jessemk2 Posted April 27, 2022 Author Posted April 27, 2022 I want a set of 18 maybe 19 inch superturismo if anyone see any for sale Quote
Alfashark Posted April 27, 2022 Posted April 27, 2022 Are you a member of this group? https://m.facebook.com/groups/1365983997079300/ That's DUBNZVW. There's always wheels being sold on there. Quote
jessemk2 Posted April 27, 2022 Author Posted April 27, 2022 Don't do social media just search tm now and again so probably missing out on the cool 5x112 rims Pic for thread 1 Quote
jessemk2 Posted May 19, 2022 Author Posted May 19, 2022 Been driving this most weekends and enjoying it I noticed the front brake pads were low Scored some ebc yellowstuff pads and installed last weekend they do work as advertised After searching tm for secondhand wheels pretty much everyday I've noticed I don't like any of them,want a more street/track looking wheel alot that come up are more flashy style rims So ordered some new 18 rims and tyres so once I pick them up I'll install the coilovers and lower to suit Probably only lower it 25mm so still have bit of ground clearance for b road hoonage 3 Quote
jessemk2 Posted May 19, 2022 Author Posted May 19, 2022 Ohh put some weather shields on it too! Same darkness as the tints so look pretty good. 3 Quote
jessemk2 Posted May 19, 2022 Author Posted May 19, 2022 Yeah, I wouldn't mind a mk6 r in white too! But can only really afford to have the one kicking about 1 Quote
jessemk2 Posted May 20, 2022 Author Posted May 20, 2022 Yesterday arvo the tyre shop txt me said my wheels and tyres are ready to pick up So impressed with the mechelin ps4 but my tyre guy managed to get me a set of the latest ps5 2 Quote
Alfashark Posted May 21, 2022 Posted May 21, 2022 Fuckin hell that's some serious boots. What's the price point between the 4s and 5s? Quote
jessemk2 Posted May 21, 2022 Author Posted May 21, 2022 Same price! But limited stock,think there trying to get rid of 4 stock first Rims are lite too 6 Quote
Alfashark Posted May 21, 2022 Posted May 21, 2022 I see a lot of Mk6 imports on those rims - Super light, but being so open they're begging for a big brake conversion behind them... Quote
jessemk2 Posted May 21, 2022 Author Posted May 21, 2022 Took it for a drive last night to test out the new kicks 2 Quote
jessemk2 Posted May 21, 2022 Author Posted May 21, 2022 Doesn't look gay at stock height but a smidgen moar lo will look way better I think 3 Quote
jessemk2 Posted May 23, 2022 Author Posted May 23, 2022 The tyre warning light came on when I was driving it the other night My initial thought was fuck there's no pressure sensors in the new wheels After a quick Google search on the side of the road they don't use tyre pressure sensors. It uses the abs/speed sensors and probably thought something was up because I changed wheel size. Did the reset procedure put handbrake on turn ignition on hold traction control button down hang tongue out to the left and it went away and hasn't come back yet. Quote
nzstato Posted May 23, 2022 Posted May 23, 2022 5 minutes ago, jessemk2 said: The tyre warning light came on when I was driving it the other night After a quick Google search on the side of the road they don't use tyre pressure sensors. It uses the abs/speed sensors and probably thought something was up because I changed wheel size. Did the reset procedure put handbrake on turn ignition on hold traction control button down hang tongue out to the left and it went away and hasn't come back yet. This happens to me every so often if driving through rain. I havent bothered enough to look into it further... Quote
jessemk2 Posted May 23, 2022 Author Posted May 23, 2022 After the quick read I did on side of road faulty sensor can do it aswell. Maybe you got a exposed wire or moisture getting into the sensor 2 Quote
Alfashark Posted May 23, 2022 Posted May 23, 2022 Another culprit for this - If you've got lower/stiffer springs and the car is capable of cocking a rear wheel around a corner, that pings the TPMS as well. Wheel size won't matter at all, as long as all 4 are the same diameter. Quote
thegreatestben Posted May 23, 2022 Posted May 23, 2022 Yeah if infrequently I just check tyres and reset. It does work though because I had a nail in a tyre the last time it pinged. Was about 20PSI in the tyre when I made it to the station, probably something like a 10psi difference when the light came on. Quote
jessemk2 Posted May 23, 2022 Author Posted May 23, 2022 1 hour ago, Alfashark said: Another culprit for this - If you've got lower/stiffer springs and the car is capable of cocking a rear wheel around a corner, that pings the TPMS as well. Wheel size won't matter at all, as long as all 4 are the same diameter. Well I can see this happening again once I lower it on the coilovers then I did find a few cases on a mk5 specific forum where it happened just by changing wheel diameter even though overall wheel/tyre diameter is minimal,just hope that's the case and it's not a sensor(never did it with the factory wheels over 6000ks) Quote
