michael0008 Posted May 17, 2020 Share Posted May 17, 2020 hey all looking at upgrading my ignition system on my hillman imp from points, currently have a 25d dizzy and been looking at electric dizzy kits seems like they all are no good or are silly expensive so was looking at accuspark electric ignition kit and remove the accuspark module so Im using it just for the inductive pickup and wire it up to a bosch HEI ignition module mount the module on the chassis with a heat sink is there anything im missing that wouldn't make my idea work or any suggestions 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted May 17, 2020 Share Posted May 17, 2020 I'd say go for it should work nicely 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted May 17, 2020 Share Posted May 17, 2020 I've only used the pertronix stuff.. Never failed and real simple to install. If you get them from the states they are way cheaper. *edit, PerTronix LU-142A on amazon for about US110 delivered to nz.. 1 Quote Link to comment Share on other sites More sharing options...
h4nd Posted May 17, 2020 Share Posted May 17, 2020 Have a go. If it doesn't work reliably, have a friend with an oscilloscope check it for correct voltages / impedance matching / polarity etc or just use TAI so the points last waaaay longer. 1 Quote Link to comment Share on other sites More sharing options...
michael0008 Posted May 17, 2020 Author Share Posted May 17, 2020 7 minutes ago, yetchh said: I've only used the pertronix stuff.. Never failed and real simple to install. If you get them from the states they are way cheaper. *edit, PerTronix LU-142A on amazon for about US110 delivered to nz.. Yeah I've heard good and bad about pertronix , have you used it for awhile or just a year? Just now, h4nd said: Have a go. If it doesn't work reliably, have a friend with an oscilloscope check it for correct voltages / impedance matching / polarity etc or just use TAI so the points last waaaay longer. Haha very true I might have to do this! Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 17, 2020 Share Posted May 17, 2020 Just now, michael0008 said: Yeah I've heard good and bad about pertronix , have you used it for awhile or just a year? Have had a pertronix in my V8 since 2004. No issues so far. 1 Quote Link to comment Share on other sites More sharing options...
Benno Posted May 17, 2020 Share Posted May 17, 2020 I've got an Accuspark in the escort. No problems with it, so much smoother and less maintenance than the points were 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 17, 2020 Share Posted May 17, 2020 Yeah, barely need to look at them. I replaced the Lucas dizzy in my Morris Minor (probably also a 25D) with an electronic Nissan dizzy (N13 maybe?) by swapping the drive gear. Has been pretty well trouble free for 15+ years too. 2 Quote Link to comment Share on other sites More sharing options...
yetchh Posted May 17, 2020 Share Posted May 17, 2020 1 hour ago, michael0008 said: Yeah I've heard good and bad about pertronix , have you used it for awhile or just a year? Had them in my land cruiser in Aus for 3 years no probs, zephyr was burning points constantly and would also when cold, slowly idle slower and slower till it stalled, would also run like a pig till warm.. Put in a pertronix igniter II about 2015 and that all disappeared. Starts first pop no choke.. 1 Quote Link to comment Share on other sites More sharing options...
michael0008 Posted May 19, 2020 Author Share Posted May 19, 2020 Cheers guys I might just get a accuspark and see how it goes then if it fails look at external module Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted May 22, 2020 Share Posted May 22, 2020 My experience with Pertronix stuff is fixing poorly installed units and dodgy reluctor wheels. Unless you're running a well tweaked engine my general advice stick with the points. The number of people that fuck up fitting those kits is amazing. But cheep points like fuel miser are shit too. Good quality points and condenser in a distributor that isn't worn to hell will fire up no problems and run sweetly. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted May 22, 2020 Share Posted May 22, 2020 I can sell you a Lucas opus electronic distributor if you want a period correct piece (of crap) 3 Quote Link to comment Share on other sites More sharing options...
michael0008 Posted May 22, 2020 Author Share Posted May 22, 2020 I could be interested in this period piece of crap for the pickup and wheel 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted May 23, 2020 Share Posted May 23, 2020 It’s like night and day going to electronic ignition, I like the ones that use the cam lobe to trigger the module and not a slip on plastic thing with magnets witch can flog out Quote Link to comment Share on other sites More sharing options...
