doullama Posted October 27 Posted October 27 G'day @kws, I was just trawling through your brilliant build thread again and see you've made up some prototype bolt on front telescopic shock mounts. I was looking at making some up many years ago but never got around to it, I don't suppose you have a drawing? I did have one I planned to work off but the computer it was on is long deceased. I see the mmoc are making kits but i imagine with freight etc on top of the 300 gbp for the kit it would be more sensible to make one up in the shed. Cheers! Quote
kws Posted October 28 Author Posted October 28 11 hours ago, doullama said: G'day @kws, I was just trawling through your brilliant build thread again and see you've made up some prototype bolt on front telescopic shock mounts. I was looking at making some up many years ago but never got around to it, I don't suppose you have a drawing? I did have one I planned to work off but the computer it was on is long deceased. I see the mmoc are making kits but i imagine with freight etc on top of the 300 gbp for the kit it would be more sensible to make one up in the shed. Cheers! I'm still working on the setup I was making. Ive had an engineer laser cut and weld up the brackets for me, all I need to do now is turn down the lower arm clevises for a longer stud and then I can fit them ( waiting on some tooling for my lathe). I do plan on eventually offering the kit for sale locally, which should be cheaper than the UK kit. Looks like they've increased their price 100gbp for just the kit, plus I was quoted another 150 gbp for shipping; hence me going down this silly path of making my own. 4 Quote
doullama Posted October 28 Posted October 28 Brilliant, it'll be interesting to see what it actually does for the handling/roadholding. Seems everyone who has fitted telescopics to these things really rates it as worthwhile. 2 Quote
kws Posted October 29 Author Posted October 29 Ive heard nothing but good things about fitting telescopics, so im really looking forward to giving it a shot. My Marina in particular seems to roll a lot in the front end, even with thicker oil in the shocks, so im hoping to stop that and make it so i can actually carry some speed around corners without worrying if the front bash plate is going to hit the ground. 3 Quote
doullama Posted October 29 Posted October 29 Mine doesn't really roll at all, the vans do have a different torsion bar. The lever arms just suck, hit a pothole etc halfway through a curve and it gets a bit wayward. I took the van to cape reinga once and on the last 10kms or so of corrugated gravel the lever arms just couldn't keep up, literally couldn't be steered at above 25kph! I reckon this marina based merlin bottom bracket is a good idea, sandwiched between the lower arm halves and as far outboard as practicable. 2 Quote
kws Posted October 30 Author Posted October 30 My setup, and i think the UK kit is the same, has the lower bracket inline with the lower clevis, so about as far outboard as you can get. Some of the aftermarket kits from the period had the shocks way inboard, which didnt seem ideal. The Marlin setup is good, but uses something like a Mini top mount, so cant easily be adapted to the Marina. I do wonder if the big old OHC E-Series contributes to my wobbly handling in the front. Its very tall and quite long This was my last prototype 4 Quote
BiTurbo228 Posted October 30 Posted October 30 That's looking good! There will probably be a bit of torsion going on with the mount offset like that, but it'll probably be alright if the tie rod is a solid mounted connection to the main arm. If it's a bushed connection then you'll probably put a fair bit of continual wear on those bushes. Not necessarily something to be that concerned about, just worth bearing in mind that they might need replacing more often than usual. Oh, and the E-Series being a good 20-100kg* heavier than the B-Series might have something to do with the handling. *Rather wide estimate there because the only information I have on the weight of an E6 is that it's '~20kg heavier than a B-Series and ~20kg lighter than a C-Series'. Unfortunately, a B-Series weights about 150kg and a C-Series weighs about 270kg, so either the E-Series is the only known example of Schrodinger's Mass or someone's telling porkies. Considering it's trying to find the weight of an engine from blokes on the internet, I'm going to guess it's the latter. 1 Quote
