  • Replies 173
  • Tiger Tamer
    174
I gave the rear seats and door panels a good scrub today and managed to get the paint on. Dries real fast so I didn't have to wait really before putting it back together. Anyway a few pic's.
IMG_0968sm.thumb.JPG.123a3800a093095f4e48fda1406f3946.JPGIMG_0969sm.thumb.JPG.35f6618b5e6ff02cc475a64f6a805709.JPG
Here I was thinking I had it mostly done then realized I had not done the power steering. I had mounted the Toyota MR2 elec- hyd pump on the passenger side by the radiator so I needed to connect the hydraulic lines and wire it. I managed to get a pressure line from a MR2 which has the correct fitting for the pump and I had the correct fitting to the MX5 rack so I took them into the local hydraulic workshop and they put a swivel fitting in to connect the two systems together. Then it was just the return line and feed lines to do. I also connected a power wire and earth to the pump terminals to check the pump did work. All is well.
Then all I had to do was the wiring and I had a diagram to wire a MR2 pump into another car. So off I went into town with great hopes of finding all I needed to achieve my goal of securing what I needed to sort the wiring. YEAH RIGHT. Plenty of places have manual re-setting circuit breakers but not auto re-setting. And they have resistor type relays but not diode type. So at the moment I have it set up with a 50amp circuit breaker which will work for now but will be replaced with a 80amp when it arrives. The resistor type relay may be ok. A mate of mine who is a stereo tech says as it's only acting as a switch and it would work, and faster than a diode but probably not last as long. But probably should stick to the recommended diode type. Any thoughts welcome.
On 24/07/2026 at 15:24, Tiger Tamer said:
Hopefully it behaves itself.
Why did I say that. The Minx lived up to it's name this week.
Once we powered up the fuse box and had all the connecters plugged in the starter ran without the key turned, so he pulled the power supply wire on the ign switch. Even with all the relays pulled from the supplied fuse box it still would engage the starter. He seemed to think the fuse box that Kpower supplied, that the relays were not oriented in the same order as the diagram. So after going over the wiring that goes into the back of the fuse box to try and sort it out and testing other circuits and trying different things and still getting the same result.
One of the wiring jobs I had to do was wiring a 3 pin Deush plug for 12v ign feed (pin 1) an earth (pin 2) and a 12v trigger hit (start on the switch pin 3) So because the relay order in the fuse box was different to the diagram we decided to swap the 12v ign feed to pin 3 and 12v trigger hit to pin 1 and then after that all seemed well with the world. The dash lit up and the ecu light came on.
He downloaded the ecu base map and calibrated the DBW and we were ready to fire it up and that was when the day (night) turned to shit. It turned over slowly. On went a battery pack to the battery which is in the boot. No better so connected it to the engine and still no better and getting worse. Pulled the plugs and sprayed wd40 into the bores. Didn't help and getting worse. Now very slow. Pulled the valve cover and it all looked good there. There was oil up there which was good.
He said to get an endoscope to look down the bores. I think you can get them for your ph. Also drop the sump and perhaps check the bearings and bores. One of the plugs had a rooted electrode which could be a sign that all was not good in that cylinder.
A shame but I suppose there's some things here I should have checked when I got the engine that I didn't. Leason learnt I suppose.
  • Thanks 3
  • Confused 1
  • Sad 12
