  • Replies 166
making some progress on the interior tonight
also picked up a Varis handbrake lever cover to go with the Varis shift knob I already had
  • Like 9
holes marked and drilled for clutch master cylinder
swapped on the manual brake master cylinder reservoir (which supplies fluid to the clutch master)
  • 3 months later...
Have been meaning to update this - I've had it back on the road since a few months ago, but only just got around to having the clutch pedal support bracket properly welded
Dash back in and that part now crossed off the list. Ideally I would want to drill out the gearbox mount bracket that's on the passenger side chassis leg and weld in the manual counterpart, but for now it's fine with a 20mm spacer between the gearbox mount and the gearbox itself.
I picked up some Evo 8/9 RS roll stopper mounts too which are slightly stiffer than the regular mounts:
I next focused my attention to the rear diff because when the wheels were up in the air it seemed to act like an open diff, not like the plate type 1.5 way LSD that it is. I knew that the USDM Evo 8/9 purposely had the LSD plates incorrectly stacked, but wasn't sure if that extended to the JDM wagons (or the JDM sedans without AYC) too.
So got to work pulling the diff:
And sure enough, the plates are incorrectly stacked - they have them plate, plate, disc, disc, plate <diff gears> plate, disc, disc, plate, plate
Looking so good man! Funny about the rear diff - I guess 1.5way LSD would be not very road-friendly for people buying from showroom floor.
How was the road trip experience? Cruise control etc all work?
what cruise control? :badgrin: It's basically bare-bones Lancer inside - no cruise control, no trip computer etc. I'm lucky to have auto climate control A/C and one-touch window controls haha.
road trip went well otherwise! Kind of miss being able to sit at 2000rpms at ~100km/h haha. Now it's 2800rpms at 100k right where the exhaust gets a bit droney, but at 3500rpms doing 140ish km/h the drone goes away.
  • Haha 1
Can't remember if I've said this before, but these are pretty much my idea of a perfect car. The things you've done to it makes it even more so.
Next mission should be demonstrating its practicality as a wagon and loading up a crew for a camping mish or some such. Rooftop tent?
I did take it camping once last year but it was to a campground that had cabins haha. I'm not really a fan of wagons with roofracks and roofboxes etc. There's a guy who splits his time between Toronto and Ottawa and has a black manual wagon that he wrapped in white Ralliart livery, but has a roofbox and in my opinion it kind of is overkill, especially when its empty 99% of the time. He did take his around Laguna Seca (sans roofbox) though which is epic
I had roof racks on the Diamante wagon and the whistle at highway speeds drove me nuts, so am not going to do that to mine.
I have been using mine for wagon duties lately - I saw someone nearby on FB marketplace selling an Evo wagon rear bumper for cheap so had to jump on it. Will probably keep as a spare if I never need it, or maybe sit on it and sell to Americans who want to convert their regular Lancer wagons into an Evo wagon.
2647F634-215D-4640-A68F-7809DE90CD5E_1_105_c.jpeg.483778d127db639faeb99b02b1b4d21f.jpeg
20 hours ago, mjrstar said:
It's looking great Phil, you must be stoked with how it's turned out, and I'm sure the trans swap has transformed the driving experience.
Definitely made it more engaging and more lively that's for sure - I just wish the 6 speed was geared a bit better haha. I wonder if anyone still sells a different final drive kit - you can easily sit at 50km/h in 5th gear and not labour the engine when you go to accelerate. I can easily overtake people on the highway without even dropping out of 6th gear haha.
Now I just need to find a MIVEC cylinder head and manual Ralliart gauge cluster to make it a fully complete manual IX wagon, but definitely nothing stopping me from having fun in it until then.
Also looking back the last page it seems I skipped progress pics of getting the manual box in completely. I actually had the manual box in and mounted by end of Nov last year before I came back to NZ over Xmas/new years, but as it was the first time dealing with a 'pull-style' clutch I wasn't 100% sold on where the clutch pivot arm was sitting in relation to the opening once the release bearing was supposedly clipped into the ACT 'monoloc' pressure plate. The only way I could verify was if I hurried up and fitted rest of the clutch hydraulic system, but by that point time ran out and I was back in NZ, and on my return it was still winter for a good couple more months and motivation was generally low working in a garage below freezing.
Thankfully the clutch did work correctly once I had the clutch pedal in and bracket temporarily mounted to the firewall with some large screws hah, it just had to hold for long enough to drive the car across town to have it welded properly.
I also had to fluff around with spacing the gearbox down about 20mm from its mount because the mount bracket off the chassis leg is different between the auto and manual body shells, presumably to accommodate the taller/larger auto transmission. I ended up removing the original studs from the box and replaced with M12x50mm bolts because the original studs don't have enough thread with the spacers inserted.
Everything else refitted - axles, flywheel plate, rubber bungs etc
Thank you for sharing all this info, I'm trying to convert my wagon to manual and this thread is extremely useful.
I was lucky enough to pick up an evo 8 shell here in the states to source all the parts.
Are you in either of the two Evo wagon FB groups? Here and here. There's also the Evo VII GT-A owners group here which I actually found more useful for the manual swap information.
You'll need some bits from a RHD donor like the rear transmission roll stopper bracket, brake/clutch pedal & clutch pedal firewall bracket because the LHD items wont work, unless of course you are converting your wagon to LHD using parts from the US Evo 8.
  • 8 months later...
