HumberSS Posted August 7, 2025 Posted August 7, 2025 14 hours ago, kpr said: On the cover of hotrod magazine with the itb zoomies out the bonnet It's like it's telling you to run it on methanol 1 Quote
glen Posted August 7, 2025 Posted August 7, 2025 can we get different sized trumpets, its practically a can am car ? 5 Quote
kpr Posted August 7, 2025 Posted August 7, 2025 The uneven cylinder distribution is hurting my head just looking at that for reference the afr difference between the long at short on romans car was about 1 afr 1 Quote
shrike Posted August 8, 2025 Posted August 8, 2025 Will the inbetween trumpet size fit under the hood ir are you going to have to run them sideways via a 90 degree? 160kw isnt bad, room for more hopefully once you dial a few more things in, remind me how it compares to the 3s power? Quote
Roman Posted August 8, 2025 Author Posted August 8, 2025 My redtop 3SGE motor was 170-180hp wheel hp sort of range. So it's still a decent power bump, with a bit more rpm! The 3S ran to around 8300rpm on factory cams but not worth revving past that. Quote
Vintage Grumble Posted August 8, 2025 Posted August 8, 2025 Who won the sweepstake? @Nominal ? 1 Quote
shrike Posted August 10, 2025 Posted August 10, 2025 So glad @kprdidn't need the broom :) @Romanthe video of the stationary cooling system tests aren't loading? Are you thinking new intake that moves the ITBS more towards the cam covers similar to the 300zx engine bay style? 3 Quote
Rhyscar Posted August 10, 2025 Posted August 10, 2025 hmm interesting results and breakdown. Sucks about the transitions. Everything is a bit crammed. Remember an equivalent area of 42mm circle in oval won't flow the same due to more boundary layer. But I respect your keenesss to keep bonnet uncut (I faced the same dilema and spent years and years and thousands solving it lol). Morally, I feel wrong suggesting this, but logically, ITB's are the biggest packaging constraint. Going to individual runners and a plenum with single TB could make everything a lot easier? I'm sure it would still sound amazing at 10k. Great news on oil pressure. Holding steady up top when factory motors rev to circa 6k is great. Did you see comments from Ken on FB about hydraulic lifters going squishy and losing valve lift? Not suggesting it might be an issue, but it's a limitation of hydraulic anything. It would be interesting to see what the Kelford guys think about impact/acceleration rate of the cam and if 9-10k rpm may require solid lifters? I'm sure the Coyote people have researched it. Next move pulling the heads off and removing ex vvt then? 2 Quote
Roman Posted August 10, 2025 Author Posted August 10, 2025 13 hours ago, Rhyscar said: hmm interesting results and breakdown. Sucks about the transitions. Everything is a bit crammed. Remember an equivalent area of 42mm circle in oval won't flow the same due to more boundary layer. But I respect your keenesss to keep bonnet uncut (I faced the same dilema and spent years and years and thousands solving it lol). Morally, I feel wrong suggesting this, but logically, ITB's are the biggest packaging constraint. Going to individual runners and a plenum with single TB could make everything a lot easier? I'm sure it would still sound amazing at 10k. Yeah so compounding effects of that transition being gross. Because not only is it not even equivilent to a 42mm circle, but then some of the area cant be utilized because of the transitions. So it's probably equivilent of having a 38 or 39mm throttle on there which is dreadfully undersized! I've got nothing against single throttle, but the motor is probably going to run like absolute shit with a cam this size and vacuum from the plenum. As even at best case there's still a fair amount of overlap at TDC. Even with ITB cutting down the intake vacuum, this motor is absolute shit just off idle still. Although yeah that will improve a lot once the cams are retimed again. But big single throttle will likely cause drivability and low load issues. Not all of us have VTEC to make life easy, this is a garbage can FE head motor remember 😄 I must admit though, a single throttle setup sure does remove a lot of complexity and take away a lot of packaging issues. But it's annoying how a big single throttle can flow mostly the same air right down to 60% throttle (or whatever, depending on rpm and how big it is) Quote Did you see comments from Ken on FB about hydraulic lifters going squishy and losing valve lift? Not suggesting it might be an issue, but it's a limitation of hydraulic anything. It would be interesting to see what the Kelford guys think about impact/acceleration rate of the cam and if 9-10k rpm may require solid lifters? I'm sure the Coyote people have researched it. Next move pulling the heads off and removing ex vvt then? It's such a prick of a job to remove the chain and retime everything, that I'm not going to do it until I've got a really solid plan for everything that I want to do while the engine is apart. So probably going to be all at once: -port heads -Solid lifters (or something) -retime the chain It doesnt sound like much but its a huge amount of work that's very fiddly. So it's not going to be any time too soon. By nature of the hydraulic lifters, they cost you some amount of lift and duration. Some people have said you can just shim them up to say 0.2mm of their fully closed position, then you get the best of both worlds. But I'm not sure if that's a good plan. The 2URFSE is very similar to a 2GR apart from that it has solid lifters. I bought one to have a look, but they are totally different and wont just slot in. It probably makes more sense to first work on sorting the intake. As it potentially has bigger outcome and far smaller scope of work needed. Then stops me falling into project fatigue from having the car only just going then in a million pieces again. I've not actually driven it since having it tuned, because while exploring the delights of Northland NZ. I ignored @kprs good advice and basically went on an upper North Island tour of gas station food. I have had food poisoning for the last three days... 2 3 3 Quote
