Sign in to follow this
SOHC
SOHC’s 1927 Ford
2 minutes ago, igor said:
Pretty sure December 1951 is the cutoff for accurate speedo for a wof.
 A vehicle first registered in New Zealand on or after 1 December 1951 that is capable of a speed exceeding 50km/h is not fitted with a speedometer, and the vehicle operator cannot produce acceptable written evidence (Note 2) that:
a) the speedometer has been removed for repair, or
b) there are no undue delays by the vehicle owner in having the speedometer replaced.
Share this post
Link to post
I would like a speedo, this thing can actually exceed the speed limit.
if all goes to plan tomorrow I will drop the engine off to the builders.
Share this post
Link to post
Well engine is at the builders now and it’s going to cost more than I had budgeted for, it’s going to be a $12k kinda engine
  • Sad 1
Share this post
Link to post
Just got the clutch and pressure plate + flywheel back, over $700 bill, ouch.
Share this post
Link to post
Yep that sounds about right...  pricey still in the states too... might be worth finding a runner here or import one?
Share this post
Link to post
I am at the point of no return with rebuilding an engine, I need to come up with another 5k I think for the work.
I did buy what I was told was a rebuilt engine that is in the car now but it’s been done wrong and fumes and tapps, oil pressure not great. It’s actually more economical I think to go down the rebuild road, then I know what I have got.
Share this post
Link to post
I hear ya, I never tend to trust pre-built stuff too.  Is the core of it all at least good ?  No cracks where they are notorious?
Share this post
Link to post
It’s been hot tanked and passed a visual inspection, but it’s going to be magnafluxed and pressure tested, I hope like hell its ok, I have other engines but they won’t take the piston bearing combination I have
Share this post
Link to post
1 hour ago, tortron said:
There is some racing class where they run half a SBC
Share this post
Link to post
Some people used the Ford or Simca V8 and flipped them upside down and made them run backwards and used the intake ports as exhaust and exhaust as intake, the V8 60 is also the worlds smallest v8, works out about 2.2 L
https://www.jalopyjournal.com/wp-content/uploads/2009/04/upside.jpg
Share this post
Link to post
i have some questions about oiling, but dang thats neat
easy, dry sump, and oil pick up is under where the intake manifold use to cover.
The only question is how they attached the stainless steel sides to the tin side V860
Share this post
Link to post
I wonder what the reasoning for that was? Better weight distribution?
Seems like a lot of work to just knock the radiator pipes and plugs off when you go over a bump
Share this post
Link to post
Lower centre of gravity and you don’t have the exhaust ports snaking thrugh the cooling system, guys in NZ would put wetsuits on under the racing overalls as after a race they would blow a hose off sometimes and the wetsuit stoped them getting scalded.
Share this post
Link to post
There is a mint speed way museum in Auckland, it’s a gold coin donation, he has a cople big sheds full of cars and stuff. I use to live just up the road.
Share this post
Link to post
