Mattt's 1970 RT80 12A Bridgeport TEQ Corona
Mattt
  • Replies 42
Right so a question for you 12A experts. I’ve heard you can “flip” the sump and run a front hump sump as a rear hump sump and just redrill the holes. I lined it up to test this theory and quickly found the oil restrictor at the front hits the sump. Is it just a matter of notching the sump for the restrictor? At this point I may just fabricate a whole new sump. I just need to sit the engine in the hole to check clearances before committing to a design.
help!
480301CD-4B66-487D-B4B1-134D42EE38A7.jpeg.9d6d0414f039d66f14e93d8e763d404a.jpegC39B30FE-19CA-425F-ACA8-B4C3E85A09DD.jpeg.be2c80d4166657fbb1c4fc39e7cce6cb.jpegA5540CFD-54DD-45D9-9EEB-6072E0E2F239.jpeg.7e7c8d37dce1905c2d4b21d51f01e9f0.jpeg
Quick update
driveshaft in
oil lines plumbed
exhaust bolted up
heater hose plug in
oil in the engine
coolant in the radiator
not much left now, basically mount and plumb fuel pump and do the wiring of which most of it’s there. Exciting times!ACBCD3B8-2F51-4B8E-B9D0-D0E446AAD813.jpeg.09bb3eaee4dcd93127145cc7bf8ef31a.jpeg
  • Like 7
For some reason this thing came with the wrong alternator pulley. It had a 13A belt pulley and the rest of the engine needs an 11A belt so I ordered a new dual row pulley from franklin engineering. Top notch stuff they make and seriously reasonable prices for quality Nz made products. Ordered an oil sender block at the same time to run my oil pressure and temp gauge senders. Will fit that in the next couple of days.FE8B51DA-B3A4-4FAE-A62A-258CA32D25CE.thumb.jpeg.605a9b6bc774e9a3ef2525dcfd45a0e9.jpeg
  • Like 7
