SOHC Posted May 20, 2021 Share Posted May 20, 2021 Dose anyone have one of those oil priming tools that you connect to the compressor to prime the oil pump and Gallary’s I could borrow? Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted May 23, 2021 Share Posted May 23, 2021 if you have a lpg bottle and fittings and hose and gauge you could make one Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 5, 2021 Author Share Posted September 5, 2021 I made one in the end from a $9 garden sprayer with the pressure relief valve tied shut with wire, was putting out 90 PSI 1 1 Quote Link to comment Share on other sites More sharing options...
Taistorm Posted September 6, 2021 Share Posted September 6, 2021 My old work had a small pneumatic double diaphragm pump with presslock attachment to various fittings depending on the engine. Was cheap and worked. 1 Quote Link to comment Share on other sites More sharing options...