locost_bryan Posted October 30 Posted October 30 7 hours ago, BiTurbo228 said: That's looking good! There will probably be a bit of torsion going on with the mount offset like that, but it'll probably be alright if the tie rod is a solid mounted connection to the main arm. If it's a bushed connection then you'll probably put a fair bit of continual wear on those bushes. Not necessarily something to be that concerned about, just worth bearing in mind that they might need replacing more often than usual. Oh, and the E-Series being a good 20-100kg* heavier than the B-Series might have something to do with the handling. *Rather wide estimate there because the only information I have on the weight of an E6 is that it's '~20kg heavier than a B-Series and ~20kg lighter than a C-Series'. Unfortunately, a B-Series weights about 150kg and a C-Series weighs about 270kg, so either the E-Series is the only known example of Schrodinger's Mass or someone's telling porkies. Considering it's trying to find the weight of an engine from blokes on the internet, I'm going to guess it's the latter. I believe the E-series is a little shorter than the B-Series, but taller. These are the weights quoted from the factory workshop manual E4 151kg + Triumph 4-speed 21kg = 172kg E6 175kg + BW 3-speed 41kg = 216kg MGB 173kg + 4-speed o/d 52kg = 225kg 1800 TC should be 173kg + 21kg = 194kg 1 Quote
kws Posted October 30 Author Posted October 30 7 hours ago, BiTurbo228 said: That's looking good! There will probably be a bit of torsion going on with the mount offset like that, but it'll probably be alright if the tie rod is a solid mounted connection to the main arm. If it's a bushed connection then you'll probably put a fair bit of continual wear on those bushes. Not necessarily something to be that concerned about, just worth bearing in mind that they might need replacing more often than usual. Oh, and the E-Series being a good 20-100kg* heavier than the B-Series might have something to do with the handling. *Rather wide estimate there because the only information I have on the weight of an E6 is that it's '~20kg heavier than a B-Series and ~20kg lighter than a C-Series'. Unfortunately, a B-Series weights about 150kg and a C-Series weighs about 270kg, so either the E-Series is the only known example of Schrodinger's Mass or someone's telling porkies. Considering it's trying to find the weight of an engine from blokes on the internet, I'm going to guess it's the latter. The lower mount is pretty solidly mounted and the tie rod is solid mounted to the arm, and the design based off the later Ital brackets that BL made (its gotta be good if they designed it, right? 🤣). 1 3 Quote
doullama Posted October 31 Posted October 31 What Kyb shock is that, mini front? Would definitely be nice to use a common shock rather than an esoteric spax etc. Quote
kws Posted October 31 Author Posted October 31 55 minutes ago, doullama said: What Kyb shock is that, mini front? Would definitely be nice to use a common shock rather than an esoteric spax etc. They need to be quite long, so they're from a VW Beetle/Ghia. Quite reasonably priced and available locally, which was a big consideration when I was designing the kit. Spax and the likes appear to do adjustable options too, for a cost. 3 Quote
BiTurbo228 Posted October 31 Posted October 31 On 30/10/2026 at 19:43, locost_bryan said: I believe the E-series is a little shorter than the B-Series, but taller. These are the weights quoted from the factory workshop manual E4 151kg + Triumph 4-speed 21kg = 172kg E6 175kg + BW 3-speed 41kg = 216kg MGB 173kg + 4-speed o/d 52kg = 225kg 1800 TC should be 173kg + 21kg = 194kg Ah now that's useful! I'm a little suspicious of the 21kg Triumph 4-speed. I've weighed a 3-rail at 34kg and a single rail at 28kg, but to be honest the rest are relatively believable. On 30/10/2026 at 20:38, kws said: The lower mount is pretty solidly mounted and the tie rod is solid mounted to the arm, and the design based off the later Ital brackets that BL made (its gotta be good if they designed it, right? 🤣). Yeah sounds like it should work (because of looking at it, not because the Ital is a pinnacle of engineering excellence...). 1 Quote
