fuel Posted April 11, 2021 Share Posted April 11, 2021 Couldn't find an existing sharn thread so apologies if one already exists. You could just swap in the entire rear beam from that newer Galant into your V2000 and that way you gain the newer style brakes you can get parts for. Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 12, 2021 Share Posted April 12, 2021 The rear brakes are vented on the v2000 The galant ones are not Some v3000 have the same brakes so hopefully parts arnt to bad Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 12, 2021 Share Posted April 12, 2021 Should add i think the calipers have been relitted at some point in the past as the pistons and seals are in good condition. Compared to the fronts that are in very poor condition. Will be getting seals for the rear calipers anyways Quote Link to comment Share on other sites More sharing options...
MaxPower Posted April 12, 2021 Share Posted April 12, 2021 if you were closer I have a 1992 manual v3000 here not doing anything that would make a great donor, don’t see to many manual ones Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 12, 2021 Share Posted April 12, 2021 I had to try pretty hard not to just put a 6g72 in it when i got into the motor and saw how yuck the heads were. But being how rare a v2000 is i figured it would be kinda cool to keep it original motor. 3 Quote Link to comment Share on other sites More sharing options...
rich1179 Posted April 14, 2021 Share Posted April 14, 2021 On 12/04/2021 at 17:03, MaxPower said: if you were closer I have a 1992 manual v3000 here not doing anything that would make a great donor, don’t see to many manual ones Random request and sorry if I hijacked the thread but can you get a photo of the sump on the 3000? Thanks Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 24, 2021 Share Posted April 24, 2021 Do these have electronic controlled transmissions? My HiAce had the same symptoms, turned out to be leaking caps and a broken trace in the trans control. Wasn't actually slipping in first, the ECU wasn't shifting down below second gear so it felt like it was slipping, but manually shifting to L worked fine. 1 Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 24, 2021 Share Posted April 24, 2021 Yes they are a computer controlled trans This is something i looked into but couldnt find the trans computer .... requires further investigation Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 24, 2021 Share Posted April 24, 2021 32 minutes ago, JustHarry said: Yes they are a computer controlled trans This is something i looked into but couldnt find the trans computer .... requires further investigation In my HiAce it's actually in the ECU. My Pajero JR had a stand alone trans computer in the passengers kick panel (just remembered it had the same issue ha) 1 Quote Link to comment Share on other sites More sharing options...
M.H. Posted April 24, 2021 Share Posted April 24, 2021 34 minutes ago, JustHarry said: Yes they are a computer controlled trans This is something i looked into but couldnt find the trans computer .... requires further investigation Are you sure about that? I'm pretty sure it will be a hydraulic valve body Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 24, 2021 Share Posted April 24, 2021 1 hour ago, M.H. said: Are you sure about that? I'm pretty sure it will be a hydraulic valve body Yes im sure about that 2 Quote Link to comment Share on other sites More sharing options...
M.H. Posted April 24, 2021 Share Posted April 24, 2021 What model trans is in it? I have the workshop manuals for a bunch of mitsi transmissions Quote Link to comment Share on other sites More sharing options...
M.H. Posted April 24, 2021 Share Posted April 24, 2021 Does it have a TV cable? If its not adjusted correctly you won't have enough line pressure Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 24, 2021 Share Posted April 24, 2021 45 minutes ago, M.H. said: What model trans is in it? I have the workshop manuals for a bunch of mitsi transmissions So do i Quote Link to comment Share on other sites More sharing options...
M.H. Posted April 24, 2021 Share Posted April 24, 2021 2 minutes ago, JustHarry said: So do i Sweet, piece of piss to fix then 1 Quote Link to comment Share on other sites More sharing options...
fuel Posted April 24, 2021 Author Share Posted April 24, 2021 It's a KM175 trans with a TCU located in the centre console behind the radio on the top of the 'trans tunnel' bump. It does not have kick down cable, it gets throttle reading from the ECU's TPS and electronically adjusts line pressure to suit. No FWD Galant/Sigma/V2000/V3000 auto trans has a kick down cable, even the most basic carb models still had a TPS stuck on the carb feeding signal to the TCU. When I've seen similar era Mitsubishi TCU's fail usually you get funny things happening like losing reverse or torque converter lock up clutch being engaged right away which stalls the engine. If you unplug the TCU or if a sensor is faulty or missing it will go into mechanical fail-safe mode where line pressure is default high and you can only engage third gear or reverse mechanically and the torque converter just slips to make up for lack of other gears. Not engaging first gear and slipping 2nd could be a TCU fault though, who knows. I would pull it out and check the state of the caps - you'll find a FWD Sigma or V3000 TCU could probably be substituted in just fine (for troubleshooting purposes at the least anyway). 2 Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 25, 2021 Share Posted April 25, 2021 9 hours ago, fuel said: It's a KM175 trans with a TCU located in the centre console behind the radio on the top of the 'trans tunnel' bump. It does not have kick down cable, it gets throttle reading from the ECU's TPS and electronically adjusts line pressure to suit. No FWD Galant/Sigma/V2000/V3000 auto trans has a kick down cable, even the most basic carb models still had a TPS stuck on the carb feeding signal to the TCU. When I've seen similar era Mitsubishi TCU's fail usually you get funny things happening like losing reverse or torque converter lock up clutch being engaged right away which stalls the engine. If you unplug the TCU or if a sensor is faulty or missing it will go into mechanical fail-safe mode where line pressure is default high and you can only engage third gear or reverse mechanically and the torque converter just slips to make up for lack of other gears. Not engaging first gear and slipping 2nd could be a TCU fault though, who knows. I would pull it out and check the state of the caps - you'll find a FWD Sigma or V3000 TCU could probably be substituted in just fine (for troubleshooting purposes at the least anyway). I have a debonair here i can swap it out of 6g72 and auto I had the centre consol out yesterday and i didnt find a tcu. Only a power steer controller and the ac/heater computer behind that Quote Link to comment Share on other sites More sharing options...
fuel Posted April 25, 2021 Author Share Posted April 25, 2021 It's definitely there - close to the firewall behind the radio. Quote Link to comment Share on other sites More sharing options...
JustHarry Posted April 25, 2021 Share Posted April 25, 2021 Ok. Ill have a better look today. I suspect it is a computer fault just because when i manually select 1st it drives fine 1 Quote Link to comment Share on other sites More sharing options...
JustHarry Posted May 16, 2021 Share Posted May 16, 2021 On 26/04/2021 at 06:36, fuel said: It's definitely there - close to the firewall behind the radio. I did locate it today. Its a mare to get out of rhe v2000 I also took the debonairs one out. Turns out one of the plugs is different. Fml I guess I'll have to try something else Quote Link to comment Share on other sites More sharing options...
