chris r Posted July 24 Posted July 24 1 hour ago, Bearded Baldy said: How bad could they really be? https://www.aliexpress.com/item/1005008810612389.html Or i could use the standard xf falcon manifold, which will not look or sound as horny. Jenvey heritage 45s are the dream. Only one way to find out.... Id run legit injectors though not China spec ones (assuming it comes with them) 2 Quote
Bearded Baldy Posted July 24 Author Posted July 24 Yeah would not be using aliex injectors. I really only need 45mm throttle plates, as the xf manifold has a thin seperate section with the injectors in it so i could make an adaptor plate up between injector section and whatever ends up supplying the butterflies. Picture 6 small SU carbs with no innards. But bugger balancing 6 links. 4 Quote
VitesseEFI Posted July 24 Posted July 24 8 hours ago, Bearded Baldy said: How bad could they really be? https://www.aliexpress.com/item/1005008810612389.html Or i could use the standard xf falcon manifold, which will not look or sound as horny. Jenvey heritage 45s are the dream. I know a couple of folks using them. They are fine apparently….. 1 Quote
Bearded Baldy Posted July 27 Author Posted July 27 Good to know. These turned up today, the A pillar piece and the inner quarters were unpainted. So i grabbed the closest rattlecan and gave them a quick spray. 2 Quote
Bearded Baldy Posted July 27 Author Posted July 27 This is the injector plate for the efi falcon manifold. Looks easy enough to make an adaptor plate for, but what should i adapt? As a bare throttle body Jenvey recommended 45mm, so i am thinking something with a bore of 42 to 45mm should be sweet. Or i can take the sensible route and just buy a triple dcoe manifold as they are still available. Will be a long way off either yet. 2 Quote
Bearded Baldy Posted July 29 Author Posted July 29 Future reference post coming up, have been trawling for numbers to copy/paste Thu Oct 13, 2005 11:12 am I got most of these from MCNEWS.com.au, these seemd to be motor-side sizes but I cant really say... kawasaki: 2005 zx6r : EFI with 4 x 38mm oval throttle bodies 2004 zx10 : 43 mm throttle bodies 2002 zx6r : Fuel injection with 38mm throttle bodies 2002 zx12 : Fuel injection with 46mm throttle bodies yamaha: 2005 r6 : EFI with 40mm throttle bodies 2004 r1 : 45mm throttle bodies; with primary and secondary butterfly valves 2003 r6 : 38mm throttle bodies honda: 2006 cbr 1000 : PGM-DSFI electronic fuel injection, 4 x 44mm throttle bodies 2004 cbr 1000 : PGM-DSFI electronic fuel injection, 4 x 44mm throttle bodies 2003 cbr 600 : 40mm throttle bodies suzuki: 2006 gsxr 750 : 40mm 2003 gsxr 1000 : Keihn electronic fuel injection with 42mm throttle bodies 2001 gsxr 600 : 38mm Quote
Bearded Baldy Posted July 29 Author Posted July 29 Wed Nov 02, 2005 12:46 am hey all, here's another few which are also somewhat larger than 40mm, for the big V8 boys hayabusa 1999 en 2003 = 46mm 4x GSXR 1000 oude = 42mm 4x GSXR 1000 niew = 41>46mm 4x (dual throttle plate) 2002 Aprillia RSV mile = 51mm 2x Kawasaki ZX12r 2003 = 46mm 4x + vier pintle injectors tot 190pk Yamaha YZF R1 2004 = 45mm x4 + longnose 4 pintle (dual throttle plate) ducati s2r 1000 2005 = 45mm x2 ducati monster 620ie 2002 = 45mm x2 all duc twin valve 620 800 en 1000 = 45mm x2 ducati st3 en st4s = 50mm x2 suzuki DL1000 V-strom = 45mm x2 (dual throttle plate) triumph daytona 955i = 46mm x3 BMW e30 M3 = 46mm x 4 Quote
