  • Replies 43
Had a fairly productive day on the Moke although very little to show for my efforts in terms of equipment removed.
I started off by draining the coolant and then removed the radiator and expansion tank (weight savings 6.5 kg):
I then spent a good deal of time in the engine bay disconnecting all engine and gearbox related wiring and tucking the engine bay wiring loom out of the way. I also removed all of the rubber and hard fuel lines all the way back to the tank. The lines are so light that it didn't register on my scale so I'll bundle them with a few other small components for weighing purposes further down the track.
I then removed the upper engine stabilisers (weight savings of exactly 1 kg):
By close of morning all that is left to do before I can unbolt the subframe is to disconnect the brake and clutch hydraulic lines as well as the speedo cable. So that's my startign point for tomorrow morning.
  • Like 9
Got a gap between storms this morning, so busted out the pressure cleaner and a spot of degreaser and gave the front subframe a good bath. With years worth of gunk removed I was able to give the frame a good once over.
Gotta say it's had more hits than The Beatles over the years.
From the look of both front bump stops and their mounts I suspect old mate did a bit of bush bashing back in the day. On the one side the mounting face has bent up to the point where it's pressing on the base of the trumpet. A bit hard to get a decent photo of it but here you go:
In other news the front looks like it has already been fitted with HILOs. Pity I didn't spot that before I ordered a new set.
I'll try to bash things back into shape once I've got the donuts and trumpets out.
  • Like 8
I'm still doing a bit of homework on a gearbox alternative and current options have expanded to include Nissan Micra K11, Toyota Yaris or Ford Fiesta IB5. I'll update you all on that score when I am a little wiser.
In the mean time I've moved on to the next large piece of the puzzle.
Now, gather around boys and girls and Uncle Flash will tell you a story about batteries.
Okay, so the brief calls for 36 x brand new traction grade Lithium Iron Phosphate (LIFePO4) Prismatic Cells (100Ah nominal capacity) that will be connected in series to provide a theoretical  115.2 volts nominal and peaking at 131.4 volts.
My plan is to mount these batteries in two batches of 18 cells that will be contained in the side pontoons that the Moke is blessed with. This should keep the centre of gravity for this little go-kart as low as possible.
I'll start off by talking about the left hand side pontoon as this is the easiest side of the two.
As can be seen in the above photo this pontoon consists of two distinctive compartments. The back compartment has a fixed pressed steel side panel and previously housed the factory fuel tank. In native format this portion of the pontoon has no base to it. So the original fuel tank is lifted up into the pontoon from underneath and is held in position by two mounting bolts fixed through the top of the pontoon and an additional side bracket that bolts to the inner wall of the pontoon. The base gap measures 695mm long and 240mm wide and 260mm tall. This opening happens to be the perfect size to house this batch of batteries which will be housed in a custom fabricated battery enclosure made from 3mm steel plate. The battery box will slide up into the pontoon from underneath with a "hat brim" around the base of the box that will be secured into the factory lip that surrounds the opening.
This leaves me with the front storage compartment free on this side and I plan to install a lot of the new electronic equipment in this compartment.
Moving to the right hand side pontoon, the design becomes more complex.
As you can see in the above photo this pontoon is divided into 3 separate compartments. The front and middle compartments are for storage (typically jack, jack handle, wheel brace and tool roll) whilst the rear most compartment houses the original lead acid battery. Unlike the left hand pontoon these compartments all have a fixed floor with the only access being through the side openings. This makes life tough as the battery boxes with pre installed cells won't fit through the opening standing upright so need to go in side on and then get rotated by 90 degrees to the upright position. Also the compartments are longer than each opening so again the smaller boxes will need to go in one at a time and then get pushed forward or backwards into their final position. Now whilst this sounds theoretically feasible I'm not convinced that there is enough space to rotate the boxes once inside the compartment and I also can't see how there will be enough space to get the second box into compartments. But lets leave that aside for now and concentrate on how the 18 cells will be packaged in this pontoon.
So the front compartment will house a single battery box containing 6 cells which will easily fit through the opening when laid on its side. The middle compartment will house another 6 cells divided evenly between 2 boxes. Similarly the back compartment will house the last 6 cells split evenly between two boxes.
