Crash's Ariel
crash
Got a little bit done on this, removed tank seat and oil tank.
bJZU6pp3opIkJFfdDulIMo41UsAyQO4J3ETOdoz8u7LnTSKFlVY4eN5Re5aqqH_APA6VeOF_QQn6yHZv2iEg3y3VnRxzo6HW_bsdCr9btRrf0i6FRgdD_Xcm8Xtu3rmAeA6ArHRg_-KN2utGimzXNxh8xrBuMHJD5q-84gU15WPuAnrDqomsWy8Sn2jVkzyr8A9Y1elwBr9f3peHYxLxu3yUyNWhq3zdE6f28dLmeI0cIPUM65bXbGOANgZzVl5QvHfZa17q6xWzB_rT5YQ599xqaXBXe6g2e9ZYo0M6pdq9n7pow5IkNYIIbk0Kb42y7Ci0h1IFGA_A5PNKs8ggF4JudR3oj38yEI_hMkhFe-Hh1tcRb18db54kD5M9C6NUCDCQby_0tYSzeaSRrxXThrW_EaWsatd9sDn8e1ZT4FmGjv8jbiTmOmSkdY31OnF_Je_5CX9u0YL51KbzuCN69UP7OY-jp4AZ5SG5jPPP1o89YwC0zXlxfd4GCGfJRX2DH9p8-NtSkuIvZ6N-VM8gYzHNkz6nx6vroGivf3akUeW1hGE4ygshCp979qedE7IJjxRioKqHBPnBhOjdygrwMr3hBUKEwJB5bdNPVmqoiEZF4G7QamC0mcVuLpthLreAx4jANQ_FhWNAJvMVkbOVapTAJ_7PfVZyXhYHOEdQE7afFBjhZlo5Hv_7RcjYL_qlXtZbq-LTMShNnhQpXxeJOw9N=w281-h211-no?authuser=0
which made it easier to see this bend in rear frame, RHS. Will have to get creative with steel beam, hyd jack etc and see if I can straighten. Otherwise off to old mate engineer with decent hydraulic press that I checked out for him a couple of weeks back.
nVB56M3m27HMxvZADEkgkd18pT425xrTzxxXKO00-S5feYTb4w0qqud-meYLEjhCg6-m-IOpDRFfHLBa6vWZhKYJ3T8zHy9UFtZAQdSLJfcEDSiNsQue680BEkDgf7gSiiShCH28sEWI8tkHQrRSmfe22g0_GlTwBFLQ9MvBgrOhYKMW4mewI1819Mvobw8_YrtzDUBeXnFOtsPFP5FeQzYZIkSF6UK4C3SMGxLE6YWUwSHvQHFOmINeZaI4izr0ZfG7w8sXIekwZqdogQYqsYnhM3Jo8-4oeRu5-hUTaGFIC0ZpobY0PuW8WGWzDhjdvyq6v2Io06r6XkKKL-W8F-8_h_lfwh0l-dUDArEI6BpIhg_dB9s9b_iwAAE0D4jeY9zKeLPohjPGtCwAQ71xg5o7dpVgkCq8TxUDaZYnBOFBWkOF0LDb9cxTApt2mym8gya0t_WY0dGIYXrD8PVLZl8hqd884w1lM7kbOjwy6bUAUp6RNMT_7hrFXlo9QqLr11Wyb2eYKqcf_cRnTzoV31jos5hN5O1hWFNgQW22nVIQKaTgofTXY_iq2t9l-65jLanQ0dJJ3SwgiGg9IirgmPO4tHQXVL9UCN2fZmYoz-9Zd34Vmukssn3P4jWbwqx90QmAm786Kbp9Ra4FbJcvD5CyAsBID-eNZRPdaiKAuSRePwshbjUCB93WyjUvFfnTK3FqW-WzOpVpSp9Kmr3p-I_2=w800-h600-no?authuser=0
BCUYphxh1st_H036dfckZ9ixXDpDBmgR3cT81YqfPlnViPtejxMyIcryFUUkct1fgYj4JqNQRp03hK3HL46lWFNLhCcz97xdZKAxUL7RMzIus3ncr7_eut40VL2lvrWEju-75PQS653XrRL5iITP__ZZxGUey4W-PyRPpiAFM2ZLWqiiZjowXaEt9XkZTh00K0Dgt_4VtQyVKqDCEKyoErpM4L-2K2i52Tm2oxcIJE-i-MwqAmTxiRBV4zBvakcsclNG58E5fiPqXM5XrD4wY7pfvDfSkNk3uoJWMLkZW_-QQTMREtXv9Z2K5306sFjrcaNdFWC_HqY_vaF9VggKqT7O_oZQ1lz_CMB6erIrJTzqE7Sx-29W3aW3zic1LgK3IvBLi9lOvzzMXgJVRj9Ne6lnfAb68GQlI1nf_TnHysPR7QvWNhEvOTRJ6GsQRtHJUwvehABNy5p0F3Vk6E_K-R7RewBxKWAQdoWBfhTvqVFQJzVp5DaugJHAnlLSldtmqoeD4_FpAPjrkRELjVzaIYHFDiTHe0G2V3L2HMqDPuX4XHo21r0-6sqO13qZnkH7i2xwWfCHwjXeSI-37JXWlbOyyPN8DYhg4Z2VHs0Az-wcxgsDdrPC9ysuKhzw6xsbC7yWDSqCMqan3lOAkLPMoTlFD4hM45nRZo7fVCw7IAVGc2Oq36J5bKAs3Zcpw75r947NfIhKN6HF6Yi79AkkE5qW=w450-h600-no?authuser=0
Other side nice and straight.
