OS DRAG DAY 2024 DECEMBER 14th! ENTRIES OPEN
Does anyone know if any oil leakage is a no no? Common sense would say any oil leake would fail inspection.
I have a small drip from the front crank seal which causes a small noticible spot on the ground (20mm diameter puddle if I was to guess after a day of sitting) and wetness underneith.
Not going to be able to fix this in time but I have been told I need to try make it to one of these :P
this product works mint on rubber seals.  we use it in the jboats that have slight issues. unless you have rope seals but front seals typically arent.
Rislone Rear Main Seal Repair 500ml - 44240 - Risln | Repco New Zealand
Yeah I have looked at this kinda thing but have avoided it as it is a fresh engine, brand new seals but there must be odd wear on the crank causing this, replacing the seal with another new genuine part and moving the seal a but to get a fresh sealing surface hasnt helped.
all it does is make the seals swell.  not sure how it could damage a fresh engine.
ya engine builder sucks to have missed that, or you lol.
did you put the sling washer back in correct way?
Any fluid leaks are a no no at Meremere, and might get picked up at scrutineering.
If it gets missed in the morning check, the staff at meremere are quick to notice water / oil leaks on the staging and track area and will ask you to stop racing.
Rule of thumb is that if it leaks a drop from when you enter and exit the Scrut shed for inspection, then it will be a problem when staging, and yes we check.
If it drips after a few hours then its not so bad, but anyone who knows they have an oil leak whether it be slow or fast should spend 5 mins zip tieing some form of rag/nappy/tray under the problem area.
If the underside of your engine/x-member is a mess and covered in sludge we may fail you. Please take some time before the event to have a clean up under there.
I may make it if i can get a few days leave before the day to do minor stuff like remove the entire turbo system get a wof and refit it all..... i'll still bring the car if i dont i just wont be racing but wont be a wasted day.
Well I just entered so I better get my shit together and renew the WOF. As long I don't blow it up I'm confident I'll at least do one Hail Mary run! It'll definitely be at least a second faster top speed I reckon is gonna be faster then I've ever gone in anything.
  • Thanks 2
Remember you've got a trailer for the weekend too and a spare motor:compress:
  • Haha 1
Entries and payments updated. Keep them coming in!
# Name Username Vehicle PAID?
1 David Van Der Haas Roman 1983 Toyota Carina Y
2 Daryll Anderson Bigfoot
Mitsubishi lancer 1979
3 Gavin Gardner Gavin
1974 Ford capri gxl
4 James Boyce punkoutnz VW Golf
5 Nathan Davis
Honda Civic 1993
6 Michael jordan   Honda da6 1990 V8 Y
7 David Torckler Davet
Vauxhall magnum 1977
8 Liam Shanker
1990 Toyota MR2
9 Ned van Geffen Ned Model S
10 Adam western   Holden commodore VL 1988 Y
11
Logan Deadman
1990 Nissan 300ZX
12 David Parr Born_Disturbed
1985 Mazda Familia
13 Dan Cruden
1980 Mazda 323
14 Phillip Weston fuel
1991 Mitsubishi Galant VR-4
15 Mop Head Mop Head Honda Wave
16 Darren Szaszy
1990 Nissan Skyline GTS4
17 David Lee Munce Muncie Holden Commodore 2003 Y
18 Tim Herbert CrazyTim HSV R8 2001