GARDRB Posted August 10, 2025 Posted August 10, 2025 10 minutes ago, Roman said: I've not actually driven it since having it tuned, because while exploring the delights of Northland NZ. I ignored @kprs good advice and basically went on an upper North Island tour of gas station food. I have had food poisoning for the last three days... Being friend's with @kpr's apprentice I know that the Mad Scientist knows more about gas station food than he does 4AGEs. Never eat the 20v of gas station food 1 1 Quote
h4nd Posted August 10, 2025 Posted August 10, 2025 30 minutes ago, Roman said: Quote Sucks about the transitions. Everything is a bit crammed. Remember an equivalent area of 42mm circle in oval won't flow the same due to more boundary layer. But I respect your keenesss to keep bonnet uncut (I faced the same dilema and spent years and years and thousands solving it lol). ...transition being gross. I think I dropped some details from the earlier discussion. Can you run big individual runners, and put an ITB at the outer end of each for easier packaging? Does that mess up vapourisation, resonance, etc? Quote
Roman Posted August 10, 2025 Author Posted August 10, 2025 No huge disadvantage to moving throttles I think. Here are some indy car throttles which have them way out in the bell! But yep I've made a bunch of concessions that I hoped would not affect performance, but was wrong. So hopefully that means some "easy" gains even if just by fixing up the intake. But yes @shrike I will probably have something that bends over the sides like that. I need to go measure everything up and then take note of what the overall length that I'm now aiming for is. Then I can start planning out how that's going to fit (or not) in the engine bay. I guess one good thing about having the intakes bend over the heads, is I could put the fuel rails facing vertially down above the ports. Might have some tonight or tomorrow to muck around with it a bit. In saying all this, I've not even driven it yet, so I'm keen to see how it goes! I need to spend some time getting the clutch adjustment right though, its horrible at the moment. Think it's overextending. 4 1 Quote
shrike Posted August 10, 2025 Posted August 10, 2025 2 minutes ago, Roman said: No huge disadvantage to moving throttles I think. Here are some indy car throttles which have them way out in the bell! But yep I've made a bunch of concessions that I hoped would not affect performance, but was wrong. So hopefully that means some "easy" gains even if just by fixing up the intake. But yes @shrike I will probably have something that bends over the sides like that. I need to go measure everything up and then take note of what the overall length that I'm now aiming for is. Then I can start planning out how that's going to fit (or not) in the engine bay. I guess one good thing about having the intakes bend over the heads, is I could put the fuel rails facing vertially down above the ports. Might have some tonight or tomorrow to muck around with it a bit. In saying all this, I've not even driven it yet, so I'm keen to see how it goes! I need to spend some time getting the clutch adjustment right though, its horrible at the moment. Think it's overextending. I am guessing even with the runners going over the cam covers youll get the same amount of heat-soak that the current setup does in the valley? I'm curious what length the Frankenstein motor-works ones are, thought he is single throttle https://frankensteinmotorworks.squarespace.com/shop/p/2gr-v1b-velocity-stack-intake-manifold https://frankensteinmotorworks.squarespace.com/shop/p/2gr-low-profile-velocity-stack-intake-manifold Quote
Roman Posted August 10, 2025 Author Posted August 10, 2025 Funnily enough those guys have just started stacks of 30mm spacers under that combo and finding gains everywhere. Again though the problem is trying to fit it all under the hood, and that's why it's initially compromised. Some of the guys have got big sections chopped out of mr2 engine bay lids and it looks like shit. Although, not really so bad in a mid engined car. Looking on the internetz it looks like they have a total runner length of around 330mm. My current short intake has a total length of around 300mm. So they're way off the mark to get that big power bump down to the lower rpm that they're running. This was from one of the guys adding spacers. Not much in it but they're probably not even close to the right length yet. There's 4 or 5 variations of the factory intake manifolds on 2GRs, and looks like some people have found that the one from the FXE engine goes really well. So it probably has runners shorter than usual, but still quite long compared to anything that's upright. In my case I cant really use any factory manifold as there are no injector bosses. Although I guess I could add some. But intake lengths arent going to suit what I want, so not much point I guess. Works for those guys as they arent doing much more rpm than factory. 3 Quote
Roman Posted August 11, 2025 Author Posted August 11, 2025 It looks like if I absolutely hog the shit out of these throttles at the base, I can only get them to be around the area of a 48mm circle. Which is probably about the absolute minimum that I'd want. But I dont think that would even work as I'm likely gonna be breaching through the walls of the throttle itself to do that. So might need to go back to looking at other options again. You know what they say though! 50th time right! These throttles are from a 500hp V10 so theoretically should work for a 300hp V6. But the difference is, it's transitioning to the right port shape for the V10 and absolutely not the right port shape for what's going on with mine. Quote
GARDRB Posted August 11, 2025 Posted August 11, 2025 is the port spacing sufficient for a cross ram intake? 5 Quote
Roman Posted August 11, 2025 Author Posted August 11, 2025 That's what I was thinking initially but its a bit more squeezed up with a 60 deg vee. But will see how it looks Quote
Truenotch Posted August 11, 2025 Posted August 11, 2025 2 hours ago, GARDRB said: is the port spacing sufficient for a cross ram intake? Nissan did it well: 6 Quote
Mop Head Posted August 12, 2025 Posted August 12, 2025 The E throttles are awesome! If I'm ever feeling a bit too smart I love to come and read your updates to put me back in my place. 2 2 Quote
