HumberSS Posted August 13, 2025 Posted August 13, 2025 Looks like you are sorted on the throttles but there are Sherryberg/FAJs weber copies that may have also been suitable and I reckon you could cut them up so they are effectively itbs and you dont have to rely on the weber spacing. Quote
Roman Posted August 13, 2025 Author Posted August 13, 2025 Yeah I had a look at those, was just a pain that they're in pairs like that. Was super stoked when I saw the 350Z setup pop up. Absolutely ideal. 3 Quote
Rhyscar Posted August 15, 2025 Posted August 15, 2025 Love how cheap the obx throttle were. No excuses with 51mm!! Way back, I heard the obx throttles were pretty rubbish for sealing throttle plate/setting up at low rpm. So could be worth including a port in the manifold for a remote idle speed control valve. Then you need to worry less about finicky adjustment. 5 Quote
Roman Posted August 15, 2025 Author Posted August 15, 2025 Yeah good point. My current set has balance tubes built in, but I'm not sure if this actually helps or hinders. I probably need to run all of the lines to the throttles in parallel, with equal length pipes. Where as my current setup was more like it was run in series on each bank. I suspect the cylinders werent getting air evenly from the PCV and would rob each other in slightly different ways. If these throttles are junk and dont seal or whatever, can probably rebore them and/or make some new throttle plates on the CNC. I just didnt really want to have to start from scratch, as figurnig out bearings/springs/sealing/etc is a big project in itself. TL;DR: Avoid multi bank engines, bloody nightmare. Haha 3 1 Quote
440bbm Posted August 16, 2025 Posted August 16, 2025 https://www.facebook.com/share/18umscW1B8/ any good for u? 52mm Quote
Roman Posted August 16, 2025 Author Posted August 16, 2025 Oh yeah i think those v8 ones are a much better outlet shape than v10 ones. However im already sorted, just waiting on the obx throttles to arrive. 1 Quote
Hyperblade Posted August 17, 2025 Posted August 17, 2025 Quote One quirk/feature with Fusion360, and I think solidworks operates this way too. Is that everything works on a timeline. Your model isnt just "how it is". It starts from the first thing you ever drew, then deleted, then drew again, and so on. To end up with the final result that you see. Which is really cool because you can roll back the timeline to make amendments or whatever. What's not so cool though, is that if you have been working on the same model file for say.... 3 years with zillions of things in it. Every time you make a change, it needs to reprocess all of these tasks. So it starts getting really sluggy. Isn't that what linked components are for (I haven't used them that heavily)? Quote I'm making some reasonable progress on my new design for the manifolds. It looks like metal printing the runners will be prohibitively expensive (about $1k for just runners) So will need to try something else that's more cost effective. I am thinking that I will get some alloy flanges cut. Then will get the runners printed from nylon, then wrap in carbon sleeve. Then alloy flanges at both ends so there's no bolts tapping into plastic and so on. I've been very impressed with brass heatset inserts (for throttle bodies), I would have thought they were viable in this case? And then use compression limiters + orings for holes where it bolts to head. Even if you do an alloy flange I would have thought you still should be adding in bracing underneath to stop it sagging. Hit me up if you want it printed out of PAHT or similar for cost of material + shipping (just set it up in slicer and I will hit print) 3mm wall thickness and you wouldn't even need to carbon wrap them. 4 1 Quote
Roman Posted August 18, 2025 Author Posted August 18, 2025 Yeah whatever it ends up, will definitely need bracing or it will crack in about 5 minutes flat from the unsupported weight. Even if it was metal. Thanks for printing offer! I'm still working through a few things and not quite sure how I'll make the runners yet. I'm tossing up where to just bit the bullet and get metal printed. Although in saying this, its insane how hot my throttles would get when the intake was fully metal. Like full 90 deg engine temp. On previous stuff with a nylon manifold everything stays fairly cool. 1 Quote
h4nd Posted August 20, 2025 Posted August 20, 2025 Hah, I just discovered I still have a Pick-a-part search running for Slush fund Priuii motors: Pick-a-Part Vehicle Alert: Toyota Prius NHW20 10/03-06/09 https://www.pickapart.co.nz/webpage/WebPage.asp?Ref=10381&VehicleID=217356&Location=pickapartconz Oh look! First time from Chch! 1 Quote
