  • Replies 160
  • Tiger Tamer
    161
I pulled the car out into the sunshine today and gave it a hose off while I am busy waiting. I did contact them, and they are busy waiting as well which is good as we are all busy.
I am quite tempted to lower the front valance and bottom of the front guards so that they cover the front X member. I don't think I will be destroying any structural integrity as the valance is more holes than steel. I think it would quite good with a mesh type grill there under the front bumper. I don't think it will be that hard to do.
I have done the flare on the passenger side so it gives clearance through full suspension travel which is huge, but I don't like it. It's fugly. I have been looking on lvvta site and suspension drop is measurement of 40mm is given but not compression. I see a lot of cars with flares so close to the tyre that I can't see how the don't rub. How do they get around this. Can I limit travel in compression with longer bump stops, stiffer rear springs, both?. I like the driver side flare as it fits nicely with the front flare but doesn't allow full travel in compression.
So, thinking about the amount of suspension travel I have in compression and the amount I had to flare the guards to accommodate it I thought I may as well find out if I am allowed to limit it some. So, I made up a cardboard template and sent it through to the certifier.  I got the ok to do it which is good. I made up the bump stop stop out of some 5mm box section I had and have tack welded them in place.
I suppose I should at least drain the oil out and remove the crown wheel cover before welding it fully. I have been doing a bit of googling the subject and some don't and don't have any problems welding on a diff with the oil still in.
  • Like 8
And still we wait for the electronics, engine loom etc to be sent. I do have the drive shaft being done as well so that's another thing I am waiting on, though no great hurry. I still have a list of to do's. I need to weld up and fit the passenger side seat base, find a new handbrake cable or try and free up the one I have, make up some more fuel line clamps etc. I probably won't pull the diff out and weld those bump stop stops yet until I have the car moving and the suspension height settles. The diff needs a new pinion seal and axle bearings so I will do it all then. Maybe even a Qaife lsd unit if the engine and gearbox are behaving themselves.
Anyway back to the waiting game.
As we patiently wait for the important expensive make it go paid for parts to arrive, I made up the passenger side seat frame out of 50x25x3 and 3mm doubler plates for the rear bolts. Front bolts use the original front mounts. Bolted in without any fuckery needed which is always a good way to end the day. Needs a bit more of a tidy up and a coat of paint and then bolt the seat to it. Then that will be another task ticked off the list.
I know you are probably sick of seeing pics of doubler plates and I am sick of making and fitting them, but I think that's it.
So, on unpacking it I discovered there are no instructions for the universal wiring loom in with the loom. The connecters do have abbreviated labels so it should all really be self-explanatory as I work through it. The Haltech comes with instructions and warnings of the order to connect and power up initially, so you don't cause damage to the ecu.
Anyway I had initially thought I would use the original loom until I decided to cheat so I had made a hole and flange in the firewall for the original gromet on the Honda loom which I managed to get off without cutting anything up. Though I was never going to get the connectors on the new loom through the 20mm hole in the gromet. I did have a piece of aluminium tube the largest connector would pass through ok so I made a few cuts in one end so I could get a taper and sprayed on some silicone and stretched it over then passed all the connectors and loom through and then slid the gromet of where needed and the tube back off the loom.
I didn't come with a new loom for the starter so I pulled the Honda one out and will use that. The new supplied fuse box will need to be mounted under the dash as it connects to the cabin end of the loom.
  • Like 9
NOT another bloody header pic I hear you say. How many times can he ftu you're thinking. How hard can it be.
So when I firstly made it (well secondly) made it, I made them too low, so I took 50mm out of the height of them which tucked them up and out of the way. BUT I must have changed the angle of the join I had to weld a little BUT didn't check the fit before welding them back up SO the flange on the end hit the old gearbox mount WHICH I trimmed BUT didn't give enough clearance.
Anyway, I knew it was something I would need to address and had been procrastinating about it. So, since I am getting close to start up and I was as far as I could get with the return line and wiring, I decided to remove the header and lengthen the drop in them by 30mm. Even THOUGH I had them in and out 100 times before, once I had all the accessory's etc on the other side of the engine they wouldn't come out without far too much jacking the engine up. So, I had to cut the outer tube off.
I have added another 30mm and tried them back in and now all is good so l have ordered some V band exhaust clamps that will make this tube removable which will make life easier in the future. Also bought another for the main exhaust so I ca make the tail pipe removable.
So I removed the engine mount and adjusted it for clearance for the bottom V clamp and refitted the engine mount and went to fit the tube, and of course it fouled the mount about halfway along its length.  Bastard. So out it all came again, and I had to cut the tube in two places and add a piece in at the top and weld it all up again. BUT not before trial fitting it and all became well in my world. Probably for a very short time but I will take it.
Of course, changing the drop length of the header means the rest of the exhaust didn't fit so I have started on that. The muffler sat a little low anyway and the tail pipe had an fugly bend in it so I will correct those two faults and add a V clamp into the tail pipe so it can be removed from the rest of the exhaust.
  • Like 8
