Rolr Posted September 23, 2021 Share Posted September 23, 2021 Wanting to get a 84 sigma converted what options r there Quote Link to comment Share on other sites More sharing options...
Bling Posted September 23, 2021 Share Posted September 23, 2021 Perhaps post what the specs are now and what you are trying to achieve. 2 Quote Link to comment Share on other sites More sharing options...
Sambo Posted September 23, 2021 Share Posted September 23, 2021 I've got $2 that says he wants to do an auto to manual conversion. Quote Link to comment Share on other sites More sharing options...
Bling Posted September 23, 2021 Share Posted September 23, 2021 I know with Toyota there are multiple options usually and some are better suited than others, situation / usage dependant. More info will lead to the best answers. Unless there is literally only one manual gearbag that will work in a sigma. I'd be surprised though. Could be weak gearbags worth avoiding, shit ratios, fitment issues and that sort of thing. Quote Link to comment Share on other sites More sharing options...
Thphantum Posted September 24, 2021 Share Posted September 24, 2021 1 hour ago, Sambo said: I've got $2 that says he wants to do an auto to manual conversion. I"ve got $5 says he wants to convert to Islam 1 1 Quote Link to comment Share on other sites More sharing options...
Rolr Posted September 24, 2021 Author Share Posted September 24, 2021 It’s for a 84 sigma gsrx 2ltr auto obviously I don’t no jak about this sort of thing lol just looking for advice cheers Quote Link to comment Share on other sites More sharing options...
tortron Posted September 24, 2021 Share Posted September 24, 2021 You are going to need to say what you want to achieve Bolt in I guess if you don't know much Asking for advice? That will get you - It's a mitsi, scrap it Quote Link to comment Share on other sites More sharing options...
Rolr Posted September 24, 2021 Author Share Posted September 24, 2021 Getting it converted to manual I no I Probably won’t find another sigmas for parts what other car gear box will fit or options? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 24, 2021 Share Posted September 24, 2021 @bigfoot is the resident Mitsubishi fiddler he may be able to help on interchangeability 1 Quote Link to comment Share on other sites More sharing options...
bigfoot Posted September 24, 2021 Share Posted September 24, 2021 Is it front wheel drive or rear wheel drive? You will need:(off the top of my head) Clutch cable (may be available new) Pedal box Cross member Clutch (available new) Crossmember Gearbox -probably narrow block, so sigma or early l200, l200 has different output shaft Driveshaft with yoke to suit gearbox Cert Quote Link to comment Share on other sites More sharing options...
Rolr Posted September 24, 2021 Author Share Posted September 24, 2021 12 minutes ago, bigfoot said: Is it front wheel drive or rear wheel drive? You will need:(off the top of my head) Clutch cable (may be available new) Pedal box Cross member Clutch (available new) Crossmember Gearbox -probably narrow block, so sigma or early l200, l200 has different output shaft Driveshaft with yoke to suit gearbox Cert Front wheel drive cheers thank you Quote Link to comment Share on other sites More sharing options...
bigfoot Posted September 24, 2021 Share Posted September 24, 2021 36 minutes ago, Rolr said: Front wheel drive cheers thank you In that case, i have little to no idea, more something @OSM Garage has experience with 1 Quote Link to comment Share on other sites More sharing options...
Bling Posted September 24, 2021 Share Posted September 24, 2021 Another thing worth noting, is that if you replace the current brake pedal with another, it will need a cert. Changing the pedal box from auto to manual parts triggers this requirement (brake pedal specifically). This is technically of course, lots of auto to manual swaps running around which need cert but will likely not be picked up. Just something worth knowing before carrying on. Easy answer is to just live the easy life with the auto, they aren't that bad. Quote Link to comment Share on other sites More sharing options...
Rolr Posted September 24, 2021 Author Share Posted September 24, 2021 2 hours ago, Bling said: Another thing worth noting, is that if you replace the current brake pedal with another, it will need a cert. Changing the pedal box from auto to manual parts triggers this requirement (brake pedal specifically). This is technically of course, lots of auto to manual swaps running around which need cert but will likely not be picked up. Just something worth knowing before carrying on. Easy answer is to just live the easy life with the auto, they aren't that bad. Cheers thank you Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted September 27, 2021 Share Posted September 27, 2021 I assume you are buying/have bought the white GSR-X on trademe. I have just completed a manual conversion on my FWD Sigma, but I luckily had a donor car to get all the bits I needed. If I was to do it again I would look to use a gearbox from a SB/SC/E33A Galant. These gearboxes dont use a vacuum actuator to select 5th gear. Its all cables. Make sure to get the selector cables to suit that gearbox. For the clutch pedal I think you will need one from a manual Sigma as I dont think the Galant is the same. Pretty sure axles are the same between auto and manual. Quote Link to comment Share on other sites More sharing options...
MaxPower Posted September 27, 2021 Share Posted September 27, 2021 I have a 1992 v3000 manual. Someone here may know if it’s gearbox will work on your engine Quote Link to comment Share on other sites More sharing options...
