Posted August 19, 2024 how tf it going that quick for a 50? sounds like its emptying the bowl. it could be a few things? electrical, like coil getting too hot but unlikely after such short distance/. check there is not blockages in the tank at fitting, sounds like a fuel supply issue. Quote
felixx Posted August 19, 2024 Author Posted August 19, 2024 Thanks. The thing has a 125 in it.. hence speed. I did put a rowdy exhaust on it. Might be causing issues. Will check fuel tank as filter looks fine Quote
Tumeke Posted August 19, 2024 Posted August 19, 2024 Check your flow rate from the tank, any kinks or restrictions in the hose/filter/tap and failing that check the float height in the carb. While in there, blow out your main jet. Also check your tank is higher than the carb because gravity. Lifan should run at full rabbit all day. Quote
felixx Posted August 19, 2024 Author Posted August 19, 2024 I just moved the fuel line it had a small kink in it and ran a less obnoxious exhaust and got a 10km ride, no issues including 3km wot in 4th. Ithink it was the fuel line . I love this thing. Quote
440bbm Posted August 19, 2024 Posted August 19, 2024 lol 125 in that. sounds hairy. i want one haha. good work on the diagnosis! Quote
felixx Posted August 19, 2024 Author Posted August 19, 2024 7 minutes ago, 440bbm said: i bet. gunna try the other zorst again? Maybe in the weekend. Its back to the Ubco for daily commuting and this in the weekend. Quote
GuyWithAviators Posted August 19, 2024 Posted August 19, 2024 Check your fuel cap is venting properly too Glenn. Has caught me out before. Vapour lock man Quote
440bbm Posted August 19, 2024 Posted August 19, 2024 So whats the go with this thing, are you just being dishonest about the motor on paperwork? did it bolt in or been modified to work? are u just rrelying ont he fact rego as 50 doesnt need wof and hoping a cop isnt clever to check? seems like a relatively simple cheap thing but no doubt as cheap as it should be. Quote
GuyWithAviators Posted August 19, 2024 Posted August 19, 2024 1 hour ago, 440bbm said: So whats the go with this thing, are you just being dishonest about the motor on paperwork? did it bolt in or been modified to work? are u just rrelying ont he fact rego as 50 doesnt need wof and hoping a cop isnt clever to check? seems like a relatively simple cheap thing but no doubt as cheap as it should be. Dont ask too many questions. Quote
440bbm Posted August 20, 2024 Posted August 20, 2024 fuck i must be blind. cannot find a single one! either new scoots with suzuki f50 and f50 just gets football boots LOL. Quote
felixx Posted August 20, 2024 Author Posted August 20, 2024 Try honda c50/90, yama v50, suzi f50 Quote
felixx Posted August 29, 2024 Author Posted August 29, 2024 Question. To lift my rear guard 10mm .. All I need to do is add longer shocks? Quote
GregT Posted August 29, 2024 Posted August 29, 2024 Are you looking for more clearance ? Do the current shocks have adjustable spring platforms ? Longer shocks will quicken the steering. Quote
