J.e.d.’s 1963 Galaxie 500 hardtop
j.e.d.
  • 7 months later...
  • 8 months later...
Guess I should try getting this thing road worthy if I’m to take it to drag day..
Finally managed to install the rebuilt PS pump.. had a bent pin I believe.
When I went to install I noticed how far out of alignment it was so that may have had something to do with it failing, so I’ve shimmed it out and it’s pretty much bang on  in line now.. was about 4-5mm out originally and I noticed the pulley on the pump wobbling prior to the rebuild, hopefully this will help it all last a long time to come.
Last thing to do was to put in the new filter, unfortunately I ordered the new one off the code of the old one without realising the old one wasn’t correct.. needs to be 2.5” diameter to fit in the cup in the base of the reservoir, but this one is 3” so sits on top.. probably not a big deal as the spring holds it down, but I’d prefer the correct filter so I’ve got it ordered and should turn up next week.
Getting there..
  • Like 9
  • 4 weeks later...
  • 3 months later...
  • 10 months later...