Bearded Baldy Posted July 29 Author Posted July 29 SUZUKI Make/Model: GSXR600 Year: -02 Number of Tb: 4 Inside Diameter: 38mm Center-Center (left to right from behind): 80-80-80mm Overall Length: 83mm Outside Diameter (intake): 44mm Outside Diameter (filter): 45mm Separate casting: Yes Injector Make/Model: Keihin KN4, 0J07 AAA A Flow Rate (45psi/100%): 240cc/min?, 13? Fuel Rail: Alu casted, Inside diameter 6mm (9mm in the ends) Additional Info: sec. throttles controlled by ECU. Make/Model: GSXR750 Year: -98, -99 Number of Tb: 4 Inside Diameter: 46mm Center-Center (left to right from behind): 80-80-80mm Overall Length: 91mm Outside Diameter (intake): 54mm Outside Diameter (filter): 54mm Separate casting: Yes Injector Make/Model: Keihin, Flow Rate (45psi/100%): 240cc Fuel Rail Inside Diameter: Additional Info: No sec. throttles. Make/Model: GSXR1000 Year: -02 Number of Tb: 2 Inside Diameter: 42mm Center-Center (left to right from behind): 80-80-80mm Overall Length: Outside Diameter (intake): Outside Diameter (filter): Separate casting: No (dual Tb?s) Injector Make/Model: Keihin, Flow Rate (45psi/100%): 230cc/min Fuel Rail Inside Diameter: Additional Info: sec. throttles controlled by ECU. Make/Model: GSXR1000 Year: -03 Number of Tb: 2 Inside Diameter: Tapers from 50 to 42mm Center-Center (left to right from behind): Overall Length: 90mm Outside Diameter (intake): Outside Diameter (filter): 53mm Separate casting: No (dual Tb?s) Injector Make/Model: Keihin, Flow Rate (45psi/100%): 230cc/min Fuel Rail Inside Diameter: Additional Info: Pic without secondary butterflies and fuel rail. Make/Model: GSXR1300 (Busa) Year: pre 2002 ? Number of Tb: 4 Inside Diameter: 42mm at injector end, tappered from 51mm at air horn end Center-Center (left to right from behind): 80-80-80 Overall Length: 90mm Outside Diameter (intake): 55mm Outside Diameter (filter): 53mm Separate casting: Yes Injector Make/Model: Keihin, Flow Rate (45psi/100%): ? Fuel Rail Inside Diameter: PA66-G35 Additional Info: no secondary butterfly Quote
deankdx Posted July 29 Posted July 29 On 27/07/2026 at 18:18, Bearded Baldy said: This is the injector plate for the efi falcon manifold. Looks easy enough to make an adaptor plate for, but what should i adapt? I can't remember if you've mentioned it or not, but the Iron head on the XC has a different intake to the alloy, has a water outlet under number 2 intake port. I bolted an alloy head on an iron head once, I was told it wouldn't work (it did, but the locating dowels needed to be be binned ..none in the block on XC) I didn't use this engine for long, but it was a good combo of pre pollution cam, probably higher compression with the mix n match.. but smoked and burned oil.. was one of the most powerful stock crossflows i ever had though. Quote
Bearded Baldy Posted July 29 Author Posted July 29 That is correct @deankdx, i have a complete xf efi engine with E2 head sittingnin the back shed. Will get a swap done on the heads one day but panelwork is more important at the moment. Can't hurt looking into morr options in the meantime though. The E2 chambers and the chambers on the ironhead will be near enough the same cc once i give it a massage with the grinder and get it skimmed. 1 Quote
Bearded Baldy Posted August 2 Author Posted August 2 Going through my notes i found these part numbers from when i last had the head off. Posting here as backup. 1 Quote
Bearded Baldy Posted August 7 Author Posted August 7 Well shit. Took the alloy driveshaft into work today to split the flange and yoke for painting and polishing, and noticed this once it was all apart. Seems it has corroded from the inside out. Have never seen it happen before. The guy i bought it from has been real good, i need to measure it up then he will track down another one. Good to know there are still good bastards out there. 6 Quote
Bearded Baldy Posted August 12 Author Posted August 12 Middle ports kind of kill the idea for an adaptor plate. 3 Quote
deankdx Posted August 12 Posted August 12 14 minutes ago, Bearded Baldy said: Middle ports kind of kill the idea for an adaptor plate. space to the shock tower is restrictive, use the EFI bananas and mount carbs above the rocker cover in place of the plenum?(might not fit under the bonnet and hot side intake not ideal. 1 Quote
Bearded Baldy Posted August 12 Author Posted August 12 Cheers Dean, i forgot the plenum came off the tubes... More to consider once daylight returns.... 1 Quote
