yetchh Posted August 8, 2022 Share Posted August 8, 2022 Hello, looking at a couple of the bluetooth dongles and apps. What are the better ones to get? I did look at a scan gauge but I don't want to spend that much to check a few things. Do most of them come with their own android apps or are there better combinations found on play store? Cheers. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 8, 2022 Share Posted August 8, 2022 I got one from either trademe or aliexpress, I'll have a look next time I'm near my tool box. It wasn't very expensive and it bluetooths to my phone. I downloaded 'car scanner' for free and it worked mint , found and fixed a cam angle sensor fault, and clears codes etc 2 Quote Link to comment Share on other sites More sharing options...
keltik Posted August 8, 2022 Share Posted August 8, 2022 The torque pro app has been pretty good for me. Got 3 or 4 Chinese obd adaptors and usually one of them will work... But not always the same one 1 Quote Link to comment Share on other sites More sharing options...
DB8-TypeR Posted August 8, 2022 Share Posted August 8, 2022 Same as above, I just got a generic ELM327 chinese thing and whenever Ive wanted to use it, it has worked (they do drain your battery if plugged in and dont use car for a couple weeks) 2 Quote Link to comment Share on other sites More sharing options...
Sunbeam Posted August 8, 2022 Share Posted August 8, 2022 I bought a LeLink obd2 from amazon. Bit dearer but leafspy on iPhone is fussy. Works mint and has survived a trip through the washing machine. I think android is better for apps. I have car scanner pro which has connection profiles for hundreds of models, but generally only newer cars. Does generic OBD stuff just fine. 1 Quote Link to comment Share on other sites More sharing options...
jessemk2 Posted August 12, 2022 Share Posted August 12, 2022 Do you want to watch what your cars doing live with the app running or just for checking and clearing codes? Quote Link to comment Share on other sites More sharing options...
yetchh Posted August 13, 2022 Author Share Posted August 13, 2022 Check what it's doing live, some sort of logging feature would be good to. Mainly for timing and afr. Quote Link to comment Share on other sites More sharing options...
jessemk2 Posted August 15, 2022 Share Posted August 15, 2022 I run a ultragauge it works similar to scan gauge but has way more options. little bit spendy but worth it imo Main reason I went with it is you turn your car on and it's on,don't have to open app then bluetooth connect You can set alarm alerts so if you go over pre set it will tell you Knowing you torque converter Temps trans pan temp intake air temp etc etc etc is pretty cool on the fly. It will also reads and clear codes Think there knock off ones for cheap but probably a lucky dip 1 Quote Link to comment Share on other sites More sharing options...
jessemk2 Posted August 15, 2022 Share Posted August 15, 2022 This guy does a in depth review on it https://youtu.be/faG27fK5BbY 1 Quote Link to comment Share on other sites More sharing options...
ThePog Posted September 13, 2022 Share Posted September 13, 2022 @mjrstar suggested I invest in a dongle to check for issues on the Wish. Looking on trademe there are $5.85 elm327 ones, $22 ones, etc. Are the super cheap ones even worth it or should i spend up large on the probably just as shitty $22 ones? Or go hard? Quote Link to comment Share on other sites More sharing options...
mjrstar Posted September 13, 2022 Share Posted September 13, 2022 I have an under $10 trademe unit and it goes hard for what it is. I did pay for the Ford specific software in the torque app to get a few extra parameters to show in my turbocoon but this is not necessary for scanning and clearing codes etc.. Edit This is what mine looks like.. Can't comment on other options.. https://www.trademe.co.nz/a/motors/car-parts-accessories/tools-repair-kits/meters-testers/listing/3760913695 1 Quote Link to comment Share on other sites More sharing options...
j.e.d. Posted September 14, 2022 Share Posted September 14, 2022 16 hours ago, mjrstar said: I have an under $10 trademe unit and it goes hard for what it is. I did pay for the Ford specific software in the torque app to get a few extra parameters to show in my turbocoon but this is not necessary for scanning and clearing codes etc.. Edit This is what mine looks like.. Can't comment on other options.. https://www.trademe.co.nz/a/motors/car-parts-accessories/tools-repair-kits/meters-testers/listing/3760913695 I see in that listing it doesn't work with iphone.. could that be the reason my aliexpress one doesn't seem to work? it looks like this.. Quote Link to comment Share on other sites More sharing options...
datlow Posted September 14, 2022 Share Posted September 14, 2022 My one wouldnt work with iphone, grabbed a old samsung phone and happy days.... It looks very similar 1 Quote Link to comment Share on other sites More sharing options...
ThePog Posted September 15, 2022 Share Posted September 15, 2022 I got this one. $5.85. It works fine, i got through 3 apps before i got one that seemed ok. GaragePro 2 Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 15, 2022 Author Share Posted September 15, 2022 What parameters do you get? I need to get off my arse and break the bank. Quote Link to comment Share on other sites More sharing options...
ThePog Posted September 15, 2022 Share Posted September 15, 2022 There was a list of like 15 groups, engine, transmission, hvac etc. Took 10 mins to connect to each and read it all. Might plug it into the carib tomorrow ti see if it works on that too. https://play.google.com/store/apps/details?id=com.zymbia.carpm_mechanic Quote Link to comment Share on other sites More sharing options...
