Flash Posted February 11, 2021 Share Posted February 11, 2021 I know that a lot of the older manual Toyota gearboxes like the W and G series have bell housings that can be swapped out to suit a particular Toyota engine. Do the auto gearboxes like the A43D and A44DL have the same ability ? Quote Link to comment Share on other sites More sharing options...
M.H. Posted February 11, 2021 Share Posted February 11, 2021 1 minute ago, Flash said: Do the auto gearboxes like the A43D and A44DL have the same ability ? Yes as they are the same family of trans. You cant swap between the Axx series and A3xx Quote Link to comment Share on other sites More sharing options...
Flash Posted February 11, 2021 Author Share Posted February 11, 2021 Thanks for that. Would it be possible to put a A series auto box behind an engine that previously ran a G series manual gearbox ? Quote Link to comment Share on other sites More sharing options...
M.H. Posted February 11, 2021 Share Posted February 11, 2021 If Toyota made that engine family with the auto than yes. Its a fully hydraulic trans so is easy to swap Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 11, 2021 Share Posted February 11, 2021 Yeah what engine etc. Some will be harder to track down a bell-housing that others. People threw away the A43 etc autos like crazy but they are pretty good units, a overdrive and lockup version without computer control being the holy grail. Quote Link to comment Share on other sites More sharing options...
Flash Posted February 11, 2021 Author Share Posted February 11, 2021 Thanks fellas. The engine I want to put it behind is a Toyota 3Y out of a mid '80s HiAce van. According to some info I found on The Google it looks like these vans were equipped with either a A44DL or a A45DL. The box was top hung in the vans. @Spencer I seem to recall that you are Brissy based - correct em if I'm wrong. If you know of any available units in the Brissy area, please let me know. Ta Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted February 12, 2021 Share Posted February 12, 2021 From wiki A43D Four speed automatic without lockup torque converter. This transmission model is not electronically controlled. It is instead controlled by throttle position and also by a governor. Manufacturer designation: Aisin Warner 03-71 Applications (calendar years): 1981 Toyota Celica Supra 1982–1985 Toyota Celica XX 2000G/S turbo 1982–1985 Volvo 240 2.1L Turbo I4 (AW71) 1985–1991 Volvo 740 2.3L Turbo I4 (AW71) 1985–1990 Volvo 760 2.3L Turbo I4 (AW71) 1985–1990 Volvo 760 2.8L V6 (AW71) 1988–1991 Volvo 780 2.3L Turbo I4 (AW71) 1987–1990 Volvo 780 2.8L V6 (AW71) 1991 Volvo 960 2.8L V6 (AW71 – Australia only) 1991–1995 Volvo 940 2.3L Turbo I4 (AW71) 1981 Toyota Pickup 2WD 2.4L I4 22R (California emissions only, Federal emissions used A43) 1982–1995 Toyota Pickup 2WD 2.4L I4 22R/RE 1982–1995 Toyota Cab/Chassis 2.4L I4 22R/RE (flatbed, cube, motorhome) 1995–2000 Toyota Tacoma 2WD 2.4L I4 2RZ 1982 Toyota Crown Royal 2.8L I6 5MG 1 2 3 4 Rev 2.452 1.452 1.000 0.688 2.212 A43DL Four speed automatic with lockup torque converter. Based on A43D. Manufacturer designation: Aisin Warner 03-71L Applications (calendar years): 1983–1985 Toyota Cressida 1982–1985 Toyota Land Cruiser 1982 Toyota Celica Supra 1990–1992 Volvo 740 2.3L Turbo I4 (AW71L) 1991–1997 Volvo 940 2.3L Turbo I4 (AW71L) A43DE Four speed automatic with lockup torque converter and electronic controls. Based on A43D. Applications (calendar years): 1982–1987 Toyota Cressida 1995-2002 Toyota Granvia 1983–1986 Toyota Celica Supra 1992-up Suzuki Sidekick (4L30E) 1995–1998 Volvo 960/S90/V90 (AW30-43LE) A44D Four speed automatic without lockup torque converter. This transmission is electronically controlled by an electronic shift control module. Mechanically similar to the A43D. Applications (calendar years): 1989–1991 4Runner 2001–2004 Toyota Tacoma 2WD 2.4L I4 2RZ A44DL Four speed automatic with lockup torque converter Applications (calendar years): 1982–1991 Toyota Van 3-YE 1989–1990 Volvo 740 GLE 16-Valve (AW72L) 1991 Volvo 940 GLE 16-Valve (AW72L) 1992–1995 Mitsubishi Montero 5 Dr. V43 (03-72L)(V4AW2) 1992–1995 Mitsubishi L300 – (P04v) (P03V) 1992–1995 Mitsubishi Express – (P03V) (V4AW2) 1997–1999 Hyundai Galloper A45DL Applications (calendar years): 1982–1990 Toyota Van 4Y-E This document http://www.natpronet.com/trans/A40.pdf says Toyota Vans 1984-89 2WD 4-speed A44DL 3Y-E Quote Link to comment Share on other sites More sharing options...
Corbie Posted February 12, 2021 Share Posted February 12, 2021 Thanks Google. 2 Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 12, 2021 Share Posted February 12, 2021 Not many 80's auto hiaces around anymore. Best bet to just hit-up and call every wrecker in Australia that has old shit. All of them will have done 300,000km Quote Link to comment Share on other sites More sharing options...
M.H. Posted February 12, 2021 Share Posted February 12, 2021 L300s had the same trans as well so if you find a fucked Toyota one you can just swap bellhousings Quote Link to comment Share on other sites More sharing options...
Flash Posted February 12, 2021 Author Share Posted February 12, 2021 Thanks for the extra detail fellas. Much appreciated. I'll start hunting. 1 Quote Link to comment Share on other sites More sharing options...