shrike Posted August 26, 2025 Posted August 26, 2025 Not sure if you've seen these guys playing with the 2GRFE in a Camry with a manual swap E351 Episode 1 Episode 2 Episode 3 Episode 4 Episode 3 was 254hp so not much more then what you got out of your 4GR (roughly 17kw more) and you've got 1L less displacement though I know Frankenstein motor-works has cracked 350hp (260kw) so 100kw more But 100hp per L isn't a bad number as long as we ignore @kpr 4age builds that are hitting what 100kw (130hp) per L? id argue he has more R&D into it however :p 1 Quote
Roman Posted August 26, 2025 Author Posted August 26, 2025 Revving to only 7k rpm hurts my feelings. Obviously there's a heap more they can do to make way better power though. Cool that they are doing iterative testing! Will check out some more of their vids. This is an overlay of how they make the power differently. I wonder how much a Camry weighs compared to Carina. Probably 1300-1400kg minimum. Quote
Roman Posted August 26, 2025 Author Posted August 26, 2025 6 hours ago, shrike said: I know Frankenstein motor-works has cracked 350hp (260kw) so 100kw more He's had 405 whp when on E85 with a fairly big effort build (FXE pistons, cams, valve springs, exhaust, etc) Then it was 385 or 390hp or something like that, on pump gas. Pretty awesome result! 100hp per litre at the wheels is a pretty good / achievable goal for a modern NA motor thats had some effort applied. Hopefully I can manage about the same. 4 Quote
h4nd Posted August 26, 2025 Posted August 26, 2025 1 hour ago, Roman said: 100hp per litre at the wheels is a pretty good / achievable goal for a modern NA motor thats had some effort applied. Hopefully I can manage about the same. I have every confidence you can do better than 1970 😁 ..."In July 1970 the SS version appeared, featuring a twin-carb, 40 PS (SAE) version of the ZM engine (ZM5) - a specific output of over 112 PS per litre...[15]" Quote
Roman Posted August 26, 2025 Author Posted August 26, 2025 ...At the wheels? Easiest way to have big hp per litre is to have the tiniest engine possible. 1 litre sport bikes are banging 200+ hp per litre. Quote
h4nd Posted August 26, 2025 Posted August 26, 2025 Naw, at the crank, and totally cheating. As you say, big per L numbers, but for a pittance total that can't overtake a loaded truck on a hill (ask me how I know) Yours is gonna sounds great, and be hilarious to drive. Looking forward to seeing it. 1 Quote
mjrstar Posted August 27, 2025 Posted August 27, 2025 if only there was a way to get petrol into the combustion chamber without injecting it into the port before the intake valve. like directly injecting into the cylinder. 1 7 Quote
shrike Posted August 27, 2025 Posted August 27, 2025 @Romanis there space to add injector ports directly to the head feeding into the intake port After he intake manifold? Quote
h4nd Posted August 27, 2025 Posted August 27, 2025 One other consideration: is there numbers on how much the air crams up around the outside of the turn? "D" looks like you'll be injecting into the densest part of the airstream. No idea if that's good/bad, and I guess you'd need to yarn with an aerodynamics Guru to see how big an effect that is, in practice. Just for your ponderment. Quote
Roman Posted August 28, 2025 Author Posted August 28, 2025 22 hours ago, shrike said: @Romanis there space to add injector ports directly to the head feeding into the intake port After he intake manifold? Hey actually this might be a plan. I have previously been considering adding them to the underside of the port. But too much other stuff in the way. Might be able to fit a double injector scheme on the top side. Will have a look on my spare heads when im back from a work trip. 2 Quote
Roman Posted August 28, 2025 Author Posted August 28, 2025 20 hours ago, h4nd said: One other consideration: is there numbers on how much the air crams up around the outside of the turn? "D" looks like you'll be injecting into the densest part of the airstream. No idea if that's good/bad, and I guess you'd need to yarn with an aerodynamics Guru to see how big an effect that is, in practice. Just for your ponderment. I doubt it makes any practical difference. If injector duty is at say 5%. Then all of the spraying happens when valves arent open yet anyway. With the echo i moved fuel rail from by the ports to entrance of trumpets and it made exactly zero difference. Apart from horrible bogging on transient throttle from big wall wetting area. 1 Quote
