Popular Post rumrum Posted July 5, 2020 Popular Post Share Posted July 5, 2020 tried to think of a catchy title ^ for my new 2002 gilera ice 50.... I've always wanted one of these as the cool kids were riding them when I was in England (you can hide spliffs and 8ths in the glove box real well) I've had "gilera ice" on my favorites search on trademe since trademe was invented.... there are now only 100 odd on the road in the uk so becoming very rare, this one came up on marketplace hahaha bloke wanted 400 I gave him 300 and said cheers, has a live plate, non working front brakes and seized front shocks.... i can work with that. I have a 70cc malossi cylinder kit in stock and have on order a malossi flip exhaust, new front brake lever and master cylinder new tires and malossi multivar 2000 variator kit, new 19mm pwk carb. I'm hoping for 100kph. any way ill dump photos here, it came in ok condition but definitely worse for ware first up is starting to strip and hot water blasting grime and oil. ps if you haven't hooked your water blaster up to the laundry hot tap are you even living? 16 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 5, 2020 Author Share Posted July 5, 2020 here's what they are supposed to look like 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 5, 2020 Author Share Posted July 5, 2020 here's stripping the fork seals, no oil at all and fully seized... also you can't buy oem seals for them anymore and were made specifically for the ice model ..... fark Quote Link to comment Share on other sites More sharing options...
Lord Gruntfuttock Posted July 5, 2020 Share Posted July 5, 2020 Must be able to find a generic seal by dimensions...? Cool looking scoot btw. 3 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 5, 2020 Author Share Posted July 5, 2020 cheers mayte, yeah alot of piaggio vespa gilera parts interchange, like the centre stand is pretty much for every Italian 50cc... so hoping an early model piaggio zip will come close, might a mm too small but meh can stretch Quote Link to comment Share on other sites More sharing options...
Kimjon Posted July 5, 2020 Share Posted July 5, 2020 Seal imports? I always seem to find something that'll work, or can be made to work from those guys. 5 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 5, 2020 Author Share Posted July 5, 2020 mean I'll give them a hoon ! Quote Link to comment Share on other sites More sharing options...
Thphantum Posted July 5, 2020 Share Posted July 5, 2020 Springer conversion 2 Quote Link to comment Share on other sites More sharing options...
peteretep Posted July 6, 2020 Share Posted July 6, 2020 Dont forget idle jets, main jets, needles. And rollers too Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 6, 2020 Author Share Posted July 6, 2020 6 hours ago, peteretep said: Dont forget idle jets, main jets, needles. And rollers too correct jets come with bigger carby, rollers come with multivar kit ill also be putting in a new belt, tourqe driver, clutch, clutch bell housing, reeds and intake manifold that can mainline a boost bottle direct 1 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 6, 2020 Author Share Posted July 6, 2020 then crankshaft and port match/polish 1 Quote Link to comment Share on other sites More sharing options...
Kimjon Posted July 6, 2020 Share Posted July 6, 2020 14 hours ago, rumrum said: then crankshaft and port match/polish I'm always blown away by how far out tbe ports etc can be from "matching". Simple blueprinting can make these little motors so much snappier and responsive. Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 7, 2020 Author Share Posted July 7, 2020 29 minutes ago, Kimjon said: I'm always blown away by how far out tbe ports etc can be from "matching". Simple blueprinting can make these little motors so much snappier and responsive. yeah man, especially the Chinese clone copies, half of the exhaust ports are normally blocked, a die grinder and a dremel a d you can make them fire breathers 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 10, 2020 Author Share Posted July 10, 2020 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 10, 2020 Author Share Posted July 10, 2020 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 11, 2020 Author Share Posted July 11, 2020 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 11, 2020 Author Share Posted July 11, 2020 dirty bitch Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 11, 2020 Author Share Posted July 11, 2020 quite a difference 1 1 Quote Link to comment Share on other sites More sharing options...
rumrum Posted July 11, 2020 Author Share Posted July 11, 2020 4 1 Quote Link to comment Share on other sites More sharing options...
