igor Posted August 14, 2025 Posted August 14, 2025 Bit like me mate. I have never needed to know how or why it works. I just use it. 1 Quote
shizzl Posted August 14, 2025 Posted August 14, 2025 3 hours ago, Bearded Baldy said: At this point it should be glaringly obvious that i know just enough about computers to not get electricuted, and that is about it. More than me then 1 Quote
Bearded Baldy Posted April 5 Posted April 5 Set up a second monitor to watch tutorials and have a play this week on freecad. Then immediatly couldn't be bothered when i realised an updated version had come out. Had a play around this morning though, managed to go beyond the basic 3d printer style stuff i had been doing. And made a revolving crank setup including the animation. Camera wouldn't focus with it turning.... Until today i could have made all the parts, but had absolutely no idea how to assemble them and set things up. MangoJelly Solutions is the guy i watched. Will try more of his stuff tomorrow and report. 5 Quote
Bearded Baldy Posted June 5 Posted June 5 Question for those clued up in solidworks, how do you take a 3d scan stl file and make it something editable. I have a scan of a solo seat cowl/cap for a motorbike, that i want to remove some lugs and add extra ones. And no idea how to do it. Quote
ThePog Posted June 6 Posted June 6 3 hours ago, Bearded Baldy said: Question for those clued up in solidworks, how do you take a 3d scan stl file and make it something editable. I have a scan of a solo seat cowl/cap for a motorbike, that i want to remove some lugs and add extra ones. And no idea how to do it. Solidworks is pretty shit for editing scans, you can basically only bring it in as a graphics body which cannot have operations performed on it. I have been told that fusion360 can make an stl in to an editable body, but I tried once and it/me was fucking useless. You best bet is Onshape, it imports an stl as an editable surface with certain limitations. But you should be able to create other surfaces and cut the scan with them, or do mutual trims etc. Just make sure the file isnt too big otherwise you will be there for a long time. I have found Bambu studio to be pretty good/quick at reducing scan size without losing heaps of detail. You just ignore the error when it is a meter bigger than the build volume. 2 1 Quote
Bearded Baldy Posted June 6 Posted June 6 Thabks for that. Doesn't help that i have no real idea what i am clicking on. Is a lot more user friendly than freecad though. Just have to unlearn some habits as it seems SW does a lot of things automatically that i had to learn to do myself in freecad. Next thing to learn is how to add a plane on a set angle to an existing sketch. Youtube should be able to help for that though. 2 Quote
ThePog Posted June 6 Posted June 6 45 minutes ago, Bearded Baldy said: Thabks for that. Doesn't help that i have no real idea what i am clicking on. Is a lot more user friendly than freecad though. Just have to unlearn some habits as it seems SW does a lot of things automatically that i had to learn to do myself in freecad. Next thing to learn is how to add a plane on a set angle to an existing sketch. Youtube should be able to help for that though. Are you trying onshape? If so getting planes in place is kindof more difficult than sw, although you can make a 3 point plane from points on the scan which can be useful for orientating things 1 Quote
Bearded Baldy Posted June 6 Posted June 6 The angled plane was for something else, not the scan. Have not tried onshape, i dislike the lack of privacy etc. Not that anything i do is cool or would be worth copyrighting haha. Current project is making a tablet mount for my daughter to clip on side of her bed. So i dont have to wake up early on weekends she can entertain herself. Onto mk3 so far, gets easier each time as i learn slowly from each round of cockups. 1 Quote
NickJ Posted June 6 Posted June 6 11 hours ago, Bearded Baldy said: Question for those clued up in solidworks, how do you take a 3d scan stl file and make it something editable. I have a scan of a solo seat cowl/cap for a motorbike, that i want to remove some lugs and add extra ones. And no idea how to do it. ooooh, this is a pretty painful operation that SW needs to address, i've found fusion to be easier so my complicated scan workflows happens there. Like pog mentioned, shrink them as much as possible in Bambu before getting into SW if you have to use it My usual go to in SW is import the mesh, use the mesh tools to set up some planes to then build around the mesh as a handrail. surfacing or directly editing a mesh sounds like all sorts of not fun with SW. 1 2 Quote
