KKtrips Posted December 22, 2020 Share Posted December 22, 2020 Has anyone bought and used one of the generic wiriing kits (from Painless Wiring etc) Anything I should know before buiying and I'm thinking for the ol Commy, 21 ciircuits should be plenty?https://www.summitracing.com/parts/prf-10102 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted December 22, 2020 Share Posted December 22, 2020 @vk327 Quote Link to comment Share on other sites More sharing options...
vk327 Posted December 22, 2020 Share Posted December 22, 2020 Just now, flyingbrick said: @vk327 i was just reading this post, stick to the known brands like painless there are some cheap knockoffs around, they are the easiest way to do a rewire from scratch only thing worth addding is relays for heavy loads like headlights, grab a factory diagram for the commodore and give it a go (dont just cut the old loom out may need to trace out heater and wiper wiring) 2 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 22, 2020 Author Share Posted December 22, 2020 3 minutes ago, vk327 said: i was just reading this post, stick to the known brands like painless there are some cheap knockoffs around, they are the easiest way to do a rewire from scratch only thing worth addding is relays for heavy loads like headlights, grab a factory diagram for the commodore and give it a go (dont just cut the old loom out may need to trace out heater and wiper wiring) I have fully removed the wiring loom, so nothing to "cut out" (it's still all one piece at the back of my lockup) Did you get a generic one or the GM keyed column version? Quote Link to comment Share on other sites More sharing options...
vk327 Posted December 22, 2020 Share Posted December 22, 2020 I havnt used one myself, i tend to build my own custom ones. my vk is custom front half re wired all moved under dash, the generic one would prob be best as the us gm stuff is s bit different, would recommend getting a decent open barrel crimper and brass terminals, de pin and reuse the connector housings for the like of ignition switch headlights etc inside the car i normally use basic unsealed connectors, under car/engine bay I prefer deutsch connectors, weatherpack is another good option for sealed connectors 1 Quote Link to comment Share on other sites More sharing options...
ThePog Posted December 22, 2020 Share Posted December 22, 2020 I got this one for the truck, probably an earlier version as it looks a bit different but same same really. http://www.kruzinkustoms.com/view/parts-for-sale/electrics/21-circuit-wiring-harness-kit.php Basically it was ok. No headlamp relays though, I added those in. 1 Quote Link to comment Share on other sites More sharing options...