The above plan assumes that my certifier will be averse to cutting out the base of the rear and middle compartments as well as the dividing wall as this will be a structural change to the vehicle. I'd argue the point that from factory the left hand side pontoon is structured as so, but I don't know how much water my argument will hold. So for now I'm going to try to embrace the complicated multiple battery enclosure scenario for this side, unless I can prove that it is unworkable. In which case I'll argue for a single enclosure setup to mirror the left hand side pontoon.
So what's the next steps Flash ?
There is only one thing for it. More plywood aided design to create the 5 small battery enclosures for the right hand side pontoon and a quick game of Sokoban to see if they will actually fit. At the same time I'll mock up the single battery enclosure for the left hand side pontoon so that I have something to physically show my certifier when I talk through the structural design for the battery boxes.
So tomorrow I will make it so.
Thanks for reading.
  • Like 9
Rant time.
First world problem.
So Google's AI Assistant had a brain fart and provided me with the physical size for a 50Ah cell instead of that of a 100Ah LiFePO4 cell. As a result all of my battery box space calculations that were based on a 37mm cell width need to be re-calculated using the correct width of 50mm.
The Bastard !
So instead of getting into some woodwork, I spent the morning re-designing my battery enclosures and layout based on the correct measurements. Not necessarily a bad thing as its been pissing down with rain all morning here and its way more pleasant being tucked up in the home office than out in the elements.
The good news is that on paper my 36 cell array still splits into two packs of 18 cells in each side pontoon.
The bad news is that the area vacated by the fuel tank will only house 12 cells so I've had to move the remaining 6 cells to the front storage compartment in the same pontoon. Not a biggie. It just means that instead of the electronics having its own dedicated storage bay it will now have to squeeze into the remaining space with the 12 cell battery box.
Now that I'm left with no option but to run a split cell array in the left hand side pontoon I may as well embrace the concept of running split cell arrays in the right hand side pontoon rather than trying to convince my certifier to allow me to make structural changes. It means more work for me from a battery box fabrication point of view, but overall I'm happier with the "no structural modifications" approach.
Soz for the lack of pictures.
Righto, I've been spending quite a bit of time in my cave pondering gearbag options. When I last mentioned this a few days back I had sent the Toyota C-52 gearbox to the naughty corner as I just couldn't see how it was going to work out. I then set my sights on a gearbox out of a mid 90s Suzuki Swift or Holden Barina, but after doing a bit of research I discounted that as an option as they have a reputation for being a bit soft and I figured the high torque of an electric motor would destroy the thing in no time. I then toyed with the idea of a RS5F30A out of a Nissan Micra K11 and got some really good pointers from @fuzzy-hair-man who has done such a thing. I also spent a bit of time looking at @Adoom's Mini build as he is also dabbling with a K11 gearbag in his setup. Looking at the sub-frame mods done by both gents in order to get these to fit, I realised that I was in for a world of pain and all of that just to gain around 30mm which is the difference in length between a K11 box and my existing C-52. At the end of the exercise I've made an interim decision to persevere with the C-52. Reasons being I know its a strong box. Secondly I already have it in hand and if I'm going to have to make subframe changes anyway why not stick with a box that I know is up to the task.
So enthused with renewed vigor, I moseyed on out to the shed this morning to hunt down some solutions.
First thing I focused on was this little holding bracket for the outer sheaths on the gear selector cables:
That bracket is currently sitting hard up against the back of the subframe and is preventing the gearbox from shifting back by around 20mm.
So I quickly whipped the bracket off and nudged the gearbox back a tad like so:
And suddenly things aren't looking too far off from a driveshaft aligment point of view:
Right hand side:
And then left hand side:
Okay, it's still early days and I'll need to get my front wheel hub assemblies all mounted up and double check clearances by putting the suspension through its travel with everything setup for ride height. So I won't be breaking out the champagne just yet. But it's definitely a step in the right direction.
