Roman Posted October 7 Author Posted October 7 Thanks, it feels like I'm finally getting somewhere! Must be due for another engine blow up 🤣 1 1 1 Quote
BiTurbo228 Posted October 8 Posted October 8 Very nice. What does it do, cut ignition whe the clutch dips or something? Quote
Roman Posted October 8 Author Posted October 8 Yeah I have a different trigger setup for upshift or downshift. On upshift if throttle is over 10% and clutch is more than 70% depressed and foot not on the brake. it starts flat shift mode. So it does a full ignition cut, then you change gear, then when you let the clutch back out past 70% it considers it finished, and ramps ignition timing back into it. On a downshift. Conditions are that it needs less than 10% throttle, foot on the brake, and clutch in more than 50% Then it starts an ethrottle blip which raises the rpm to suit the next gear. There are some global lockout conditions like minimum vehicle speed and so on. After a bit more testing I think I still might need to do the 1-2 shift the old fashioned way. Or get a bit more practice with it. As I crunched the shit out of the box trying to do it too fast haha. But the 2-3 shift and upwards its great. The hardest part is defying your muscle memory telling you to pull your foot off the gas. 8 1 Quote
Truenotch Posted October 9 Posted October 9 It's just like driving on the sim! I don't think the J160 1-2 shift will ever be great. The ratio gap and shitty syncro kinda work against you there. I'm really interested to see how this goes at drag day. 2 Quote
Roman Posted October 9 Author Posted October 9 Yeah it's awful. Hopefully when I put in the 5.3 final drive, can just avoid using 1st at all at the drags. 2 Quote
Muncie Posted October 9 Posted October 9 Would love to know your average rpm for that 12l/100. Im getting 16.5l per hundred so very jealous Quote
Roman Posted October 9 Author Posted October 9 haha wow thats chugging it. Is that including hooning around? This is from logs of driving up and down the road "nicely" not quite highway conditions. This car currently does around 3300rpm at 100kph. Will be considerably worse once I've put the 5.3 final drive in. haha 1 Quote
yoeddynz Posted October 10 Posted October 10 That flat shifting tech etc is cool. 😃 The engine is sounding great. In the future, when I can be arsed, I'll remove my loom, un-pick my loom then add more wires to ecu etc and look to adding fbw throttle. For now I'll have to deal with a cable and sticky throttle (although there's this guy I know who was going to send me some of his special throttle jizz...) 1 Quote
Roman Posted October 14 Author Posted October 14 Ahh yeah I think I will just find a plastic bag to put it in, and send you the whole tin down. Will try get it to you before xmas Quote
