Joe's Cortina mk2
MightyJoe
  • 4 weeks later...
well that was a quick month. shit. kaikoura hop next week so i've been doing small jobs instead of the big ones i should be doing. anyway.
i bought some rubber and trim from palmside. 20200910_150931_copy_2064x1161.thumb.jpg.1b3217f46a26f2c77fe1df2ea2ef3e7f.jpg
Before, 20200910_152200_copy_2064x1161.thumb.jpg.cdb893a1e2c1489de337db4e10e1357f.jpg
After. so good.
i bought some new brake flexi hoses as i was sure the old ones were giving me some of the spongey pedal feel, i havent tested them yet but the pedal does feel nice.
the front screen rubber was shot so i took it out, and there was some surface rust there which i cleaned up and treated, i'll refit the screen tomorrow with the new rubber and trim. i topped up the diff level and gearbox also, and made an attempt at polishing the wheels... pics to follow
Faaar out what a weekend. We travelled to Hanmer on Thursday and woke up friday morning to snow. lol.
20200918_055212_copy_1651x929.jpg.ed454ae8e33f1bbfe2c97c2126d7a0bc.jpg20200918_070636_copy_1651x929.jpg.170683d53003e556a6e0d131f380377e.jpg
That was good fun though tbh, there werent any scary moments. Kaikoura bound, feeling very underprepared. 20200918_070611_copy_1651x929.jpg.462eee49c34f41c28c4e94cde24fe291.jpg
The Clutch master died on the way over. got lucky with the roadworks and managed to bang gears/  revmatch enough to get all the way into town without stopping once since leaving hanmer. i pulled straight into the caltex and spoke to the mechanic there. he rang round for me and tried to locate a rebuild kit but there wasnt anything anywhere he could find. i decided to try a brake master from a trailer, only as i saw one on the shelf at safe r brakes yrs ago and thought, hmm, that looks similar. turns out theyre identical. fuck yeah. shop across the rd had 2 in stock. the snow hadnt reached KK but the rain had, so i had 40 mins of getting wet and lying on the floor on a sketchy as fuck jack reching in through the wheel well to bleed it. but it worked. 20200918_090652_copy_1651x2935.thumb.jpg.9715f2f17fab6723921b84154d910156.jpg
the sun came out after i'd finished because of course it did so we cruised the strip a bit until we could check in. 20200919_152547_copy_1651x929.jpg.cf28a34c1e3a1bc0e8a314c744b4924c.jpg
Night time at south bay.
then the sat cruise. I got hit, fairlane couldnt stop, smacked into a mini which then shunted me. the mini was badly damaged unfortunately. i feel really bad for the guy.
i was pretty pissed off but did some stuff still, but mostly waited until the afternoon and parked my arse on the espalande with a box and watched the cars cruise.
on the way home...
The damage. FU! its been a pretty intense few days tbh.
  • Like 8
  • Sad 16
  • 5 months later...
  • 6 months later...
Its been ages since an update again, its been off the road for ages, my own fault cos i cant leave anything alone but i took the head off in may / june as i have never been properly happy with the power, its always felt flat and considering its got an a2 cam and a vernier on it i thought i should try and dial it in. trying to keep up with my mates bgt was too much effort so i went chasing power. i spent months waiting for parts from th uk, and when they came spent another few months trying to get it to idle and i was chasing vacuum leaks all over the show. i tried 3 different gaskets and im pretty sure shes right now. i've got a blackline lsd sitting in the house waiting to go into a GT axle i've half refurbushed, i ordered 2 wheel cylinders, shoes and a spring kit sometime in june and they made it to auckland, sat there for 3 weeks and then got sent back for some reason. the guy emailed me saying they'd been returned. perfect. so i need another plan for that. i;ve got new wheel bearings pressed onto the axles and waiting, so need to re source those parts and get that 3:54 rear end in.
during lockfown 2.0 i got out at it and started tnkering. i bought these name tabs off ebay and made a small control panel for the accessories. I'm pretty happy with it, they were supposed to be mounted under the dash but I didnt like the way the keys interfered with them so I moved them, only now you cant see the tabs clearly hence they angle they're on. meh. itll do. 20211017_182248_copy_1161x2064.thumb.jpg.2be41af36abc15af681a574e91774f1c.jpg
discussion.  opinions on the top mount situation appreciated.
another bits and pieces update this week. went to fit my shock inserts and found both top mounts are perished. They're kind of functional due to where they've failed but also very much at the end of their life, so I fitted one insert and left the other as theyve both got to come out again anyway. They are made of that famous cortina unobtanium but I can get repro ones. I'm hesitant though as I've fitted aftermarket rubber to the triumph and it lasts a few yrs and is then also fucked. I'm leaning toward the (believe it or not) slightly cheaper adjustable mounts which means a cert for sure but they're fully adjustable and rebuildable with a spherical bearing.  I'm gonna talk with palmside tomorrow about how viable they are for a road car.  also had a stall with the rear axle. I cant get wheel cylinders at the moment. worst case I can get rebuild kits but the guy is gonna ring me tomorrow if he can get some then I'll get a hard line made. pics...
damaged top hat.
replacement options
251057800_10158537867317993_5270944196719071695_n.jpg.6520463103bb9e79c21b3ddc3ded6b5d.jpg
it's a shame these get hidden.
  • Like 7