The next thing I checked was preliminary drive shaft lengths. Standard Leyland driveshafts measure approx 650mm end to end for the right and 610mm end to end for the left. Factory Toyota shafts measure 929mm end to end for the right and 610mm for the left. So quite a big variation in length for the Toyota setup. My rough measurements indicate that my right hand side driveshaft would end up being about 480mm and the left 450mm. Jeez, that's pretty jammy!
At the moment this is all achieved with no mods to the subframe. To gain some better driveshaft alignment I could look at giving the back of the subframe a little nip and tuck in the diff area, but I'll only know how much I can "pocket" the frame by once I've bolted the subframe back into the Moke.
So whilst this all sounds fantastic there is the elephant in the room that still needs to be addressed and that is the space left over within the subframe to house the HyPer9 and .................... ..... in a nutshell there is no way that bastard is going to fit.
Okay so that leaves me with no other option but to can the idea of running a HyPer9 and search out an alternative motor with a smaller footprint.
Stay tuned for the next exciting episode when Uncle Flash reveals his next harebrained scheme.
  • Like 8
Well a good day was had in the shed today.
Started off by completing the mockup of the adapter plate. In true life this will measure 25mm thick which will allow a few millimeters of air gap between the gearbox input shaft and the ME1616 output shaft inside the bellhousing.
Bolted her up and then more cutty cutty with my jigsaw and snipped a few short bits of wooden slats to the right length before nailing everything together to resemble a ME1616.
Here is a photo of the chubby looking ME1616 next to the svelte looking HyPer9 mockup:
Offered up the ME1616 to the adapter plate and realised I needed to countersink the bolt heads holding the adapter plate into position. So off came the adapter plate and I did that.
Second time lucky:
Before I go any further let me talk a bit more about the ME1616 mockup. In the wild a ME1616 measures 256mm in diameter and is 176mm long. However it is blessed with a square block that houses two 19mm barbed cooling outlets. This block measures about 40mm high. In addition there are the three high voltage cables that protrude about 25mm. In order to make allowance for the block and the cables I've given my mockup an overall diameter of 315mm. As for length I've increased my mockup from 176mm true length to a figure of 225mm. This is a whopping 49mm longer. I'm not sure exactly why I increased the length but it seemed like a good idea at the time. So what you are seeing in the above photo should be worst case scenario.
Okay so what's the verdict Flash.
Well I'll let some photos do the talking.
Left hand side clearance to edge of subframe:
And right hand side clearance to edge of subframe:
She's a bit of a tight one as the bishop said to the actress, but everything just squeezes between the subframe towers.
Flushed with success I chucked in my orange conduit "driveshafts" to check alignment and it's not great. Both leave the gearbox and point towards the rear of the car in order to clear the subframe openings. Not ideal at all. In order to fix that I need to shift the whole gearbag further back.
After scratching my head for a bit I've come up with a couple of options:
Step 1 is to temporarily remove these gear selector arms:
As you can see in the above photo the longer arm is hard up against the subframe and is preventing me from moving the gearbox back any further. If this solves the alignment issue I'm sure I can modify the arms to create permanent clearance going forward.
If this doesn't solve the issue then Step 2 is to try to rotate the gearbox in order to move the driveshaft outlets further back. I reckon I could get away with having a slightly clocked gearbox if this became a permanent option. I'll just give it more oil than normal which luckily I can do as the gear oil filler bung will be higher than standard as can be seen in the following photo:
If this doesn't work then Step 3 is to offer the empty subframe back up to the Moke to establish how much space I have between the back of the subframe and the steering rack. I'm hoping that there may be enough clearance to allow me to create a "pocket" in the rear structure of the subrame which would allow me to tuck the diff further back.
So that's where we ended up at close of day today. Tomorrow is going to be all about driveshaft alignment.
Thanks for looking.
  • Like 8
I didn't get as much time as I'd hoped in the shed today, but there was a bit of progress.
Overnight I decided to swap the order of things around a bit so first up was a test fit of the empty subframe.
I figured this wasn't going to be the only time I'd be putting the subframe back in, so decided to make a little cradle to ease the process. Started off with some timber decking offcuts and a few wood screws and created this little work of art:
Then I flipped it over and added a round recess that sits nicely in the cup on my trolley jack.