_d_3Z7mO5wmlI7ikx9JXB7cg-L6ailN-yYRKg36f6v5s395gGo16XmUNfPMlzJpKBUCl5dsO2jvo-gdK0ZqdlcNJy3ELdEsuuWZdytrmEmoSCl_V2d0r6GSdAutE2WQf5CsTY39iht0xCLRkCz3GjLULj2rGzMP5rKgrmwiGOWBFVWzmuqwOcxByFMz-ce_0hUOEcfBkzIR1s2MsSHUIKjc5Je1hzPlmL2qLq1Ok_9Ph7lZMwc0la8MIeVtGtUxt3B_OleQOcVlBJvMODgKC6BQRQ-2wd2yLSYXaqiUswREgA2BRFBSBEE5Y36Hx210TvmvQTMeRg3xlrmFppN_ltOxvuU651Brih_24n_OR6Gf9nG1uI_0_cvV6UPi7oSUQ19uc58HigNUwwmRr0_S3hCFZWqbpjL70A-TRrr0D4Mq-GMi_xoGTkkeaBuT04Ll28lt_Tm2BGjvCP5hj-NfSzVnvlGwiFhhM-8TWqEggT9ShatwUwlmmT9ZUDY-wJKonedvXwg7LNE6savu_PkWR5slHnuhegmeJjVB6DODrnKQzLZlfD2NQdnc8UJO-mowcFjYLeIWp61yNnI9gxtPoGlhA6NMi4xaq8oRRBA8jfD8xaM7m3wZHpmOX-ZSFfsIqAaepthyaqjvDO5YbS0UJ3Q6zNo2VPi18jmCAd6RDsujCYnhiid8mrrDjaA5ILbDX0P7JyFKm5zkdnIDKIpxr_Wuv=w800-h600-no?authuser=0
Nice bit of wear on rear sprocket, bloody country boys getting their money's worth.
fn0cgxXFxl2U9i_wsnQhf5lJmJ7D_ueabutbd8njOy2uHO_oqqReHXHO_srl5TltD_fDQCZC1GyDW4Q8UtfL3DZ3VXPtfDo5Mrf2joicnjgI37-GzqJ_NSvzdkVbX87zlMcdZ8a5NOq10Hmn2_1ca0mPloh5J_2VITyEUooEcQfR70U86rnKN5UOoPU1JuIaQdZwLGDvPmXljQCUOjJNO1byQl7FNb_i8kzDJ44E47P045tBNikAMGZk_mm9ptlZKmokzcYcB9BqqOkJxcZsfFwEgg8mTn8Zhdd8eih8fC15VFYdILJGWbYtdNuo4SScr0LVo961m9CWcgqqa3P2hhODl2CyF6_nRCuPi6SCs2Mz3FTVUiEUzw9iyLzABeA9zSvz93LIZ3EEwEtdzyDMbYwNYZJMZeSbVVW2nfcFcRTXzuozT83JMvOoydYmy-UB-QA_186StdhN53phhQZjOF2J4-j8AFaMUdWa8YEhyRD6IV7GdQpqHhDq5ieAKuz0n4jIb03Qj6j2CWhg18Ndh8uCiehEDhFWZVIlzOyPrl17-d6QtI1BXn2uI3UF_zcbf-W0YmmT_xVD7lVCvmavoLA4qpM69-f6inRyascDz28cidjswh57hguBjdUiVgw22cvN2ioQUqeFvJgt9TNRO-Ukybnt5Zv24-BMDtqNbj5H1wzbjL6g3da_O8Px23_qKVq6Hxok_jqky-4cXFdfMURj=w450-h600-no?authuser=0
Not too sure about pic troubles?
Thanks to Liz having a birthday and weather being too poos for work outside I got a bit of time to get into this again. Want to completely strip it down to figure out what bits to buy to save on postage. No doubt I'll forget a few bits but want to get on and get stuff.
So got the frame naked.
Bubble wrap underneath to catch the big lumps of grease/old dirt etc. Was not too bad to strip down, only used cut off disc once on a shitty bolt holding front mudguard. Front mud guard had been cut and overlapped to shorten, with hand beaten rivets.
Girders had a shit load of play in the top pin, once apart found that bushes were unsurprisingly well worn, one crumbled to sweet f all.
Luckily there had been a heap of grease pumped into the nipples so it all came apart fairly well.
This is the bit at top of the headset, small hole on right is mounting for main spring, large hole is where the centre of headset comes up through. Strange crack through it. No big drama as I have another one.
Handle bar has been welded to the mounts, behind this is a rubber bush. Probably welded to stop bar spinning, then got the ugly gutter bolts when welds failed. Yuk.
Headset bearings pretty good, lower race not perfect but once again I have another which looks better, new replacements available too, ex UK.20210607_163525.jpg.70729764323c21dfc44698c387e5bd14.jpg
5 hours ago, Raizer said:
Looks like you've linked to Google images in the first post, you can't hyperlink to Google, you can see them but pretty much everyone can't.
Thanks for letting me know, will repost pictures later.
