~Slideways~ Posted July 13, 2020 Author Posted July 13, 2020 14 hours ago, kyteler said: Noisey but grippy to go with it? Definitely better, probably no where near as good as they should be since they are old. Quote
kyteler Posted July 13, 2020 Posted July 13, 2020 I run semi on the FD, will hold off on the Roadster for now as I somewhat want the loose nature of it for a bit of a laugh. Should put some Ling Longs on... Quote
~Slideways~ Posted July 14, 2020 Author Posted July 14, 2020 40 minutes ago, kyteler said: I run semi on the FD, will hold off on the Roadster for now as I somewhat want the loose nature of it for a bit of a laugh. Should put some Ling Longs on... Yeah I totally agree, with the supercats and the lsd it was fun in the rain pulling away in first gear with way too many revs, but it'd barely chirps into 2nd. It really needs just a little more power. Is yours 1.6 or 1.8? Last night I investigate fitting a random pod filter to the AFM but didn't have the right combination of joiners etc. I ended up leaving the factory air box, removing the snorkel thing (doesn't even lead to cold air) and drilling some big holes into the air box while still letting the panel filter do its thing. Driving it to work this morning it has a good amount of induction noise, previously it was all exhaust noise (has a aftermarket rear muffler of some sort, the rest is facotry). Sounds pretty cool actually, not sure its making any noticable power though. I've read that a lot of the intake restriction is due to the 90degree bend from the AFM down into the air box plus the AFM itself. I'm pretty tempted to buy a diy kit for a speeduino just to see how much of a restriction the intake really is by removing the AFM and piping etc. It may actually lose some torque since I think that long intake pipe is meant to help with bottom end torque. The top end really does feel choked and flat. All suppliers of the plug in MX5 speeduino have been sold out for a while but the diy solder kit is available. Would have to splice it in or get some spare ecu female plugs. Quote
kyteler Posted July 14, 2020 Posted July 14, 2020 Mine's the wee baby 1.6, unlikely to have LSD either but throttle check due to poor clutch is inconclusive. Pretty keen on pod as basic but ideally would love itbs for max dort noise. Maybe I should make a thread too. Quote
~Slideways~ Posted July 14, 2020 Author Posted July 14, 2020 Just now, kyteler said: Mine's the wee baby 1.6, unlikely to have LSD either but throttle check due to poor clutch is inconclusive. Pretty keen on pod as basic but ideally would love itbs for max dort noise. Maybe I should make a thread too. Yes you should. I'm still considering using bike itb's using joiners to the stock runners, cut off etc. I know it can be done. Seems like not much to be gained unless higher compression and cams though. But the cool noises... Or a simple turbo setup with either a td04 or a twin scroll td05 if it would spool ok. First step would be an ecu, keep it low budget with a Speeduino, free up the intake and exhaust might be enough? Quote
kyteler Posted July 14, 2020 Posted July 14, 2020 Yeah, a spare intake sliced up on bike carbs and some custom octopus spaghetti headers would be sick. It's never going to set the world on fire so it may as well sound good and be a laugh to drive. Quote
~Slideways~ Posted July 17, 2020 Author Posted July 17, 2020 Have ordered a DIY solder Speeduino kit, it's coming from the UK so who knows how long that might take. Both the Aus and UK Speeduino suppliers have been out of stock of the MX5 PNP ones for quite a while and never had a reply from the Speeduino guy in AU so just bought a solder kit. Have done a decent amount of soldering but never anything like this, think it'll be pretty cool. If it works, I can then play around with Tunerstudio without too much fear of blowing up an expensive engine. Plus the lack of turbo or anything like VVT should make it a good way to learn the basics of tuning. Quote
shrike Posted July 17, 2020 Posted July 17, 2020 7 minutes ago, ~Slideways~ said: Have ordered a DIY solder Speeduino kit, it's coming from the UK so who knows how long that might take. Both the Aus and UK Speeduino suppliers have been out of stock of the MX5 PNP ones for quite a while and never had a reply from the Speeduino guy in AU so just bought a solder kit. Have done a decent amount of soldering but never anything like this, think it'll be pretty cool. If it works, I can then play around with Tunerstudio without too much fear of blowing up an expensive engine. Plus the lack of turbo or anything like VVT should make it a good way to learn the basics of tuning. Ive built a 0.4 kit, and my soldering was pretty shit and it still worked, use a fine point on your soldering iron, decent solder and make sure your at the right temp. I got a circuit board holder so I could rotate the board. Quote
~Slideways~ Posted August 8, 2020 Author Posted August 8, 2020 Speeduino kit arrived from the UK, bought a PCB holder thing from Jaycar. Still waiting on the mx5 adapter board but made a start on soldering. Quote
~Slideways~ Posted August 16, 2020 Author Posted August 16, 2020 Did a bunch more, pretty fun to put together: Quote
~Slideways~ Posted August 17, 2020 Author Posted August 17, 2020 Got a second hand ecu to salvage the plug and will use the case as well. Mx5 pcb vs speeduino: Plug removed: Found someone made an adapter board for the mx5 two plug which saves me having to figure out the pin outs: soldered on: added the 40pin and some more bits to the main pcb: Quote
~Slideways~ Posted August 21, 2020 Author Posted August 21, 2020 Trying to find out what type of resistor and diodes the adapter needs but Other than that it’s altogether. Will need to modify The standard ecu case as it’s too tall. Quote
~Slideways~ Posted August 21, 2020 Author Posted August 21, 2020 2 hours ago, Adoom said: Can you get another case and stack them? Maybe... the standard one can go on top although the bolt holes don’t go through. I’ll probably just space it out or make a new bottom plate. Quote
~Slideways~ Posted August 22, 2020 Author Posted August 22, 2020 Like a glove: From the top you can barely tell, which is the side you can see. Just the extra screws on top and the USB cable out the side: Mounted on pc stand off screws: All in there with hole in the side for the cable: Quote
~Slideways~ Posted August 26, 2020 Author Posted August 26, 2020 It does things! Firmware successfully updated with speedyloader: Tunerstudio recognises it and when I set the map sensor correctly it reads a change when I blow into a vacuum hose: Connected to the mx5 loom it powers on and the LED’s flash when it cranks: Next I need to go to Pick a Part and find a suitable variable TPS that’ll fit and maybe a generic Air temp sensor and see if it will fire. Then decide what AFR sensor to use, could just take the one out of the 200sx but to be honest I haven’t been impressed with it. Quote
BlownCorona Posted August 28, 2020 Posted August 28, 2020 bmw e36 (or pretty much any bmw) TPS is popular, several options for mounting it to the mx5 throttle Quote
~Slideways~ Posted August 29, 2020 Author Posted August 29, 2020 17 hours ago, BlownCorona said: bmw e36 (or pretty much any bmw) TPS is popular, several options for mounting it to the mx5 throttle I literally just got back from Pick a Part with a BMW one! Cheers though. I was actually hoping to find a Nissan one which is supposed to be a good fit without an adapter. None there so got the BMW one based on the PnP kits. I'll see if I can make an adapter or if I need to get one 3d printed. Quote
BlownCorona Posted August 29, 2020 Posted August 29, 2020 i dont see any reason you couldnt make one. 3d printed ones can be purchased from someone on the NZMX5 Facebook page, but i cant remember who. i also got banned from that page for consistently pointing out that one of the mods, who is also on oldschool, advice is always horrible and wrong lol. Quote