Bearded Baldy Posted June 24 Posted June 24 So i was about to try the ideas you guys mentioned. Figured a nice, relatively flat sided thing like a seat cowl would be good to learn the hows and whys of the program. Then i found a model on makerworld for rear speaker adaptors for an 80 series cruiser, but the guy had done it for some fancy 3 screw mounting speakers. So i dove into the deep end of reverse engineering this. Into this. And along the way learned how to do circular patterns and such to get the 4 speaker screwholes and 3 speaker cover slots all equally spaced. And how to set up custom planes to do the revolve cuts only where needed on the grill mounts. Took about 6 hours to do mk1 and mk2, made cockups in each one and didn't finish them so i could look back and remind myself what i got wrong. Started and finished mk3 in 2 hours and am just slicing it now to print a test piece. Tldr... should have sailed the internet seas and found a copy at the beginning of my cad journey. 6 Quote
ThePog Posted October 22 Posted October 22 Openpoly.dev https://github.com/eitan27/open-poly/blob/main/README.md This came up in my feed, might be worth a look. It seems to be an open source Fusion360 clone that runs in a browser with locally saved files. I had a cursory look and it seems to be pretty slick, did what i expected it to do. As much as I dislike Fusion360, if something like this gets to the point of real usability I would go for it. @Willdat? for your brats? 1 1 Quote
Willdat? Posted October 22 Posted October 22 1 hour ago, ThePog said: Openpoly.dev https://github.com/eitan27/open-poly/blob/main/README.md This came up in my feed, might be worth a look. It seems to be an open source Fusion360 clone that runs in a browser with locally saved files. I had a cursory look and it seems to be pretty slick, did what i expected it to do. As much as I dislike Fusion360, if something like this gets to the point of real usability I would go for it. @Willdat? for your brats? Yeah I have a fear with some of these Fusion clones that I invest the time in them, then Autodesk gets their legal team onto them and gets them wiped out. Mind you the licencing issues I've had with Fusion for students this year have been huge and have lead to a lot of downtime. Quote
ThePog Posted October 22 Posted October 22 11 minutes ago, Willdat? said: Yeah I have a fear with some of these Fusion clones that I invest the time in them, then Autodesk gets their legal team onto them and gets them wiped out. Mind you the licencing issues I've had with Fusion for students this year have been huge and have lead to a lot of downtime. Yea it seems so much like fusion that I wondered about the legality, but I do not know fusion well enough to know how infringy it might be. Quote
Hyperblade Posted October 23 Posted October 23 The other issue is that you build a model in them, and over time the software starts doing stuff which means it's not compatible when you export it with Fusion, then your truly fucked, as your only left with a product that is AI coded, so no real developers with real experience in maintaining it. And the legal side, even if they are legal, to defend any lawsuit takes lots of $$$ which most of these people creating these products will not have, or the time or energy, unless they were getting $ from the product, at which point it becomes an even bigger target for autodesk. I'm happy to wait a couple of years and see how it plays out. 3 Quote
anglia4 Posted October 27 Posted October 27 I have lost my access to Solidworks, so this week have been learning Onshape for designing some stainless chemical tanks. Some aspects seem great, some aspects don't seem to be able to do as much as SW. Overall I'm fucking hating life while I spend hours re-learning how to mate things together that would have taken me 30 seconds before. 2 1 Quote
ThePog Posted October 27 Posted October 27 13 minutes ago, anglia4 said: I have lost my access to Solidworks, so this week have been learning Onshape for designing some stainless chemical tanks. Some aspects seem great, some aspects don't seem to be able to do as much as SW. Overall I'm fucking hating life while I spend hours re-learning how to mate things together that would have taken me 30 seconds before. I can assure you that once you get over the hump you will understand why they have done it the way they did and that it is generally a better way than SW did it. Ping me if you need a steer, I am now 2 years in and probably know some things about it... 2 1 Quote
mjrstar Posted October 27 Posted October 27 I'm also using onshape, but starting from zero knowledge means I'm running Google/copilot on a second screen to learn lingo and short keys. 1 Quote
