Bearded Baldy
Bearded Baldy's 1985 Mitsi L200 Discussion Thread
Ok guys n girls.
What diff heads will fit in the old turd?
I am guessing any of the l200/pajeros up to the mid 90s, when all the platforms changed.
Ideally want a 3.9 lsd.
Share this post
Link to post
Just now, Bearded Baldy said:
Ok guys n girls.
Pretty much. I put a 2nd gen LSD in mine, it's 4.22 but suits me. Starion ones fit
Share this post
Link to post
Beauty cheers Tortron, has a 4.875 in it at the moment.
Coupled with the low and wide 14s it puts the speedo out by around 15km at 100.
Share this post
Link to post
yeah mine was out by about that for 20 years from when it was certed
these were sold as dodge ram 50's / d50s in the states. so cheap parts off rock auto
www.mightyram50.net if you haven't seen it yet
Share this post
Link to post
Cool truck! love the wheels :-).
Only the later Starion stuff (5 stud) with the bigger 8" CW will fit, the earlier 4 stud stuff (more common in NZ) is the smaller 7.25" CW.
Finding 3.9 gears for the 8" stuff is a might tricky. Early L200 sport models had them. I put 3.5's (from a widebody starion out of the states) and a 2nd gen LSD head in mine though as I wanted better highway cruising. The 3.9's that were in mine were pretty worn out and noisy. With the smaller tyres on it putting the taller diff in it has corrected the speedo which is excellent :-).
Share this post
Link to post
Have been lurking on mightyram for the last month or so, that is where the long term turbo swap idea stemmed from.
Will definately check out rock auto too.
ProZac re the wheels, i usually do not go for white writing on my tires, my 4x4s i have the tires showing blackwalls. But this ute just seems to suit it so will get similar when they need replacing.
Good info on the starion gear, when this lockdown is over i will put the word out amongst my suppliers. I have a suspicion a local-ish one has some early 80s stock hiding in a far corner of the yard.
Share this post
Link to post
Side topic. Are the turbo rvr motors really as bad as the yanks make out for crank float?
I have seen a few die but more from lack of maintenance and/or cooking them.
Share this post
Link to post
If they have more than one 3.909:1 8" CW&P setup, let me know, keen for my Starion GSR-V clone project.
Nah, I dont reckon the 7 bolt (RVR) motors are as bad as they make out, not if you keep it maintained and aren't asking huge power from an internally standard motor. They do make the install easier having the timing gear on the front of the engine.
Share this post
Link to post
Will keep you in mind when i ring them after this shitshow is over.
Would not be looking for insane power, poor ute would not be able to put it all down anyway.
2.5 inch exhaust, front mount behind the grill. Should make for a fun trip to the dump.
Might start looking around, see how much people are asking.
Share this post
Link to post
@tortron , just went on rockauto for a quick look. That is a dangerous site mate!
I went on looking for front shocks and checked out with allsorts of parts i do not need yet, but so cheap i could not not buy them.
Any other sites you know of? Lol
Share this post
Link to post
Check that seam on the wheel well and floor and the seams under your bonnet on the firewall
(Also everything else because mitsi)
Share this post
Link to post
Yeah firewall seam is ugly in the corners, which means if i start digging it will be ugly across the whole thing. So i am not digging yet. Wheel arch seam looks ok on passengers side, drivers side was average so cleaned it up while i was there.
Panelwork is not my area of expertise, in any way shape or form.
Share this post
Link to post
Can see the floor/wheelwell seam in the pic, rusthole right above it.
Had to do a near identical repair on my old navara a few years ago, panelbeater gave it the all clear so i am doing it the same way. In theory should be a ok this time too.
Share this post
Link to post
You might find with the sport dash and tacho your high-beam light on the dash doesnt work. Its a simple fix, I've got pics somewhere.
Share this post
Link to post
I have not checked that yet. Will do today if i can sort these motors out without stringing myself up.
Share this post
Link to post
On 16/06/2020 at 21:10, Unclejake said:
You may have seen this already, but if not perhaps it's of interest to you (or is possibly yours already. Dunno).
https://www.trademe.co.nz/motors/wrecked-cars/auction-2663748839.htm?rsqid=b3bf486211f84a99a596d6f9ead3c081-001
Cheers for the heads up, that ute is not mine, bloody close though. Might get made to sleep outside if i brought a 3rd one home this soon lol
Share this post
Link to post