With that done I headed over to the Moke and admired the wide open spaces of the engine bay as it currently stands.
With the aid of my new cradle and my faithful old trolley jack I did a thing and nek minnit:
Grabbed my torch and headed under for a close look at the subframe. As I guessed there isn't much of a gap between the rear of the frame and the steering rack, but while under there I did spot something interesting. So it looks like the factory made a single subframe that they could use across both right hand and left hand drive vehicles. As a result there is a little bulge in the subframe on the left hand side that isn't in use. I've slapped some white paint on the area of interest just to keep me on track.
As you can see in the above photo there is a nice gap between the top lip of the subframe and the firewall in the painted area. The vertical face of the subframe in that area also has a nice bulge in it to accomodate the steering column to rack intersection if this was a left hand drive example. At this stage I'm not exactly sure if this will be of benefit, so the next step is to drop the gearbox down onto the subframe to see what is what.
It's at that stage that I had to call time in the shed.  So hopefully more tomorrow.
  • Like 8
Today was a bust in terms of shed time as I had to take a run into town for supplies, but whilst I was there I dropped by a local battery business. Apart from the usual 12 volt lead acid fair they also supply new generation cells for solar storage so I figured they may have the necessary supplier contacts to source my Lithium Iron Phosphate cells for the Moke. I'd printed out a copy of my spec sheet before leaving home so entered the business armed with that. Had a brief introductory chat with the owner before handing over my spec. He duly started to read through the docco and by the time he got to the bullet point that states "Cell Form Factor: Rigid Aluninium-Cased Prismatic Cell" I could see his eyes glaze over. Give him his due he soldiered on through the rest of the document and his final comment was " I wouldn't know where to start in trying to source these for you, but leave the spec with me and I'll see what I can do".
Yeah, nah I won't be holding my breath for a return call anytime soon.
After begrudgingly spending a few days sorting out the busted diff in the Thames I finally got back onto the Moke this morning. When we left off I had fitted the subframe back into the Moke to see if I was able to "massage" the rear of the frame to get much needed clearance for the diff on the Toyota C52 gearbox. Sadly no due to its close proximity to the steering rack.
First step today was to pull off the gear selector arms to provide some extra clearance:
I then lifted the whole lot up with my engine crane and dropped it in the hole:
Spent a bit of time faffing about to get my mockup driveshafts to poke through the factory holes in the subframe. This was the best I could get.
RHS:
And LHS:
Not ideal. And that was with the gearbox clocked at around 25 degrees.
Back in the engine bay things aren't looking to ahem ... flash.
Almost no space to fit the selector arms. Even with some heavy modification I might get the gear selector arm to work, but the gate selector doesn't have enough space to do its thing without modifying the firewall and possibly the top portion of the subframe rear.
The diff is also sitting hard up against the subframe as is the tail section of the gearbox casing and the starter motor ear is hard up against the firewall. Trying to create a working gap throws the driveshafts way out of aligment with the openings.
So the verdict is yes I could probably make it work with a bit of hacking, but before I go there I'm going to investigate another option.
My mate Grunty has a Gen 1 Sirion sitting in his paddock. According to what I've read Daihatsu used the same gearbag across their entire Gen 1 offering from the palty 3 cylinder up to the turbo charged K3-VET that pushed out 177Nm of torque, so it is more than capable of handling my Me1616 which peaks at around 120Nm. Unlike the Toyota C52 the Daihatsu unit has a more centralised diff that sits higher up in the casing. As a result it's sounding like a likely contender.
So the plan for tomorrow is to head on out to Grunty's place to pull the Sirion apart.
Short update with a potential show stopper thrown into the mix.
First thing this morning I gave the ME1616 mockup a little trim around the area occupied by the right hand inner CV. I had to shave a bit off my plywood adapter plate while I was at it.
While I was doing this I suddenly had a random thought. I know that the ME1616 has a large diameter due to the incorporated liquid cooling tubes. But what if the diameter is so large that the outer edge of the casing clashes with the right hand side inner CV joint ? ....... Gulp!!
More investigation is needed.
  • Sad 1
