VK304's 1988 Nissan Vanette w/ added SR20DET
Willdat?
  • Replies 57
Tbh is lacked the torque to drive normally in such a heavy but small van
it was great for doing redline doooorts or driving on the limit of van handling abilities
Got a few confused looks when I could beat altezzas or integras in a traffic light drag
 tech post about changing the primary input resistor on the tacho input to the cluster, the sr will have a low voltage tacho drive and the tacho is expecting a coil negative collapsing voltage pulse,  this modo should get your tacho working,  done it to my VK from link g4 output   and a corona with 3sge beams ecu
  • 2 months later...
  • 4 months later...
