Mr. Mainstream Posted August 22, 2020 Share Posted August 22, 2020 Hey team, Just out of the blue all my indicates failed to work. The hazard switch also now does nothing. I have checked and replaced the fuse. I tried the joint pin 1 &2 on the hazard pins with no luck. Any ideas? I guess replace the relay, My guess this is it shown? Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted August 22, 2020 Author Share Posted August 22, 2020 Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 22, 2020 Share Posted August 22, 2020 Flasher unit or fuse. Or an earthed out and melted switchgear. Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted August 22, 2020 Author Share Posted August 22, 2020 By switch gear do you mean at the column itself? 2 Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 22, 2020 Share Posted August 22, 2020 Yep. Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted August 23, 2020 Author Share Posted August 23, 2020 yep, so about 15months ago i replaced the switch gear with one from palmside https://palmside.co.nz/products/escort-mk2-new-indicator-switch as it was as sloppy and worn. so kinda ruling that out at the moment, managed to articulate my large body once again under the dash to have a poke around to see if anything looks suspect with no luck. guess il replace the relay, can anyone confirm the photo shown is it? chur Quote Link to comment Share on other sites More sharing options...
ajg193 Posted August 23, 2020 Share Posted August 23, 2020 Never rule out a failure because a part is "somewhat new" 1 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted August 25, 2020 Share Posted August 25, 2020 I'd start with the flasher relay. They are cheap and easy to replace. Quote Link to comment Share on other sites More sharing options...
