So I acquired this tonight..
It looks like a beast
Facebook marketplace special..
Just need to pick up an extra link on the chain and a couple of bits.
Reg on hold as 50cc.
Discuss here:
  • Like 7
  • Replies 64
Loom for lights/ indicator ordered
regulator ordered (12v) I got a 4 wire and 5 wire, what does the extra wire do?
I am guessing I can get a another joining link for the chain from any motorcycle shop? This should be fine for a small motor like this?
I am picking up wee fella's gizmo on sat - new tyres, will see if I can get a joining link as a short term fix if thats reasonable
Also does anyone have an exhaust for a f50 as mine has had all the baffles removed (loud pipes save lives but this is very loud)
Max rowdy installed...
... next up rear brakes
Also the wee gooseneck in the top of the carb rotates causing it to start...
Any tips or ideas?
Well I have it running.
Front and rear brakes work.
Quiet exhaust pipe fitted (for now)
Fuel petcock un clunged and fuel filter on the right way
Just went for a wee zip and its fun...
However it has a kxd pit bike engine and I dunno how to wire lights into it
I decided the headlamp and speedo mount looked pants and 3/4 of it was missing so I deleted it.
I made some flash harry mounts for the new light bucket and threw it on.
Next up.. what to do with the speedo.
I fabbed up a prototype mount out of scrap.
It kinda works so I will make a tidier one  this week
So I got a loom off ali express
Useless. Or maybe I am
Has 4 indicator leads. Thats good. 2 light up for each side. Happy days.
But they dont flash.
This is ok, there is a flasher relay , but nowhere to plug it in!
I think I have the light Hi/lo sorted, but there is nothing for brake lights or tail light...
I can rig a circuit for brake light, and will splice tail light into headlight circuit I guess.
/ling post
Question
Bike has AWFUL matte black paint over the factory red
Insulation tape will lift the black
Whats an easy way to remove the shit spray so I can prime and paint the frame satin paint?
Will paint remover and a water blaster be a good option?
Try paint thinners first, I have had success using it to remove a shit spray can job, if you are careful it may not effect the underneath paint otherwise its paint stripper
Great idea. I noticed blistering of black paint where I spilled petrol, Im dosed up on flue meds so my brain is slow today, did not even put 2 and 2 together! So might try a 3m scrubby soaked in petrol first as petrol is cheap(*er) than thinners
(Will wait until spring to paint, but I am curious to see the state of the red paint underneath)
On 13/08/2024 at 11:04, felixx said:
Question
The CRC Gasket Remover does a damn good job ripping at basically anything. Did it to my old Fa50 and used the water blaster after while it was still soft and got atleast 90% of the frame in 1 go
Lowered the headlight.
I think it looks better down there
New tail light arrived
I will mount it tomorrow night. Just waiting for my bar end indicators to arrive.
I registered her today. First time since 2008
Getting help from @mo999, (thank you good sir!)with the electron transfers tomorrow morning. Monday I will order golden boys and brake shoes, new front brake cable and lever, perhaps a shorter throttle cable then ride the wheels off her.
So @mo999 is a king!
Black widow has lights and stuff. I am impressed.
Next up is tyres, brake shoes and in the near future front shocks. I guess if Im doing fronts I should do the rears too.
Anyway here she is registred and legal
Well it goes well around town, tried riding her to work down QE2 drive - 80km/h stretch
She kept up with the cars and it was great!! but after 700m or so, bogged down and stopped
Pull over, find neutral, Kick and we are off
Did this 3 times
I am guessing she is drinking fuel faster than the bowl is filling, (@mo99 this was with a full to the brim tank)
I noticed the carb manifild has some funky welding in it, and the carb is on an angle because of this,( should it be level when riding)
Cheers in advance
