Marlborough Moped Melee - 4th, 5th, 6th March 2022 - Entry form now Live
- i5oogt -
  • Replies 340
3 hours ago, tortron said:
Nothing like a tauramanui meth head petrol station brawl to start your day
If that’s the photo of the Tauramanui petrol station, you’re in for a treat Sunday morning at Caltex Nelson. We might not do meth (in the carpark next door they definitely do), but we do a good coffee.
Yeah do that. I can repair the shroud, only wreckers with one is on holiday for 3 weeks.
Didn't heat seize on the next hours ride, I took the front engine cowl off, probably doesn't do anything much for cooling, but il at least see the piston shoot out
Ordered one from aliexpress anyways, it just has a nasty vibration
It can die when I say it can die
32 minutes ago, Beaver said:
Just cut the end of the strap off so you can untwist it,  and use a lighter to fuse the end. Problem solved
I'll have to do that.
But then I'll have the pointy end of that buckle pointing in.
The waistband is very thin. Less comfort.......
