  • Replies 71
Finally got on to this job.
The torque converter that matches the gearbag  had a smaller diameter spigot that was also too tall so that needed rectifying in order for it to plug into the back of the v8. I couldn't just make a sleeve and slip over the existing spigot as it would have been fuckery so I did this instead.
First I had to find a chuck that held the TC securely, the one I had that had a base plate didn't cut it so after some rummaging in the shelves I found this random base of some other bit of gear which I turns out was damn near perfect, even had 3 evenly space slots close enough to the pcd of the bolts on the chuck. So I clocked that up and made some holes and bolted the whole sandwich together thus.
I then set the TC up and clocked that then milled the old spigot off.
  • Like 8
  • 8 months later...
