  • Replies 65
14 minutes ago, bigfoot said:
From memory, they have a proportioning valve thing in the back that works off suspension height. My brother had issues on his l200 when it got slammed into the weeds. There is a length part of the lever needs to be at ride height
Whoops. Who would have known that overloading the crap out of the poor old girl would have consequences. Nobody could have predicted this.
Messenger_creation_14D6BBE8-C526-46E6-9D39-8CE18798CCD6.thumb.jpeg.de508ddb80446978f56e2d4b73cc8b7c.jpeg
Now to do some sleuthing and find this valve thingy.
Passed the wof. It was pissing down so was good fun screeching about the back streets.
Jeez they really need to bring the 12 monthly wofs in for old cars. Doing my head in.
Time to put her back to work. Poor thing.
  • 1 year later...
Right then. Looks like this thing just joined the conga line of cunt projects I have under 2.5 years to finish.
Options:
Fb marketplace lucky dip 4g63
Rebuild what is in there properly
In the parts bin I have a 283 chev and a Nissan ed33
Answers on a postcard.
24 minutes ago, chris r said:
Chemseal and send it.
Surprised it had enough oil in it to make a milkshake? Usually it's all burned
The previous owner @Bearded Baldy who shall remain nameless skimmed the head whilst wearing a visible g banger peaking out over his jeggings. If that didnt scare the head into hugging the block out of fright then chemseal wont do much.
  • Haha 4
That's not bhg milkshake that's a delayed orgasam from the g banger head job
  • Haha 1
I am not going to validate either of those comments. Not going to deny them either.
  • Haha 1
14 minutes ago, HumberSS said:
Go get it a year wof then slap that ed33/sbc in it and forget about it for a year.
I measured both today whilst bored and the ed33 wont fit (too long) but the chev would with a radiator mod.
A 3.8 fits easily with the weird front sump too.
Wonder how hard the EFI 2l is to wire up. Im always fiddling with the weber. 🤔
6bolt crank efi has cam sensor on back of head with not enough firewall clearance unless you slot the engine mounts.
Mid 90s 7bolt dohc efi should have cam and crank on the front.
I have a folder on pc full of info and pictures. Will send it to you for some light reading.
Used to be a site called hotrod coffeeshop or something like that, that had wiring pinouts and stuff.
Manifold needs throttle body flange swapped end to end or use an Evo4 intake on the '7bolt' head.
Swap the ute ring gear onto the frontwheeldrive flywheel should negate any starter motor alignment issues.
I think that is the basics of it.
@lush would be a fountain on knowledge on the subject, and can tell you everything i just said is wrong lol.
It's all getting into the to hard basket. I might just whip the head off and take it in to get reconditioned. Hoping that being an iron block the block isn't the issue.
I need to get a fan shroud or electric fans on the radiator too. Not that I recall it ever overheating but there is a mile between the fan and the rad and I'm ntot sure that does anything.
Theres actually also a long and short fan iirc, also a pajero jr fan shroud should fit
I may be hallucinating both those things, as I only know buick l200s, but I think I absorbed that info on thr ram50 forum
