l200 Posted January 30, 2021 Share Posted January 30, 2021 hey guys i was wondering if you had and ideas on what will fit in my l200? have got a 4g32 engine in it but it dropped a ring and now toast, will i have to get new motor mounts if i change or the same ones? its a 2wd column shift 4 speed. thanks Quote Link to comment Share on other sites More sharing options...
tortron Posted January 30, 2021 Share Posted January 30, 2021 Obviously you are going to swap in a Buick v6 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted January 30, 2021 Share Posted January 30, 2021 you can also check out www.mightyram50.net to see what the americans do. theres plenty of v8 swaps. theres some holden v8 ones floating around nz, its a little tight but fits with minimal cutting. Theres probably plenty of newer stuff you could put in now days. depends what you want out of it Quote Link to comment Share on other sites More sharing options...
M.H. Posted January 30, 2021 Share Posted January 30, 2021 4d56t would be an easy conversion Quote Link to comment Share on other sites More sharing options...
M.H. Posted January 30, 2021 Share Posted January 30, 2021 rv8 would go good too Quote Link to comment Share on other sites More sharing options...
