Jamie’s rx 323
J4m13
Pretty stoked to see all the original seam sealer still in place and unbroken on both guards!! And the original parcel shelf there, with factory stickers on the inside of the bonnet. Pretty original I think.
feom here is where my parts Aquire and hoarding started.... again
So I’m not sure if many k ow from my rx7 thread. But I live in qld... and there’s no jail bar grills ever for sale here. So I turned to NZ and not a week later of browsing I found one and bought it and had it couriered over. Not long from there I purchased a blown 323 diff and a b1600 diff. Funnily enough from the bloke I bought the hatch off.
so started the laborious job of cleaning the old mounts off the 1600 diff in preparation for the transfer of the mounts from the 323.
I also made the trek from just out of Brisbane where I live down to Sydney to pick up a “complete conversion package”
when I got there it turned out to be a 13b bridgeport with IDA, s1 gearbox and nothing else.
of I’d known I sure wouldn’t have driven 24hrs pretty much straight for that.
live and learn.... but that wasn’t the last time for me to make a mistake and live to regret it... you shall find out later
  • Like 8
Was a prick to get all lined up properly, and the 323 mounts actually fitting correctly as the 323 housing has a much smaller diameter than the 1600. But after a bit of fettling, they all lined up so I asked a welder friend of mine to glue them back on.
  • Like 8
From here I wasn’t sure a 6stud axle was my best choice, so threw the axels n the lather you’re turn me down until the fit the Nissan discs I’d acquired. Also had some brackets/mounts laserwd out of 10mm plate
So then it was time to fit the LSD head in, which went in a piece of piss. No notching or anything.
not long after I found a PP that I thought I’d like to grab.... and a whole lot of other parts mysteriously started arriving at my house that my wife was puzzling about
I’m not sure if it is just me, but I wasn’t too impressed with how the back half on the inlet ports were filled. I know into the block they were devconed appropriately, but it must be an Aussie thing to only fill it halfway and then put tin foil or steel wool to same a buck or two.... cheap cunts. So I then needed to pull that shit out and seal it properly...
  • Like 9
I had a sneaky suspicion the motor I picked up from Sydney wasn’t as I’d been told/ expected. And being as I was fucking tired I didn’t do a thorough inspection as I should’ve. Needless to say it’s pretty fucked. I did an inspection with a borescope at work and my suspicions were confirmed. And so my thoughts turned to the gearbox. I made the assumption it to was fucked so bought an mx5 box because all the reading id done said it was an easy fit. Just exchange the bell housing and tail shaft. Cut 10mm off the end of the Input shaft and I’ll be away so people said on forums.
Well fuck me, not on a s1 box.
so I did the bell housing and tail section with the gear shifter. Had to change the gear shift linkages also. Measure the overall length of my s1 input shaft from the bearing to the end. Sure enough, mx5 was 10mm longer so I cut it off.
bolt the box up and it won’t go... fuck me tried again, and again. Wouldn’t do the last 10-20mm.
pulled it and the motor out for a measure up. Everything ok. What the fuck is going on?!?!
look and the end of the crank shaft and bugger me dead, there’s in imprint of the spline m the end of the shaft where the pilot bearing lives. My predicament from here was to take the input shaft from the rx7 box and change it over, or machine the mx5 splines down.
i chose the machine option, these next rusty photos will show you how good condition the 7 box was in
  • Sad 2
I took my gearbox into work the next day, and with the help of an internet site I stripped the thing right down until the input shaft fell out.
put the shaft in the lathe and started machining it down. Didn’t really put much thought into it at first but chipped about three tip tools. Must be bloody hard!! So got the grinder out and used it to take it down to about 1-2mm from final outside diameter And machined the rest.
cleaned all the gears, synchros etc in the parts washer then had the job of reassembling it.
  • Like 8
So I got to removing my standard diff today in preparation for the lsd.
I purchased a pair of Rear lower Control arms from an rx7 to remove the big ugly 323 ones that incorporate the rear spring perch.
After installing them  in place of the originals with the standard diff in they’re a little too long, but that’s no issue. I’ll either shorten them, or lop a section out and add some fittings to make em adjustable.
i did run into a bit of a predicament with the qa1 rear adjustables.
id known they needed a bit of modding on the car, so putting it out there with everyone to gimme some feedback as to wether it’ll work.
I had a bit more progress with my qa1 shock. The steel inserts/crush tubes for the upper shock mounts weren’t the right size so I had to figure out what I was going to do. So I took the easy way out. I pressed out the rubber bush from the original shock. Remove all the rubber from the original shock crush tube and pressed that it. Right length, o.d and I.d
bloody winner!!!
Im going to try run the other bushes from the other end of the shock and see how things go. They slip in, fit what seems appropriate enough so will have to report back after a few k’s are put on it when I finally get it on the rd
Also, ive got a week away from work so i'm going to tackle the wiring.  Those who are proficient and this magical wiring stuff... ive got 1.5mm and 2.5mm.
Would this cover most of the stuff I need to do to both extend my loom, and wire new relays and positive feeds etc??
Any help would be appreciated, write up on the discussions.....
I started my week off, last week on Thursday, and set to sorting the wiring.
im not a sparkey, and have never really wired anything up before so to tackle this was a big of a head fuck to say the least.... but I got there.
i chose to extend my harnesses, so to keep the factory colours at the end of the runs. Not sure if this was the right thing to do but made sense to me at the time.
anyways, here’s a pic or two
To make it easy for me, I ran 3 “circuits”
headlights and indicators. Instruments, and ignition.
so the lights were a basic cut, solder and lengthen.
the ignition was a bit trickier, as I wanted there to be minimal wiring in the engine bay, and to look somewhat professional. So that’s all new, from the fuse box forward. I had a ball ache of a time looking at wiring diagrams, tracing wires etc to utilises the correct ignition circuits from the original ballast system, so I gave that up n reached out to an old auto sparky i knew from way back when and he told how he does it.
so same deal with alternator wiring. Fucked if I knew what to utilise from the old ext reg system but nutted as much as I could before again reaching out.
so all that was done and dusted, clipped up and ready for action yesterday morning.
enough dribble, more photos
