Kimjon Posted March 26 Author Posted March 26 A catch up photo of where I'm at now with the Chaly. Exhaust on order too. 5 Quote
Shakotom Posted March 27 Posted March 27 Do you need a stock chain guard / Headlight casing w speedo? Have got both listed on trade me but will cut deal for OSGC /an undercowl? Quote
Kimjon Posted March 27 Author Posted March 27 6 hours ago, Shakotom said: Do you need a stock chain guard / Headlight casing w speedo? Have got both listed on trade me but will cut deal for OSGC /an undercowl? Thanks man, really appreciated. But I just ordered those parts the other day. Quote
Kimjon Posted March 27 Author Posted March 27 Probably looks no different, but slowly solving problems and taking it from Instagram ready - to closer to actually going. I made a brake pedal, pin. The front fender mounting hardware was all made from scratch (still needs some work). Exhaust is on the way, lots of other parts too. 4 Quote
Kimjon Posted March 29 Author Posted March 29 Been chipping away at this in the background. Slowly fixing all the shitty stuff, clutch, gear cables, electrics and wiring, carburetor, brakes, etc etc etc... There's fuckloads to do, but im enjoying it a lot. Things that go are much cooler than things that don't. 6 Quote
Kimjon Posted March 31 Author Posted March 31 Yeah, I'm pretty happy with this. So I ordered an exhaust from mbike, but unfortunately it wasn't a bolt on fit. It hung so low it touched the ground. Bit ko problems...just solutions. I cut it up and welded it back together the way I wanted it to go, running super tight to the frame. Gained 60-80mm clearance and looks bitchen! Win/win. 6 Quote
Kimjon Posted March 31 Author Posted March 31 Also made my own footpegs and brake lever. #custom 8 1 Quote
Kimjon Posted April 1 Author Posted April 1 Made up a rear taillight/license plate bracket. Needs a paint job obviously, but looks the part. 1 Quote
Kimjon Posted April 10 Author Posted April 10 Okay...wee bit of scope creep, yip I've totally lost the plot on this and gone full retard. 3 1 Quote
Kimjon Posted April 13 Author Posted April 13 These rear sets have not been easy. I've re engineered both sides, and spent longer than I'd care to admit (probably upwards of 10hrs) machining up adapters, pivot arms, linkages, stand off etc. I can count 18 different parts that I've had to make in order to get both sides to function. Would I do this again...ummmm...not so keen. I made my harley forwards controls and they look a lot more impressive, but took half the time. These have been a right cunt of a job. But hey...its basically done now. So the pain will be long forgotten in a few weeks time. 3 Quote
Kimjon Posted April 13 Author Posted April 13 Amongst all the big jobs, I get the occasional win with a small job like this key bracket. I always think of project binky, and how making any type of vehicle is basically a collection of brackets. I now appreciate a good bracket more than most. 3 Quote
Kimjon Posted April 13 Author Posted April 13 More brackets, witj rubber isolating bushes. I had to use the motor as a "sky hook" to attach the other brackets too, that are fixed to the chassis. Never a great idea - so the isolating bushes will hopefully stop bad things happening as the two play tug of war. 2 Quote
