davidian Posted December 21, 2020 Share Posted December 21, 2020 any ideas what size and thread nut these run? Tried M12 - too small, M14 - too big, 1/2'' UNF - too small, 9/16 UNF too big... Steelmasters don't have anything that fits (first time ever). Any ideas before I take the grinder out would be highly appreciated. Quote Link to comment Share on other sites More sharing options...
Adoom Posted December 21, 2020 Share Posted December 21, 2020 Is it 1/2" Whitworth? Slightly larger than 1/2" UNF. Quote Link to comment Share on other sites More sharing options...
tortron Posted December 21, 2020 Share Posted December 21, 2020 try 1/2" unc? doubtful its witworth, mk2s went metric 1 Quote Link to comment Share on other sites More sharing options...
Mof Posted December 21, 2020 Share Posted December 21, 2020 UNC is coarse? The end of the stud doesn't look so good Quote Link to comment Share on other sites More sharing options...
tortron Posted December 21, 2020 Share Posted December 21, 2020 yes its coarse. put a thread gauge on it and measure tpi if you want to be sure 1 Quote Link to comment Share on other sites More sharing options...
davidian Posted December 21, 2020 Author Share Posted December 21, 2020 @torton after trawling the shit out of forums, Ive found references to MK1 originally being imperial (mine is '68 - first year), then the Mk2s went metric, so not the same apparently. I've had a thread guage onit and it was close/same as a 1.25 so Id say not UNC... Quote Link to comment Share on other sites More sharing options...
tortron Posted December 21, 2020 Share Posted December 21, 2020 Probably you have mk2 parts and it's 1.25 12mm 1 Quote Link to comment Share on other sites More sharing options...
davidian Posted December 21, 2020 Author Share Posted December 21, 2020 why don't my M12 1.25 nuts work then? Quote Link to comment Share on other sites More sharing options...
Bling Posted December 21, 2020 Share Posted December 21, 2020 Could be damaged thread as Mof mentioned? Maybe give it a tickle up with a file. Sit a m12 1.25 bolt next to that thread and see how it lines up. Quote Link to comment Share on other sites More sharing options...
tortron Posted December 21, 2020 Share Posted December 21, 2020 Yeah it will be cos the end is damaged that nothing fits Quote Link to comment Share on other sites More sharing options...
davidian Posted December 21, 2020 Author Share Posted December 21, 2020 your kind responses are not helpful sorry. I have tried both sides and I have measured both with digital verniers. M12 is SMALLER cheers Quote Link to comment Share on other sites More sharing options...
tortron Posted December 21, 2020 Share Posted December 21, 2020 What is your measurement from the caliper From the tpi, if it's not metric it's probably unf which is pretty close to 1.25. it wouldn't be whitworth as it would be the wrong tpi for that size Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 21, 2020 Share Posted December 21, 2020 It's not simply M13 is it? Because the British are fuck wits. I imagine you'll be able to get the nuts from an escort specialist but I would ponder whether you could die it down to M12 at a similar pitch. Quote Link to comment Share on other sites More sharing options...
Bling Posted December 21, 2020 Share Posted December 21, 2020 1 hour ago, davidian said: your kind responses are not helpful sorry. I have tried both sides and I have measured both with digital verniers. M12 is SMALLER cheers Post the dimensions of the bolt and thread pitch then. We are all just throwing darts at a board hoping to hit the bullseye with the details provided. 2 Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 21, 2020 Share Posted December 21, 2020 5/16 UNC for MK1, 12mm for MK2. Edit: that's coming from a UK Ford forum, but yeah thinking about it that's too small, the poster there seems to have put the size of the top shock nut for mk1 ha. 1 Quote Link to comment Share on other sites More sharing options...
Valiant Posted December 21, 2020 Share Posted December 21, 2020 Sounds and looks like 1/2unf with a damaged lead in to the thread. Mk1 was imperial threaded. Have you got die nut you can tidy that thread up with? Quote Link to comment Share on other sites More sharing options...
anglia4 Posted December 21, 2020 Share Posted December 21, 2020 1/2" UNF = 20 TPI 1.25mm pitch = 20.3 TPI If M12 is too small, but the thread measures very close to 1.25mm pitch, I would hazard a fair guess that its 1/2" UNF with a damaged thread. If your caliper measurement was anywhere near 12.7mm then yeah, bullseye. Quote Link to comment Share on other sites More sharing options...
davidian Posted December 21, 2020 Author Share Posted December 21, 2020 cheers to you all lads, I will clean up the thread an try the 1/2UNF again. To my eye, both M12 and 1/2 were just a shade not big enough on the ID to fit over the thread, whereas 14 and 9/16 slid over the top. @kyteler I'd love to try a M13 but no one stocks them (as in steelmasters, AES, blacks etc.) worse comes to worse the grinder will come out, replace stud with a bolt + sleeve and done, just wary of welding anything suspension wise (altho original has welds in it) Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 21, 2020 Share Posted December 21, 2020 Not something Palmside sells? Or some other Brit Escort specialist site? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 22, 2020 Share Posted December 22, 2020 ENFORD might be able to help you out. Quote Link to comment Share on other sites More sharing options...
