Srstarlet Posted April 25, 2020 Share Posted April 25, 2020 Hey guys im not very good with computers so hopefully this is right. Ihave a 1989 Toyota hilux with a 2y in it. It was running on 3 cylinders at the beginning of lockdown and I had put it down to the fact it was leaking oil past the spark plug tubes and onto the plugs. So I replaced the plug tubes and cleaned up the plugs still running on 3, I checked the timing and it was way out so I set it to around 8 btdc as I had read somwwhere and it ran better still not right though. Yesterday I went to move the truck and no start, winds over and backfires couple of times but won't run. I checked spark at plugs and all plugs have got yellowish/orange spark on all plugs in all leads. Points aren't burnt and rotor and cap look clean. It has got fuel at the carb but I thought id give it some engine start spray and no noticeable difference, also tried rotating dizzy through adjustment while cranking but still no real change Any ideas of what could be happening thanks heaps I hope this makes sense Quote Link to comment Share on other sites More sharing options...
AllTorque Posted April 25, 2020 Share Posted April 25, 2020 If it is backfiring and not starting I would guess you have the timing wrong. What state are the spark plug leads in? Quote Link to comment Share on other sites More sharing options...
Srstarlet Posted April 25, 2020 Author Share Posted April 25, 2020 Thanks for the quick answer! I thought it may be related to timing being out as that's what I'd been touching last. So I tried cranking while rotating dizzy back and forth and no real change so set it bak to old witness mark. The leads all look to be in reasonable condition, eg not cracked or anything. I have measured the resistance of them if that helps Coil to dist 2.29k 4 to dist 2.46k 3 to dist 1.85k 2 to dist 1.70k and 1 to dist 1.22k while I don't really know what any of that means nothing seemed to be way higher than another Quote Link to comment Share on other sites More sharing options...
Srstarlet Posted April 25, 2020 Author Share Posted April 25, 2020 Update: it's running again, albeit on 3 but I think no.4 lead is crook. I noticed that rotor was pointing between 1 and 3 when at tdc, don't know how I didn't see it before, pulled dizzy out and turned round a bit so rotor lined up a bit nicer towards 1. Put dizzy back but it had a flat on bottom of shaft that didn't line up so pulled it out and turned the groove down in the hole with a screw driver, put dizzy in turned key and it went thankfully. I'm not sure what happened for it to be out but. . . It's good for now. Just thought I'd put a update on this Cheers for ya help 1 Quote Link to comment Share on other sites More sharing options...
Bluebird_U Posted April 25, 2020 Share Posted April 25, 2020 What happens if you swap No4 lead to one of the other cylinder, just to see if the miss follows it? Might save having to replace a few things. Quote Link to comment Share on other sites More sharing options...
Srstarlet Posted April 25, 2020 Author Share Posted April 25, 2020 I did look at doing this but none of other leads were long enough to reach back to no.4. I guess if it still ran on 3 with no.4 lead on no.3 plug and nothing on 4 then I could rule out the lead. I may have a bit more of a look at it in the morning. Still really confused how dizzy was so far out though Quote Link to comment Share on other sites More sharing options...
