Corza’s 1986 Toyota Crown
Corza_88
Discussion thread
Hey team.Thought I’d  spark up a project thread for old bluey
Has been in storage for years.Last Wof reg in 2014.
Got it back home now as I’ve built a shed.There must’ve been a rat living in the engine bay rat shit everywhere.
Cleaned all that out and degreased motor.
Has a fuel issue
.I can get it running if I poor petrol down the carb Otherwise it doesn’t start.Decided I should pull the fuel tank out drain and clean it and check the pickup for blockage
That means pulling the rear AC shit out to remove the tank what a mission
Current plan is to get it running and drive able
Get as low as possible on some old school rims
WOF and Reg.
There is rust around sunroof and rear windscreen which will need fixing
  • Like 8
Sunday had a few hours free for shed time and beers so pulled out front springs and tried to fit some XF falcon front springs but couldn’t get them to fit as they spring diameter is 10mm larger
The reason for that is the front is about 20mm to low on cut standard springs and rear is 40mm to high needs compressing and I’d had these XF springs sitting for years so tried to use them up front
Have now decided to get shit done properly and have ordered through BNT pukekohe low springs for front and  standard Springs rear
once I get the wheels I want I can install new springs and compress down to required height and new bushes etc.The shocks I have are shortened KYBs so can re use those
chucked on wheels of my old hiace for a laugh
started it up still running rough.drove onto driveway then turned it off then under bonnet tinkering away
go to jump back in drivers seat and hello the alarm locked the car so now it’s sitting in my driveway with the only key in ignition
pretty pissed off at myself because I’d been cautious of that all afternoon till then ffs
so yeah may as well give it a wash because I’m locked out of the bloody thing spacer.png
Have decided to stay true to my original plan and go for jdm style wheels
as much as I love 12 slots and eagers I’m not sure the crown would suit them so I’m on the hunt for old school mesh style wheels
Deep dish staggered rims are also dope as
What have you guys run on your Toyota’s?
discussion link below
What wheels you reckon? PFA
