evel Posted October 21, 2021 Share Posted October 21, 2021 Gidday OS GCs, I've been tasked with getting my bosses grandfather's L200 going after she's sat for a few years. I believe it had abit of a thrashing and developed an engine knock. I've cranked it over with the plugs out and I could hear it knocking so I didn't bother trying to actually get it running. Do these engine have a common oiling problem or a common component that fails? Also any links to manuals or engine info for the impending rebuild would be greatly appreciated. Cheers. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 21, 2021 Share Posted October 21, 2021 Yeah its a mitsi, they love burning oil so probably run a bit low then knock knock who's there 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted October 21, 2021 Share Posted October 21, 2021 might need to sign up to get access but here http://www.mightyram50.net/vbulletin/showthread.php/3513-Mitsubishi-Engine-Overhaul-Procedure-Manual i have a few workshop manuals here too normally the headgasket goes or the balance shafts go. bottom end is gona be cos its full of sludge probably 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted October 21, 2021 Share Posted October 21, 2021 im gona pull the buick v6, 700r4, and loom out of mine, he should put it in his 1 Quote Link to comment Share on other sites More sharing options...
